Fog light mod similar to Tacoma relay
Discussion in 'Lighting' started by bj46-taco-tundra, Aug 21, 2016.
  1. Dec 12, 2016 at 8:08 AM
    650h1
    650h1 New Member
    2013 Rock Warrior C/M
    I guess I follow this thread so someone who had tried it could tell us what happened... no one yet.
  2. Apr 14, 2017 at 7:34 AM
    1st2014TSS
    1st2014TSS New Member
    Chuck
    New Jersey
    2014 Black CM 4X4 TSS 5.7
    So I tried the fog light mod with the wires behind the side panel and it works. I do have an issue with it because my fog lights somehow come on by themselves hours after I've turned my truck off. Has this happened to anyone else? I just had to jump start my truck because the lights were on for an undetermined amount of time. Any help would be appreciated.
  3. Dec 14, 2017 at 7:34 AM
    dsimonl
    dsimonl New Member
    2017 Tundra DC Limited MGM
    Amp Research Powersteps and Bedstep, 2018 LED headlights, LineX Platinum, Baja Designs fog lights, Driver side grab handle, SwingCase
    Reviving this thread. Seems a bent relay pin in the engine compartment is far more elegant than depinning, heat shrinking and jumpering small wires under the dash.
  4. Dec 14, 2017 at 8:01 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    So who tried this?
  5. Dec 14, 2017 at 9:59 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    Just saw his post. But im not a fan of not being able to turn off the fogs when ever i want. So ill just stick to cuttinf the wires lol
    NewImprovedRon likes this.
  6. Dec 15, 2017 at 12:40 PM
    myk1013
    myk1013 New Member
    Myk
    2017 CM * MGM * TRD
    Saw your post on the other fog light mod thread, did you ever figure out which PDF to follow? The title on PDF is for early model Tundras (2008-2009?)
  7. Dec 15, 2017 at 7:13 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    I havnt done it yet. Im going to use the 1 that says eddie. @BlueBottle used that one and is working on his 16
  8. Dec 16, 2017 at 5:45 AM
    myk1013
    myk1013 New Member
    Myk
    2017 CM * MGM * TRD
    Thanks. Just making sure, I don't want any surprises once I start tearing the dash apart. Pls keep me updated on how it goes.
  9. Dec 18, 2017 at 8:40 PM
    Tundra4us
    Tundra4us New Member
    "D"
    I have a 2016 and I just did the one that says "design by eddie". Works perfectly! Careful as they are some thin wires. Why is this not a stock function....
    650h1 likes this.
  10. Dec 23, 2017 at 8:27 PM
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    2015 Platinum Crewmax
    D.A.P. Tune Bilstien 6112/5160 33x12.50xr20 Toyo Open Country M/T 20x9 Fuel Coupler TRD Exhaust
    Where is this design by eddie mod?
  11. Dec 23, 2017 at 9:27 PM
    Tundra4us
    "D"
    You can Google it, I saw it on a youtube video. Also check out Bluebottles build, look at post 374, it shows the two wires at the two locations that need to get cut, and add jumper.
  12. Dec 23, 2017 at 9:55 PM
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    I have looked at the post where you cut and add a jumper but I don't end to do any of that.. I hope this will work for the 14 and up.
    https://youtu.be/-kfzNGUAs-A
  13. Dec 24, 2017 at 8:55 AM
    Tundra4us
    "D"
    Not sure about this , as he states its for 2nd Gen. Look up 3rd Gen. "anytime fog light mod"....
  14. Dec 24, 2017 at 9:02 AM
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    I understand that it is for a 2nd.. I am seeing it anyone was able to get this to work on a 3rd gen. All the anytime fog mods i have seen you have to tear apart under the dash and cut and spice or pull wires out of pins and run jumpers.
  15. Dec 24, 2017 at 9:10 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    Only problem with the relay mod is that u cant controll fog lights anymore. They will be on everytime u turn on the truck. Of ur fine with that, then ur good to go.
  16. Dec 26, 2017 at 6:27 AM
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    Ok thanks.. Might jump into the full mod then.
  17. Jan 5, 2018 at 7:53 AM
    dsimonl
    dsimonl New Member
    Can someone post a schematic of the fog circuit? I still believe there should be a way to get this 'Tacoma' mod to work in a similar way on a Tundra. I found a schematic for an '07, but nothing newer.
  18. Jan 15, 2018 at 5:56 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Anyone try this yet? Fuck it I’m about to give it a whirl
  19. Jan 15, 2018 at 6:03 AM
    #49
    xtyfighterx
    Ty
    North Idaho
    Guy in the comments on this video said he did this to his 2014 but didn’t add a toggle
  20. Jan 15, 2018 at 6:31 AM
    #50
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Hhhhmmmmmm
  21. Jan 15, 2018 at 9:40 AM
    #51
    xtyfighterx
    Ty
    North Idaho
    I confirmed it works bottom left prong on the fog light relay bend it attach a spade and run it to a good ground source. Fog lights come on with parking lights and headlights as well as the brights. You just loose the fog light switch. Everything turns on automotcilly with parking lights or headlights. Which is fine because I always have fog lights on.m
    If you want to turn the fogs off at all you would have to turn all lights off or run the ground wire to a separate aftermarket switch.
  22. Jan 15, 2018 at 10:13 AM
    #52
    xtyfighterx
    Ty
    North Idaho
    Mod seriously took 5 mins. If anyone needs help or more info let me know
  23. Jan 15, 2018 at 9:18 PM
    #53
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    How about a pic of the relay to see exactly which prong.
    Edit: never mind, I watched the video and saw how the tabs were laid out.
  24. Jan 16, 2018 at 8:05 AM
    #54
    xtyfighterx
    Ty
    North Idaho
    When you pull the relay it’s the bottom left prong. When you plug it back in your wire should be coming out the right side. I can take some pics if you guys want.
    I may do a quick write up on it to
  25. Jan 16, 2018 at 9:18 AM
    #55
    xtyfighterx
    Ty
    North Idaho
    Looking at the fuse box
    Locate the foglight relay
    Pull the relay and looking at it from this angle the bottom left prong is the one u want bend it slowly with pliers to a 90 deg and connect a female spade to it with about 12in a wire.
    Plug your relay back in and run the ground wire to a good grounding point cut the wire to proper length and connect using the proper connector(which I need to add to mine I couldn’t find any in my shop).
    Install your fuse box cap and test your lights. The fogs no longer are controlled by the fog light switch. They will be controlled by your main light switch. Fogs with come on with the parking lights, headlights, and hi beams. Only way to shut them off will be to turn off all lights or wire in an aftermarket toggle/rocker switch.
    Posting this in the DIY section
    Berdine, Les7311 and NewImprovedRon like this.
  26. Jan 29, 2018 at 2:57 PM
    #56
    Les7311
    did you use a rocker / aftermarket switch of the sort, or all controlled by your headlight-stalk?
  27. Jan 29, 2018 at 3:10 PM
    #57
    xtyfighterx
    Ty
    North Idaho
    All controlled by the headlight stalk. The only time I wanted them off was when I had park lights off. The guy in the video used a switch it should be pretty simple. Let us know what u do.
  28. Jan 29, 2018 at 3:24 PM
    #58
    Les7311
    done in 5 minutes and just like illustrated in Post 59...................2nd Gen
    Stalk controls everything.........
    great find and easies mod...
    xtyfighterx likes this.
  29. Jan 29, 2018 at 3:55 PM
    #59
    xtyfighterx
    Ty
    North Idaho
    Right on!
    Les7311[QUOTED] likes this.
  30. Feb 2, 2018 at 5:28 PM
    #60
    Les7311
    The only Con with this set up - grounding relay to frame and use stalk to control lights:
    fog lights comes on even if you want to use only your park lights
    Hhhhmmmm!!!!
