Fog lights not turning on
Discussion in 'Lighting' started by Blkaxe, May 22, 2015.
  1. May 22, 2015 at 6:47 PM
    Blkaxe
    Blkaxe [OP] New Member
    2015 Tundra Double Cab TRD
    K&N intake/Gibson exhaust/
    I have a 2015 Tundra, I have replaced most of the lights with LED's. All I have left to do is the headlights and the fog lights. I started with the fog lights and found that they no longer work, I know, check the fuses. I checked and double checked every fuse in engine compartment and the fuse box under the dash, all the fuses are good. To be sure, I replaced all fuses that had anything to do with the fog lights, there is no power getting to the fog lights. Any ideas?
  2. May 22, 2015 at 7:57 PM
    Tried putting the stocks back in? This may sound dumb, but I've had it happen on some led bulbs f you place it in the wrong way (turn the bulb around so contacts are facing other way if that makes sense) the bulbs don't work. Just a thought.
    Could a relay have been shorted? I wouldn't think so though...i don't specialize in electric. @csuviper is pretty good with it though.
    Horseshoer likes this.
  3. May 22, 2015 at 9:06 PM
    Mike Tread lightly.
    south carolina
    What did you exactly? Changing bulbs or mod or something else.
  4. May 22, 2015 at 9:53 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Could be the LED bulbs your swapping in. Do what Sean said and swap them back to stock as double check. If all you did was swap bulbs and nothing else then it's a bulb or fuse or loose wire at the bulb housing.
  5. May 23, 2015 at 8:51 AM
    I know that the LED's I used liked a certain way. I Ohmed out all the bulbs first for continuity. One open micro solder then no current flow.
  6. May 23, 2015 at 10:40 AM
    Blkaxe
    Yes, stocks are back in and they don't work. I checked the plug itself with a meter and have zero power going to the fog lights.
  7. May 23, 2015 at 10:44 AM
    Blkaxe
    No mods, just changing bulbs. I know that the LED's use less power and sometimes cause the system to think a bulb is out, maybe this is related?
  8. May 23, 2015 at 10:46 AM
    Blkaxe
    I will try that, thanks.
  9. May 23, 2015 at 10:49 AM
    Is there 12V to fog light relay and zip out?
  10. May 23, 2015 at 11:17 AM
    Mike Tread lightly.
    south carolina
    Sounds like the fuse under the dash one you missed is out. I think you need to go back through the dash fuses again.
    15 amp fuse it should be
  11. May 23, 2015 at 1:34 PM
    Blkaxe
    just got a fuse tester, gonna run through them again. Thanks to all!
  12. May 24, 2015 at 4:00 PM
    What happened. You get figured out yet?
  13. May 24, 2015 at 5:13 PM
    Blkaxe
    I checked every single fuse and they are all good. I ordered a couple of relays to see if somehow they might have blown. I will see what happens when I get those.
  14. May 24, 2015 at 5:39 PM
    Mike Tread lightly.
    south carolina
    Relay is possible the contacts dead shorted.
  15. Aug 30, 2015 at 11:28 AM
    BOOZTD5.7
    BOOZTD5.7 New Member
    tony
    2014 tundra sr5 dubl cab 4x4 trd
    Hi what happens if you find a problem reason I ask is I'm having the same issue and cannot find the problem if you fixed or found the problem please post it or let me know I will greatly appreciate it thanks
  16. Aug 30, 2015 at 2:24 PM
    Blkaxe
  17. Aug 30, 2015 at 2:25 PM
    Blkaxe
    I am actually taking it in tomorrow to have TRD Pro suspension installed, they are going to troubleshoot the fog lights while they have it. I will post what they find.
  18. Aug 30, 2015 at 4:02 PM
    Ahhhh yaaa!!! You'll love it! They are coming out with BOSS reservoirs later this year too...can't wait to try those! Either way, you can't go wrong!
  19. Sep 3, 2015 at 8:30 PM
    BOOZTD5.7
    tony
    Hi any updates on the fog lights?
  20. Nov 23, 2016 at 5:14 PM
    Sparky1024
    Sparky1024 New Member
    2014 tundra sr5
    I am having the same issue. took a chuck of wood at 60 mph to the passenger fog lights. now the won't turn back on. I have checked fuses, relay and they are good. still not getting power to the stock plugs
  21. Dec 7, 2017 at 9:03 PM
    650h1
    650h1 New Member
    2013 Rock Warrior C/M
    Anyone figure this out?
  22. Dec 7, 2017 at 9:11 PM
    csuviper
    Broomfield, CO
    Yours not turning on?
  23. Dec 7, 2017 at 9:14 PM
    650h1
    650h1 New Member
    Tried putting duallys in as my fog lights. I plugged one in, it didn't work, so I went back to stock. Never touched the passenger side light. Now neither of them will turn on. Ughhhhh
  24. Dec 8, 2017 at 7:33 AM
    650h1
    650h1 New Member
    Anyone?
  25. Dec 8, 2017 at 4:25 PM
    :popcorn:
  26. Jan 23, 2022 at 6:54 PM
    SacPuente86
    SacPuente86 New Member
    2011 Tundra
    Thanks for the help!
    Had the same issue fog lights not working, bulbs are good, fuses work. The issue was the relay, located outside the fuse box, picture attached.
