Fog lights not working
Discussion in '1st Gen Tundras (2000-2006)' started by Oottoo, Feb 1, 2021.
  1. Feb 1, 2021 at 2:05 PM
    Oottoo
    Oottoo [OP] New Member
    2005 sr5 TRD
    Hey guys. My first gen is having a fog light problem.
    Got this truck a truck a few years ago and when I got it one of the fog bulbs was out so I disconnected the working one just so I didn’t have one bulb illuminated if I accidentally turned the switch. I meant to get a new bulb but I completely forgot about it until now.
    Anyhow, just installed new bulbs and instead of the fog switch turning on the fog lights, IT TURNS ON THE BRIGHTS?!? I might add, the normal bright switch works too to turn on the brights. also no Little blue indicator to tell me my brights are on. All the while the fog lights are not turning on at all... so I’ve tried the fog fuse, it’s good. The next thing i was gonna try is the fog relay. Otherwise I’m stumped?
  2. Feb 1, 2021 at 2:34 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Welcome to the forum.
    Sounds like you're using LEDS, or the computer isn't getting proper signal "back" from the lights to say "OK, yeah the high beams are on. Heres a blue light on the dash."
    Try these. I have a set.
    https://www.superbrightleds.com/mor...-led-headlight-bulb-conversion-kit/3957/8622/
    Some will say that only one is needed, but I never found a definitive "Yes" saying that only one was required. I installed both using JB weld Steelstik on the fender wall thing near the headlight.
  3. Feb 1, 2021 at 3:00 PM
    Oottoo
    2005 sr5 TRD
    Sweet! Thank you so much, perhaps that would explain the radio interference as well.
    The LEDS are so nice to have so hopefully this fixes it!
    Tundra2 likes this.
  4. Feb 1, 2021 at 3:03 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Leds cause radio interference in general. The only way to fix that is to change the radio head unit for a "modern" one.
    I still have my stock radio. I've noticed that when I run my high beams there's static like crazy.
    (Light bar is tied into the high beams.)
    Same thing when I hit the brakes. Leds there also.
  5. Feb 1, 2021 at 5:01 PM
    Oottoo
    2005 sr5 TRD
    Copy.
    I ordered that kit. I read some other stuff of people having the same problem they said it fixed it.
    If it doesn’t. I might just direct wire some little led floods with their own switch in the place of them.
    Tundra2 likes this.
  6. Feb 1, 2021 at 5:01 PM
    Oottoo
    2005 sr5 TRD
    Thanks again!
    Tundra2 likes this.
  7. Feb 1, 2021 at 5:12 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    By the way, Welcome to the club. There's lots of good info in build threads, and on the two daily threads.
    Admittedly, the search function on this website is pretty much useless. I have more luck using Google, and adding tundras.com at the end of search.
    Here's the lunctable thread. A lot of us 1st gen guys bullshit, and discuss "off-topic" things here.
    Here's the what have you done to your 1st gen Tundra? Thread. Lots of goodies here.
    1st gen build threads
  8. Feb 3, 2021 at 8:05 PM
    dropindeuces
    dropindeuces New Member
    I picked up and installed this set:
    https://www.superbrightleds.com/mor...esistor-kit-h4-led-headlight-bulbs/2179/5079/
    It seemed to work and allowed me to use my fogs finally but I went in for a double check of the connections before committing to drilling and mounting and found that the resistor unit was very hot. It was only on for possibly 5 minutes max. Thinking about just scraping everything and going stock.
    Tundra2[QUOTED] likes this.
  9. Feb 3, 2021 at 8:58 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I linked the wrong part earlier. Either one will work. I have the set that you linked. My bad. :anonymous:
    Anyways, instead of drilling, and bolting. I mounted mine with JB weld Steelstik. It comes in tube, you blend it together, and then stick it to the inside of your fender/enginebay. Mine are around the headlight areas. I can take pictures later on if you want.
    I've had mine mounted with steelstik for going on 4 years now. No issues with the resistors, or the stik.
  10. Feb 3, 2021 at 9:05 PM
    dropindeuces
    Oh I see no worries. But does yours get hot after a few minutes as well? Thats what worries me, the last thing I need is my wiring harness going up in flames because I wanted brighter lights :rofl::bananadead:
  11. Feb 3, 2021 at 9:53 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yeah, it's hotter'n'hell. Especially on the forearm. It's only the resistor box that gets hot because a resistor is literally a heater like in your oven.
    I have mine tucked out of the way so I never have to touch'em
  12. Feb 3, 2021 at 9:59 PM
    dropindeuces
    LOL I see. Well thank you and I am sorry about your forearm. If you get a chance can you send me a pic of where you mounted it, Im sure i could mount it anywhere but just curious where you decided to put it.
  13. Feb 3, 2021 at 9:59 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'll do that when I get home today, but you may have to remind me. Lol
  14. Feb 3, 2021 at 10:03 PM
    dropindeuces
    I wish I could man but it looks like your in Kentucky and Im in Cali ~3hours diff and I am not a morning man lol. So if I get it I get it lol.
  15. Feb 3, 2021 at 10:04 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'm a night shifter. So it's midnight here, so it must be 9pm there?
  16. Feb 3, 2021 at 10:17 PM
    dropindeuces
    Yeah close 1020 pm. But yeah I worked night shift too, 11pm - 7pm for 12 years, I feel you man.
  17. Feb 3, 2021 at 10:21 PM
    dropindeuces
    Its not a rush man, just when you get a chance.
  18. Jan 20, 2023 at 6:26 AM
    Pronto13
    Pronto13 New Member
    ‘06 white DC SR5 V8/4wd
    @Tundra2 could you still send a pic of how you mounted that resistor?
  19. Feb 24, 2023 at 5:41 PM
    Emwve
    Emwve New Member
    Turk
    2006 Toyota Tundra Double Cab SR5 4x2 V8
    I’d be interested as well on where you placed the resistor.
  20. Feb 24, 2023 at 5:44 PM
    Emwve
    Emwve New Member
    Turk
    Do you have any issues with the high beam indicator on the dash not illuminating when you turn on your high beams?
  21. Feb 24, 2023 at 5:50 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    When I installed LED headlights only, yes. You need in-line head light resistors.
    Some claim you only need one, but I installed two. One per headlight.
  22. Feb 24, 2023 at 6:01 PM
    Emwve
    Emwve New Member
    Turk
    Did you buy the Motorcycle Headlight Load Resistor - H4 LED Headlight Bulbs - H4 Connection Load Resistor from super bright leds?
  23. Feb 24, 2023 at 8:36 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yes. They have been on my silver truck since 2019? Long time. No issues with those.
    Emwve[QUOTED] likes this.
  24. Feb 25, 2023 at 4:35 AM
    Emwve
    Emwve New Member
    Turk
    I ended up buying canbus decoders from xtremevision that fixed the fog light issue. Then I later realized my high beam indicator wasn’t working. I thought I had it fixed…..I know it’s small but I would like to know the high beams are on, you know cause sometimes you forget. I’ve heard the load resistors get super hot. Can you tell me how you mounted each of them and where. If you have pictures that would be even more helpful. Thank you for being so helpful.
  25. Feb 25, 2023 at 4:55 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I have no pictures. I mounted them with jbweld steelstik right next to each headlight. I didn't drill a hole in nothing for it l.
    They do get hot. Hot enough to burn your forearms. I mounted them behind the radiator support.
    I can get you pictures later today
    shifty` likes this.
  26. Feb 25, 2023 at 5:01 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Also, I'm unfamiliar with those decoders. You do you, but real reason to get high tech on these trucks.
    I would remove those before trying the resistors
  27. Feb 26, 2023 at 10:32 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Meant to post the other day which fixed my high beam indicator not illuminating.
    I chose to install resistors on passenger side and instead of getting 2 H4-RL650-H which has 1 50W resistor in each box, I got the H4-RL650-M, which has 2-50W resistors in one box.
    Had some AC sheet metal laying around and chose to create a platform to attach to since like any 100 watt bulb, it does get hot. Also, since I chose the location I did, needed an H4 extender cable. My local Napa had just what I needed....8" extender
    Headlight Wiring Harness TEE HWH106 | Buy Online - NAPA Auto Parts (napaonline.com)
    Shouldn't matter but this was not for an LED install. This was on a Audi style DRL and halo, sequential turn signals with mini H1 projector and HID’s that @SouthPaw put together. Still holding up strong.
    The ultimate headlight project | Toyota Tundra Forum (tundras.com)
