Fob not working
Discussion in '3rd Gen Tundras (2022+)' started by 22whatwedo, Jan 12, 2025.
  1. Jan 12, 2025 at 8:05 PM
    22whatwedo
    22whatwedo [OP] New Member
    The Open Road
    22 SR5 TRD OR Army Green
    My wife’s fob battery ran out - now she hardly ever drives the truck and it’s unclear how long it was dead. I changed the battery out. It doesn’t work. Took the battery out, checked it, charge is good, also checked the old and it was dead. Put it back together, nothing.
    Any ideas? I was thinking maybe it needed reprogrammed?
  2. Jan 12, 2025 at 8:11 PM
    SR72
    SR72 New Member
    Devin
    2025 Tundra TRD Rally Ice Cap White
    OEM tonneau cover, door edge guards, all-weather mats and spray on bed liner.
    Try holding it up to the start button when you start it up, maybe it will reprogram it
  3. Jan 12, 2025 at 8:13 PM
    22whatwedo
    The Open Road
    I’ll give that a try tomorrow
  4. Jan 12, 2025 at 8:26 PM
    DRP
    DRP Old Member
    Dave
    Is it a Duracell battery with the sour coating? I've had a couple of devices they won't work in until I rinse off the coating.
  5. Jan 13, 2025 at 1:50 AM
    GREENPUS
    GREENPUS New Member
    Scott
    2024 Black Tundra Limited TRD Off-Road
    That’s what I was going to suggest too. I use rubbing alcohol. I’ve noticed my BMW X6 fob is really sensitive to that coating
  6. Jan 13, 2025 at 5:21 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I hope you figure this out. Keep us posted.
    FYI, if the truck is rarely driven, you can turn the FOB off to conserve battery. I've forgotten what the button push sequence is, but that should be a easy search.
    Tundrastruck91 likes this.
  7. Jan 13, 2025 at 6:32 AM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    my oem battery went dead just a few weeks ago - 18 months after initial use. Replaced it with a Duracell and it works fine. Maybe you put it in wrong side up? Or the plastic shield cover on the battery contact side did not get removed before you installed it.
  8. Jan 13, 2025 at 6:40 AM
    Brums
    Brums New Member
    Bethel, OH
    22 Tundra DC TRD Sport
    Press and hold lock , then unlock 2x . will turn fob off then any button press will turn back on
  9. Jan 13, 2025 at 7:56 PM
    22whatwedo
    The Open Road
    Ok I took the fob in question to the truck, with my working fob in the house. I pressed the start button, it asked to put the fob near the button, I did,it started. However, I tried again from scratch, on a second start I had to repeat the sequence. I also noticed her Fob was not emitting that little red light. So I know it works, and I suspect it ran out of batteries a long time ago and the internal memory is erased. I am going to read the manual about programming/pairing it up and we will see how that goes. Thank you @SR72 for the suggestion.
  10. Jan 13, 2025 at 8:42 PM
    Hella Krusty
    Hella Krusty New Member
    Just change ALL your FOB batteries every birthday and BOOM, problem goes away
