Fog Lights Not Working... Help?
Discussion in 'Lighting' started by 650h1, Dec 7, 2017.
  1. Dec 8, 2017 at 7:28 AM
    650h1
    650h1 [OP] New Member
    2013 Rock Warrior C/M
    Yeah, just sucks that something doesn't work. How could one LED pod take out both fog lights like this? I don't get it.
  2. Dec 8, 2017 at 7:30 AM
    650h1
    I was reading somewhere there is a relay for the tail lights that may affect the fogs, anyone know where that might be?
  3. Dec 8, 2017 at 7:34 AM
    zlaneb
    zlaneb New Member
    Austin, TX
    Hold on there Pardner! I wrapped my 11 around a tree last year - replacing Tundras is Ex$en$ive :)
  4. Dec 8, 2017 at 7:34 AM
    Let me post this thread on a FB Tundra group and see what they can find..hang on.
  5. Dec 8, 2017 at 7:42 AM
    650h1
    I've made a few lol they're probably getting tired of seeing it. Might help you more than me though lol
    T-Rex266 likes this.
  6. Dec 8, 2017 at 8:44 AM
    650h1
    You make a fb post?
  7. Dec 8, 2017 at 8:47 AM
  8. Dec 8, 2017 at 9:43 AM
    650h1
    Well, shit.
  9. Dec 8, 2017 at 12:12 PM
    650h1
    Ok, I put the grey/pink wire AFL mod back to stock.
    I bent the back right prong of the fog relay out, connected a wire to it and grounded it.
    I now have fog lights, and they work just like the grey/pink wire AFL mod, but my switch doesn't control them anymore, since the relay is grounded.
    Which means, I need a new stalk/switch on the steering wheel?
  10. Dec 8, 2017 at 12:52 PM
    dsimonl
    dsimonl New Member
    2017 Tundra DC Limited MGM
    Amp Research Powersteps and Bedstep, 2018 LED headlights, LineX Platinum, Baja Designs fog lights, Driver side grab handle, SwingCase
    You made two changes, reversing the afl mod AND grounding the fog lights. Bend the relay tab back....see if the stalk works again.
  11. Dec 8, 2017 at 1:15 PM
    650h1
    No stalk doesn't work for the fogs. Seems like fuses and relays should have burned up before a $150 switch, but what the fuck do I really know. Leaving like this I guess, unless anyone has a deal on a stalk?
  12. Dec 8, 2017 at 4:00 PM
    650h1
    It works for everything but the fog lights so who knows. Don't try putting rigid duallys as your fog lights is the lesson learned...
  13. Dec 8, 2017 at 4:45 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    When you do the mod this way you completely take the switch out of the equation. If you returned the wiring back to stock you should be able to bend the prong on the relay back and everything should work as stock. If they don't come on try your original relay. It's been a rare occasion that I've had a relay go bad but I have seen relays fail after a prong gets bent too far and it cracks. So now 2 questions and I'm not questioning your ability so no offense meant but, are you sure you bent the right tab on the relay? And were you into the right pink wire on the original mod? The relay seems an unlikely culprit but there are several pink wires pretty close together under the column on our trucks.
  14. Dec 8, 2017 at 5:13 PM
    650h1
    So I had the mood working for a few months perfectly fine. I plugged the rigid light in and that's when nothing worked anymore. So I reversed the grey and pink wire mod back to stock. I tried the fog lights completely stock and they didn't work. I had already replaced the relay and tested all fuses multiple times. So to bypass the switch I grounded the back right prong of the relay and voila, lights work. So they now come on with parking lights and headlights regardless of whether the switch has them on or off.
  15. Dec 8, 2017 at 5:38 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    This. It’s either 1) fuse is blown or 2) the pins in the stock harness got damaged.
    NewImprovedRon likes this.
  16. Dec 8, 2017 at 5:51 PM
    650h1
    Or the switch... Lights are now working. Switch is not.
  17. Dec 8, 2017 at 5:53 PM
    650h1
    Just like the grey and pink wire mod except switch doesn't control them anymore. They are just on with parking and headlights. They are off for DRLs...
  18. Dec 8, 2017 at 6:05 PM
    650h1
    Hahaha maybe, i used the stock relay just on a whim and said fuck it, let's try. I had previously bent the same prong and wired it to an ignition source but the lights were always on with ignition so I undid that quickly. Works well just being grounded and beats buying a new switch for over a hundred bucks.
  19. May 6, 2018 at 8:00 AM
    #49
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    Quick question I have this problem trying not to buy a switch. I installed led fogs and the spider headlights and tail lights. Everything worked for a month then foglights stopped working and all of my running lights. I have power to my running lights but no power to my fog lights. All my fuses are good and heckled relay. I assume it has to be switch. I broke off the one prong of relay. I saw someone do this and they said they grounded a wire from the relay. Where or what does this mean and how do i do it.
  20. May 30, 2018 at 5:54 AM
    #50
    Rockford
    Rockford New Member
    2014 Tundra SR5/TSS- Grey
    Flip back bed cover
    I had a very similar issue. Installed new fog lamps, blue LEDs. They worked for about a month. 30 days after installing the fogs, I installed new headlamps, blue LEDs to match the fogs. Once I installed the headlamps the fogs stopped working. I spent days trying to sort this out. I turned to the internet for help and found this blog and was hoping I would find out how 650h1 resolved the issue but there was no solution posted. Damn! So I then started trying what other folks suggested in this blog. I checked all the fuses and all the relays under the dash and under the hood. I took it to my mechanic just to have him check things. We were perplexed. I actually set up a time to drop my truck off at the shop for him to troubleshoot this next Thursday and Friday. I had given up and was willing to pay someone to fix it. I recalled that 650h1 was contemplating replacing his switch stick. I had an AHA moment!!..... Well, I figured it out this morning after nearly a week of puzzlement, the switch to the fogs was in the off position on the switch stick. Turned them on and it was like Clark Griswold getting his Christmas lights to work on Christmas Vacation! Whatever, your solution is I hope you get the satisfaction I had!
  21. Jan 25, 2019 at 8:38 PM
    #51
    LuvTundra14
    LuvTundra14 New Member
    20190125_205743.jpg My 2014 blew the fuse also due to water in one of them shorting out the LED bulb. I found the fuse in the engine compartment and is 15 watts
  22. May 22, 2019 at 8:06 PM
    #52
    ussdgates
    ussdgates New Member
    Dave
    2018 TRD Sport
    TRD Pro Exhaust
    I have a 2018, I installed ridgid dulies in it, they worked fine for at least a month or so. Tonight I tried to turn them on to get more light and they didn’t work. I tried all the combinations of off and on with the light switch and the high low beams and nothing worked. I just thought about this as I read this post trying to figure out the cure. Has anyone tried disconnecting the battery for a little while to see if it’s a computer problem. I am going to try it in the morning and see if it makes a difference. Sometimes disconnecting the battery and touching the +- it will reset the computer. I remember reading somewhere on here when someone tried to plug in LED tail lights and the truck's computer didn’t like it. I’ll report back in the morning and let you know what happens.
  23. May 24, 2019 at 3:09 PM
    #53
    ussdgates
    Dave
    2018 TRD Sport
    TRD Pro Exhaust
    So I tried it out... it didnt work. I am a little upset about all this, this truck only has about 10k on it and problems like this should not exist, I guess i should have also not replaced the fog lights before they were broken. If anyone finds something out please post.
  24. Jun 10, 2019 at 9:00 PM
    #54
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Damn, im having the same issue, but I swapped mine with the OEM led, and now its not working. So I switch it back to the stock, no luck. I did everything to what you guys said in this post with no luck. Im dropping it off it off at the dealer and see what they are going to say. If its a pretty penny im just gonna leave it as is. I hardly use is. Just knowing it doesnt work just bug the F’N out of me.
  25. Jul 1, 2019 at 8:13 PM
    #55
    nmpeter
    nmpeter New Member
    South Florida
    18' Tundra Cement Crewmax
    Having the same issues with my 18 after using LED fogs for a couple of weeks+.
  26. Jul 1, 2019 at 8:21 PM
    #56
    Ely010606
    SPARKS, NV
    I took mine in , And they said i had excessive aftermarket stuff, and i said can you check it anyway and I’ll pay for it.
    So they checked it and it was the fuse , there are two fuses for the fog lights , one under the hood and another one on the inside side panel. I checked the one under the hood but i didn’t check the one under the side panel i was pissed already. The one on the inside panel was busted so they replaced it and didnt charge me. I know i should have checked it to save me the trouble. Hope that helps.
  27. Jul 2, 2019 at 11:30 AM
    #57
    nmpeter
    nmpeter New Member
    South Florida
    THANK YOU! The dealership would probably say the same thing to me.
  28. Jul 4, 2019 at 6:05 AM
    #58
    nmpeter
    nmpeter New Member
    South Florida
    Changed out my 15A FOGFR fuse with the extra ones in the box and everything worked again. Time to buy some spare fuses.
    Ely010606 and NewImprovedRon like this.
  29. Jul 4, 2019 at 6:48 AM
    #59
    nmpeter
    nmpeter New Member
    South Florida
    These cheap Amazon LED bulbs might have a lot to do with it.
  30. Jul 4, 2019 at 5:41 PM
    #60
    nmpeter
    nmpeter New Member
    South Florida
    To be honest, i’m just glad they’re working again. If the fuse blows out again, i’ll investigate.
    Ely010606 likes this.
