Fog Lights
Discussion in 'Lighting' started by deucedeuce, Jul 11, 2015.
  1. Jul 11, 2015 at 5:51 AM
    deucedeuce
    deucedeuce [OP] New Member
    I have a 2014 Tundra SR5. This morning on my way to work I noticed that my fog lights did not work. I checked the all the fuses everything is working fine. Any ideas why they are not working?
  2. Jul 11, 2015 at 8:28 AM
    Tundros
    Tundros New Member
    Johnnie
    Hawai'i
    2011 Gray Tundra Dbl Cab 5.7L 4x4
    Aftermarket front and rear lights, added fog lights, bed liner, bull bar, bed cover, chrome door handles, chrome mirrors, side steps, AFE stage 2 Short RAM intake, Pioneer stereo, Alpine 6x9 front door speakers, 6in Pioneer round speakers rear door, 1 12in Pioneer sub with 1200 watt Sony Xplode amp. Toyota door logo courtesy lights and 20in black and machine rims on 275/60 Cooper HT plus M&S tires also painted red calipers. Also painted red Toyota emblem.
    The other two things I can say is one: check the wiring to ensure it isn't damaged due to rodents. Second check the actual bulb. If you run your lights a lot they could be blown
  3. Jul 11, 2015 at 10:22 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    If you've already checked the fuses, its time to check the bulbs (although the odds of them both going out at the same time, are pretty low). If that doesn't help, its time to pull out a meter or a test light to see if power is getting to the lights.
  4. Jul 11, 2015 at 12:29 PM
    It's a 14. I wouldn't bother messing with it, and just take it to Toyota for warranty work presuming you haven't messed with anything that could effect it.
