Fog light question
Discussion in 'Lighting' started by 2006 Toyota Guy, Aug 26, 2018.
  1. Aug 26, 2018 at 5:41 PM
    2006 Toyota Guy
    2006 Toyota Guy [OP] New Member
    Lance
    Kirbyville, Texas
    Put new fog lights in my truck where there wasn't any there already wired for it so snap them to bulb connection. bought ablinker switch with a fog switch attached to it and it still does not work I meanthe fog lights so there's another panel to the left ofthe steering column wherethe dimmer switch is, and the back window up anddown switch found twowires in there on dummy switch was wondering ,if that was the fog lights I am puzzled about this any help would be appreciated thank you.
  2. Aug 26, 2018 at 7:09 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Those might be important wires, but also I would look on the fuse box in case you need to add a fuse for the fogs
    LaaMahTundra likes this.
  3. Aug 26, 2018 at 9:53 PM
    LaaMahTundra
    LaaMahTundra LaaMah Tundra
    Orange County CA
    06 Tundra DC Limited 4x4
    Nov’25:Finally 5100’s, UG to 17” Toyota OEM’s came with 265/70/17-BFG AT’s.
    Im no expert but did you try it with the headlights switched on?
  4. Aug 26, 2018 at 10:30 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    The switch is on the column stalk with the headlights. Headlights have to be on to flip the fogs on.
  5. Aug 26, 2018 at 11:54 PM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    Don't you need to install a relay?
  6. Aug 27, 2018 at 12:15 PM
    LaaMahTundra
    Orange County CA
    Research the Fog Light Mod while you at it. You may want to do it at the same time. Good Luck
    2006 Toyota Guy[OP] likes this.
  7. Sep 7, 2018 at 9:42 AM
    2006 Toyota Guy
    Lance
    Kirbyville, Texas
    I installed the relay on the backside of the fuse box turned on my lights on turn the fog light switch on which is on the steering column and the brights came on so now I'm really puzzled I guess I might just run a new wire for the fog lights.
    NewImprovedRon likes this.
