Foam Invasion...insulation-home insulation
Discussion in 'Home Improvement' started by Patriot, Aug 22, 2017.
  1. Aug 22, 2017 at 12:50 PM
    Patriot
    Patriot [OP] Member
    Western NC, “Boondocks”
    CBS did a clip on foam insulation in residential homes. We went with the standard blown in Fiberglass in the attic and the rolls in the walls. Also rolls of sound proofing. This clip is worth a look, if your in the process of building a new home. I had no idea there can be issues.
    It's important to have it installed correctly.
    https://m.youtube.com/watch?v=0Hh5MYv7lWc
    SouthBoundSteve and Newm like this.
  2. Aug 22, 2017 at 2:32 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Yeah I saw this before I built my house. Went with the rolls in the walls and blown in in the attic.
  3. Aug 22, 2017 at 3:07 PM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Lots of fire companies won't touch a sprayed house around here because they up in flames
    Instantly
    SouthBoundSteve likes this.
  4. Aug 22, 2017 at 3:13 PM
    TheBeast The Beach
    yep when we did our renov our contractor advised against going with it.
    SouthBoundSteve and Patriot[OP] like this.
  5. Aug 22, 2017 at 4:04 PM
    Patriot
    Patriot [OP] Member
    You bet Steve, I thought of you when I saw this, I think you mentioned something about foam. Knowledge is power. Sounds like you have it under control.:thumbsup:
  6. Aug 22, 2017 at 4:12 PM
    Patriot
    Patriot [OP] Member
  7. Aug 22, 2017 at 4:29 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    FYI
    You can get fire retardant added, it costs.
    Also, both open cell and closed cell are available. Open cell absorbs water, closed cell won't. Closed cell costs about x4 as much.
  8. Aug 22, 2017 at 4:32 PM
    Patriot
    Patriot [OP] Member
    It should be included or mandatory if a home burns up that fast...wow.
  9. Aug 22, 2017 at 4:40 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Some think fire suppression sprinklers should be mandatory.
  10. Aug 22, 2017 at 4:49 PM
    joem1cha3l
    Albany, NY
    Im in the trades....this is coming....
    Pudge likes this.
  11. Aug 22, 2017 at 4:56 PM
    joem1cha3l
    Albany, NY
    In my opinion dense packed cellulose is the best way to go. The R values after a certain point are negligible anyway. You can dense pack cellulose to a damn high R-Value. Its also made from recycled newspapers (and such) and will not off-gas.
    My next house I will use dense packed cellulose in the walls for sure. And I'll load up the attic with loose fill.
  12. Aug 22, 2017 at 4:58 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    UBC and NBC required, not in at least 30 years.
    Local municipal codes, yes, already mandated in some California counties.
  13. Aug 22, 2017 at 4:58 PM
    joem1cha3l
    Albany, NY
    I think with engineered lumber being used more and more, along with spray foam - its a good idea.
    However, I think this is more of a money making scheme than anything else. I think thats the major driving factor.
  14. Aug 22, 2017 at 5:01 PM
    Patriot
    Patriot [OP] Member
    Yep sprinklers are high $$$, I don't see it happening anytime soon. More fire retardant building materials maybe.
  15. Aug 22, 2017 at 5:04 PM
    joem1cha3l
    Albany, NY
    Fire protection is now code (and enforced) between the basement and first floor in Massachusetts. So the more fire retardant materials is beginning for sure.
  16. Aug 22, 2017 at 5:04 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I believe the first residential sprinkler system was installed in the '20's, almost 90 years ago. Pretty sure not one life has been lost to fire in a residence that had an operational fire sprinkler system in place.
  17. Aug 22, 2017 at 5:05 PM
    n2deep
    n2deep Pavement Princess
    I built a house with spray in foam and can say it makes a huge deal in the power bill. I had a 3800 square foot home in Vegas area and never had a power bill over $150 with an all electric home including two electric tankless water heaters and Two AC units.
  18. Aug 22, 2017 at 5:07 PM
    joem1cha3l
    Albany, NY
    I don't think anyone (not me anyway) would question the effectiveness of the product.
    *disclaimer* - I did not have 20 minutes to watch that video lol
  19. Apr 18, 2018 at 6:40 AM
    Ps3udonymous
    Ps3udonymous Who is the smart ass that changed the title?
    Job security for me then
