Fog Light Install
Discussion in '1st Gen Tundras (2000-2006)' started by Titan4299, May 9, 2020.
  1. Jun 13, 2021 at 7:23 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I’ve been trying to hunt one of those down, but they’re always gone at junkyards
  2. Nov 1, 2021 at 8:58 PM
    CmdrDaniels
    CmdrDaniels Abides..
    2003 AC 4x4 SR5
    Hope some of you are still following this thread...
    I have a 2003, that came without fog lamps (empty plastic holes in the bumper) but the wiring harness seems to be there. I've ordered the lamp pods, I've ordered the relay ... but that switch. Ouch. To replace the turn signal stalk with the version that has the fog lamp switch will cost $285 on Amazon. Not worth it to me. I'd be happy to just have the fog lamps on whenever the low beams are on.
    Any ideas on how I could wire this up, with no fog lamp switch?
  3. Nov 1, 2021 at 9:00 PM
    empty_lord
    05 rollover special
    the switch can be had used for MUCH cheaper. easiest way. otherwise your looking at some wiring.
  4. Nov 2, 2021 at 5:59 AM
    lowell66dart
    lowell66dart New Member
    lowell
    South Louisiana
    2001 Tundra 4WD
    Rough Country level, RAS rear springs, Magnaflow, custom front bumper
    I want to install foglights also on my 2001. I have the spots on the dash for the switch. Did a quick search and it looks like that switch is now ~$60. Best price I have found on the lights with brackets is ~$100 and I may need a relay.
  5. Nov 2, 2021 at 7:32 AM
  6. Nov 2, 2021 at 8:08 AM
    Richid
    Richid New Member
    Keep an eye on CL and FB - I found a guy getting ready to junk one that I took the relay and switch out of it.
    He pulled the bumper and destroyed the fog light mounts - kind of wished he waited.
  7. Nov 2, 2021 at 9:58 AM
    CmdrDaniels
    2003 AC 4x4 SR5
    OK, thanks. This is probably what I'll try, if I can't find a used switch.
    NewImprovedRon likes this.
  8. Nov 2, 2021 at 1:48 PM
    lowell66dart
    lowell
    South Louisiana
    2001 Tundra 4WD
    My 2001 needs to be oval.
  9. May 23, 2022 at 4:30 PM
    Vallejo206
    Vallejo206 New Member
    Rob
    Everett, WA
    02 SR5 V6 AWD
    I’ve been looking for that oval switch forever. I have a 2002 AC. The push button switch has been discontinued from Toyota. I ordered one from a Toyota dealer and they cancelled my order a day later.
    Anyone know of a work around or if I can cut my OEM wiring harness and wire up an aftermarket switch to work with the existing wires. I already have the fogs mounted in the steel bumper just no button to turn them on. Thanks
  10. May 23, 2022 at 4:50 PM
    Best bet is probably to hit some junkyards, honestly.
    Vallejo206 likes this.
  11. Jul 3, 2023 at 11:06 AM
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    02 SR5 RC Desert Sand- ARB'd 4x4
    BOSS head Unit, Track Rack, Tint. MT Baja Legend EXP 16x9, Pro-Comp 69, Icon Titanium Rebound 17x8. Cant decide on Lift. ARB Rear. Bash Fab Sliders.
    Just wire up a three way switch. Little dremel work and it looks good.
  12. Jul 3, 2023 at 11:06 AM
    BluegrapeVr6
    J
    Unlusd having illuminated gauge is super inportant.
  13. Jul 3, 2023 at 4:00 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    The Chinesium fogs I went with this last time included a wiring harness and an oval switch for the dash. I wired it up on my bench when I received the parts and the switch is lit but its very dim. Meh. As far as the fogs themselves, I hate the way the bulb is held on with the 3 screws non sense. I bought mini projector bulbs to put in them but because of how the bulb is clocked when sitting in the bowl, the bulbs were way out of whack. I then said effit, and baked them open and threw some Chinesium bi-led projectors in them but I haven't messed with them since.
