Fog light mod similar to Tacoma relay
Discussion in 'Lighting' started by bj46-taco-tundra, Aug 21, 2016.
  1. Feb 7, 2018 at 10:29 PM
    #61
    bj46-taco-tundra
    bj46-taco-tundra [OP] New Member
    Mark
    Bj46 taco and now a tundra
    Any problems with this to date yet? Anyone plug it into a hot wire + to allow anytime control from factory switch inside cab like the Tacoma. Love momentum this is finally getting.
  2. Feb 8, 2018 at 8:47 AM
    #62
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Mines working great let us know what u do
  3. Feb 8, 2018 at 8:52 AM
    #63
    dsimonl
    dsimonl New Member
    2017 Tundra DC Limited MGM
    Amp Research Powersteps and Bedstep, 2018 LED headlights, LineX Platinum, Baja Designs fog lights, Driver side grab handle, SwingCase
    Question was whether anyone plugged the wire into a positive terminal rather than grounding it as in post 59. Theory is that the stalk fog selector would function as it does on a Tacoma.
  4. Feb 8, 2018 at 10:27 AM
    #64
    xtyfighterx
    Ty
    North Idaho
    I think someone explained why this wouldn’t work on the tundra but hell if it does let us know,give it a go.
    I did it to my Tacoma I don’t see why it wouldn’t work on the tundra but when I was researching I thought I read somewhere it would work and has to be grounded but I could be wrong. I never use the stalk selector it’s always be on Full time. This just lets me run them with parking lights and hi beams now.
  5. Feb 13, 2018 at 8:36 AM
    #65
    Quick Sand
    Quick Sand New Member
    2016 tundra TRD pro dc
    Has anyone figured out if the taco mod would work on the tundra yet
  6. Feb 13, 2018 at 11:23 AM
    #66
    Quick Sand
    Sorry I must be missing it on page 2
  7. Feb 13, 2018 at 11:47 AM
    #67
    xtyfighterx
    Ty
    North Idaho
  8. Feb 13, 2018 at 5:49 PM
    #68
    Quick Sand
    Yes I understand what U wrote I was referring to page 1 first photo of the tacos set up but thanks for your reply I just might do yours with a extra switch to shut them off when I want
    NewImprovedRon likes this.
  9. Feb 25, 2018 at 3:43 PM
    #69
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    2015 Platinum Crewmax
    D.A.P. Tune Bilstien 6112/5160 33x12.50xr20 Toyo Open Country M/T 20x9 Fuel Coupler TRD Exhaust
    Not sure what is going on with mine but I keep blowing the fog fuse everytime turn the truck on20180225_184055.jpg 20180225_184101.jpg
  10. Feb 25, 2018 at 6:28 PM
    #70
    xtyfighterx
    Ty
    North Idaho
    What other wire is grounded there
  11. Feb 25, 2018 at 6:35 PM
    #71
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    That is to my LED strip that i have installed in my hood bulge. I have tried a couple diffent places for the ground still blows the fuse.
  12. Feb 25, 2018 at 11:25 PM
    #72
    xtyfighterx
    Ty
    North Idaho
    You made sure that it’s the correct relay? Might be in a different location on higher models.
  13. Feb 25, 2018 at 11:26 PM
    #73
    xtyfighterx
    Ty
    North Idaho
    Is the relay all the way seated?
  14. Feb 25, 2018 at 11:30 PM
    #74
    xtyfighterx
    Ty
    North Idaho
    Might just be your pic but looking at mine it’s seated closer to the other relay Almost no gap between them and you have a slight gap check to make sure it’s in the correct position and it’s the correct relay. Almost make sure there is no metal to metal contact with your bent spade.
    Make sure your connectors and also connected good.
    Possible the relay is damaged look at the Bent spade carefully. Disconnect your wire and bend it back see if your fogs work like stock.
  15. Feb 26, 2018 at 10:13 AM
    #75
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    It is the correct relay. I think the relay is bad. Unable to get the fogs to work when i plug in back in I am going to get a new one from the dealership today.
    xtyfighterx and NewImprovedRon like this.
  16. Feb 28, 2018 at 8:33 AM
    #76
    xtyfighterx
    Ty
    North Idaho
    Let us know sounds like a bad relay remember to bend that print very gently and carefully
  17. Feb 28, 2018 at 9:09 AM
    #77
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    I knew I was shit when it came to electrical issues but this is redic. Haha. So I bought a new relay.. Plugged it in and all is well with fogs.. I then go through my little cable making sure all my connectors are snug and correct. Slowly bend the prong on the relay hook everything up. Run the other side to is own ground and blam fuse blown. Disconnect everything and plug the relay back in and no fogs. Son of a . I ordered two more relays off ebay and they will be here today. Might just say F it and just run stock
    #77
  18. Feb 28, 2018 at 9:38 AM
    #78
    itsdchz
    itsdchz 50statesoverland
    Clovis, CA
    2018 SR5 CM Cement 4x4
    Icon, UCAs, Method, SSO, KB VOODOO, Skids and Sliders
    Wondering if the switch that controls your LED hood bulge light is wired incorrectly and causing the fog mod to blow. I would dedicate a ground to the fog light mod, just to be safe when testing...
    #78
  19. Feb 28, 2018 at 11:40 AM
    #79
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    Well looks like I have another issue now. Plugged the new relay in and no workie.. I will investigate my light strip in my bulge but it was not an issue prior to trying this mod.
  20. Feb 28, 2018 at 2:44 PM
    #80
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    Thanks for all the help. Looks like it was my LED fog lights that were the issue. It was a polarity issue with the drivers side bulb. So 3 relays and 12 fuses later got them to work. 20180228_172757.jpg 20180228_174055.jpg
    xtyfighterx likes this.
  21. Feb 28, 2018 at 7:43 PM
    #81
    xtyfighterx
    Ty
    North Idaho
    Looks good
    AK-in-MI likes this.
  22. May 23, 2018 at 2:12 PM
    #82
    nj636
    nj636 New Member
    NJ
    2017 Super White TRD
    If anyone can post the wiring schematic for headlight/fog light switch I will figure out how to make a true anytime fog light with the factory fog light switch.
  23. May 23, 2018 at 3:15 PM
    #83
    nj636
    nj636 New Member
    NJ
    Ok guys so unfortunately this cannot be done like the Tacoma mod, at least not as easily. It would require cutting and re-landing wires (like the other mod that is currently written)
  24. Jun 15, 2018 at 2:35 PM
    #84
    EN2TUNDRA
    EN2TUNDRA NOT SO New Member!
    North TX
    2021 Tundra TRD PRO Lunar Rock
    I was so excited to find this thread and BAM, when I got to the end, I find out that its not possible. I was really looking forward to having a switch somewhere other than the stalk for the fog lights. I'm used to clicking fog lights on and off when letting people in when they want to get into my lane but with the 2018 switch on the stalk, it's hard to do without looking down.
