Fog Light Upgrade?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Silv333, Mar 4, 2020.
  1. Mar 4, 2020 at 10:00 PM
    Silv333
    Silv333 [OP] Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
  2. Mar 5, 2020 at 10:12 AM
    vnboy17
    vnboy17 New Member
    Paul
    Bay Area, CA
    I recently did the white SS3 Pros. These are a lot heavier than the stock fog lights, therefore the lights tend to bounce around while driving. Other than that, I'm pretty happy with the light output​
  3. Mar 5, 2020 at 11:07 AM
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    2015 Tundra Crewmax BRM
    I got the amber sports. as mentioned above, they’re heavier and my passenger side has some shake, but not bad at all. they’re good enough for me (in Hawaiʻi), since we don’t really have fog or snow.
  4. Mar 5, 2020 at 11:13 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Do a search for my thread with these lights. I was one of the first with them and there is a thread with a lot of information and pictures.
  5. Mar 5, 2020 at 11:13 AM
    Danman34
    Danman34 New Member
    Danny
    Shake can easily be fixed with zip ties
    pkeawe809 and kuokoa[QUOTED] like this.
  6. Mar 5, 2020 at 12:10 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
  7. Mar 5, 2020 at 12:16 PM
    Silv333
    NJ-NC-MD-NC
    Thanks. I checked your post out. Do they come in the back of the existing fog light or the front?
  8. Mar 5, 2020 at 12:17 PM
    Critical05
    Critical05 New Member
    2018 MGM TRD Sport, Crewmax 4x4
    The SS3 weren't much heavier than the OEM led fogs that I swapped out. Needed the zip ties on both.
  9. Mar 5, 2020 at 12:21 PM
    Danman34
    Danman34 New Member
    Danny
    Come in the back or the front? Not following your question.
  10. Mar 5, 2020 at 12:50 PM
    MSU Tundra
    MSU Tundra Numerous rodeos experienced
    Mississippi
    2017 Tundra and 2013 LC200
    If you're asking about how to install... They install from the front. You just pop out the plastic housing, unplug the harness, pull out the assembly to swap everything over, put it all back together, and viola. Takes about 10 mins.
    And yes, add a zip tie to secure the light assembly a little better to the plastic housing to prevent vibration.
  11. Mar 5, 2020 at 1:40 PM
    Danman34
    Danman34 New Member
    Danny
    They install from the back. Remove lower fender liner. No need to remove the entire bezel. One screw and the fog light housing pops out
  12. Mar 5, 2020 at 1:53 PM
    MSU Tundra
    Mississippi
    Much easier to go from the front imo.
    (thats what she said)
    calisparky and nekkyj like this.
  13. Mar 5, 2020 at 3:46 PM
    vnboy17
    vnboy17 New Member
    Paul
    Bay Area, CA
    if anyone is interested, I have the morimotos up for sale.
  14. Mar 5, 2020 at 3:56 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    You may have to install from behind. Many trucks have blue clips that prevent you from removing through the front.
  15. Mar 5, 2020 at 3:57 PM
    Danman34
    Danman34 New Member
    Danny
    Exactly. I honestly wasn’t even aware installing from the front was even an option.
  16. Mar 5, 2020 at 4:04 PM
    vnboy17
    vnboy17 New Member
    Paul
    Bay Area, CA
    didn't realize there was any blue clips. I have a 2014 SR5 and was able to pull it out from the front. The only thing about these fog lights is that they bounce around. Not sure how a product can be released and customer has to use zip ties. I don't know how I feel about that. Paid almost $300 for these not to use zip ties.
  17. Mar 5, 2020 at 4:13 PM
    Danman34
    Danman34 New Member
    Danny
    nothing to do with the fog lights. It’s Toyota’s bezel that needs reinforcement. It’s just a zip tie. It’s a cheap, simple, permanent solution.
  18. Mar 6, 2020 at 6:53 AM
    Critical05
    My OEM led fogs jiggled about which zip ties fixed, its Toyota's design.
    Even the Tundra Pro's with their factory rigid fogs lights need zip ties.
    mahmer09 likes this.
  19. Mar 6, 2020 at 11:04 PM
    Millerlowlife
    Millerlowlife New Member
    Toe-knee
    CM 4x4
    I installed the DD Sae fog in clear. I like them they were way better than my stock fogs. for the price its a great bang for my buck. i researched for a while. For the $200 they seem pretty well built I don't really have any shake.
    calisparky likes this.
  20. Jul 2, 2025 at 1:37 PM
    calisparky
    calisparky New Member
    chris
    2011 tundra crew cab
    "That's what she said".....
    I spit out my drink when I read that!
    10 points to you, sir.
  21. Jul 2, 2025 at 1:39 PM
    calisparky
    chris
    I know this is an older post but want to ask if they put out a larger projection on the road?
    Mine are nice on my 14 Tundra 1794 but don't really put out much further/side to side like I'd like as my Chevy dually truck has.
  22. Jul 2, 2025 at 2:38 PM
    Ghost Rider
    Ghost Rider Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    How far "further/side" are you looking at?
    I have the SS3 MAX, further, it's fine, I can see it roughly a quarter mile down? Didn't measure.
    As for the side, yea, I have drivers give me the dirty look on the side of my truck, if aim right, they are plenty for off-road/dark/fog use.
  23. Jul 2, 2025 at 3:25 PM
    Danman34
    Danman34 New Member
    Danny
    Not even a close comparison. The DDs are superior in every way.
  24. Jul 3, 2025 at 6:22 PM
    2020_Tundra
    2020_Tundra New Member
    2020 MGM Platinum Tundra
