Foot Light
Discussion in 'Lighting' started by Tondra, Dec 24, 2017.
  1. Dec 24, 2017 at 12:36 AM
    Tondra
    Tondra [OP] New Member
    2018 Magnetic Gray Metallic SR5
    Quick question, does the Tundras have a foot light at the passenger side or is it just the driver's side?
    Prostar 190, geno0506 and Y0TA PR0 like this.
  2. Dec 24, 2017 at 12:37 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Mine only has it on driver side.
    geno0506 likes this.
  3. Dec 24, 2017 at 12:41 AM
    Tondra
    Thanks! My wife dropped her earrings tonight and she asked me to turn on the foot light on the passenger side, I said I don't think it has one. She disagree she said well if the driver's side has one the passenger side should have one too. She thinks the light bulb is probably burnt out.
    Black Wolf and Y0TA PR0 like this.
  4. Dec 24, 2017 at 1:03 AM
    geno0506
    geno0506 New Member
    Michael
    My 2017 SR5 only on drivers side!
    Y0TA PR0 likes this.
  5. Dec 24, 2017 at 8:00 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Driver only. You can add LEDs as some dude have on here.
  6. Dec 24, 2017 at 9:05 AM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    This is how mine looks
    BR73, vipgs3, r1-superstar and 9 others like this.
  7. Dec 24, 2017 at 6:50 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    Looks like mine too! Courtesy of VLEDS inside LED footwell kit! Totally agree it should have come this way, but easy fix...
    BR73 and (deleted member) like this.
  8. Dec 24, 2017 at 7:24 PM
    mscroggi
    mscroggi New Member
    toyofan87 likes this.
  9. Dec 24, 2017 at 7:54 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    Yes, this is an updated version of the kit I bought for both front and rear. Just plug it in and route the LED strips under the dash, glove compartment and each rear seat.
    BR73 and Skippy like this.
  10. Dec 24, 2017 at 10:02 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Darth Tundra likes this.
  11. Dec 24, 2017 at 10:39 PM
    And how the hell did you do that?!?!?!
  12. Dec 25, 2017 at 5:25 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    For mine, I ordered the kits for the front and rear from VLEDS. It includes an adapter that replaces the bulb in the driver side footwell, and then I plugged in the LED string for the driver side and attached it under the dashboard with the included double-sided tape. Then, I plugged the LED string for the passenger side on the end of the driver side string and ran it behind the console and attached it under the glove box. Next, using the provided long extension wire which is plugged into the passenger side LED string, I ran the extension through the kick plate on the passenger side under the door sill to the passenger front seat. Next, I mounted another LED string under the passenger front seat, attaching it to the seat frame. The kit has a short extension that I used to connect the final LED string under the driver seat to the passenger seat LED string and mounted the final LED string under the driver seat.
    Basically, the kit has everything I needed to "daisy chain" the LED strings once the driver footwell bulb was replaced by the adapter.
  13. Dec 25, 2017 at 10:19 AM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    I did the same thing! I ordered mine from VLEDS using the older version
  14. Dec 31, 2017 at 6:46 AM
    mscroggi
    mscroggi New Member
    I installed mine yesterday... Be careful with those clamp on connectors used to wire in the extension. Those connectors are plastic crap.. One came apart on me.. The other failed to get a good connection. While installing the lights, one kept flickering out.. I discovered it was one of those connectors. I didn't want to worry about that connection going out eventually (which I am sure it would), so I cut them off and soldered the connections. I almost just ripped the kit out and went back to the single footwell light..
    BR73 likes this.
  15. Dec 31, 2017 at 8:32 AM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    I also used heat shrink to help keep the connection together.
  16. Dec 31, 2017 at 10:46 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    good point...I used electrical tape to keep the connections together...
  17. Jan 6, 2018 at 12:55 PM
    MGMTUNDEE
    MGMTUNDEE New Member
    Quacky
    Tampa
    I put the VLED kit in my truck about a week ago and I absolutely love it!
    BR73 and ChucklesToy like this.
  18. Jan 15, 2018 at 8:32 AM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    Will this work on an 18...my light on the footwell is tiny....
  19. Jan 15, 2018 at 8:35 AM
    MGMTUNDEE
    Quacky
    Tampa
    Yes I installed the VLED's in mine and I have an '18
  20. Jan 19, 2018 at 9:52 AM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    so i plan on installing my front Vleds kit I got yesterday...any pointers? came with no instructions
  21. Jan 19, 2018 at 11:20 AM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Check post #12 explains how to do it.
  22. Jan 19, 2018 at 1:21 PM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    Finished, little wire connectors suck, cut off wires and bonded the gather. 15m install, looks awesome
    Eclipsed & Floating and Berdine like this.
  23. Jan 20, 2018 at 7:41 AM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    From the driver side, I used some 3M cable clips to run the cables to keep it from hanging and getting snagged. Stick the lights on your desired location in the footwell. To get to the passenger side, I passed the cable behind the dash...straight across . Any excess cable is zip tied to get your desired placement.
    Basically, cleanly hide the cable as much as you can. Remove side panels if you need to.
    From the Front Passenger to the rear, remove the side panel. I attached the light under the front passenger seat. Now, to get to the driver side, slide the cable from the passenger under the center console. Again, use a zip tie for any excess cable.
    Skippy, Ely010606 and ChucklesToy like this.
  24. Jan 20, 2018 at 8:17 AM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    Worked great, amazing the light output
  25. Jan 20, 2018 at 8:29 AM
    Berdine
    Binghamton, NY
    So, you guys ordered 2 kits, did you order and extension too?
  26. Jan 20, 2018 at 8:48 AM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    I did not install the back seat lighting. With the led interior kit I get good lighting in the center/back
  27. Jan 20, 2018 at 10:31 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    If you order the front and rear kits, the rear kit includes connection to the rear.
  28. Jan 20, 2018 at 10:47 AM
    Berdine
    Binghamton, NY
    I'm curious because on their website just shows front.
  29. Jan 20, 2018 at 2:12 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    @porkitt , did you remove the head unit to pass the wire from the driver side to the passenger side, to get through the behind the dash. Thanks, i just ordered mine. Any info will be greatly appreciated. Thanks
  30. Jan 20, 2018 at 2:26 PM
    smooosh
    smooosh This place costs me too much $
    2018 TRD Offroad Limited Crewmax.
    Ongoing project
    You all do white? Anyone do a color?
