FN BFD picture thread.
Discussion in 'Wheels & Tires' started by Big J, Mar 4, 2018.
  1. May 21, 2018 at 5:07 PM
    Less than 2weeks. Why don't you pre order! Well...maybe more than 2 weeks
  2. May 21, 2018 at 5:11 PM
    I first saw the FNs on ToyTec employees FJs and ToyTec owners Tundra. Had to have them. T-rex arranged sale. I bought all "6" BFDs off that ToyTec Tundra.SCORE!!!!
  3. Jun 7, 2018 at 8:38 AM
    JWoody
    JWoody New Member
    Does anyone have a pic of graphite FN BFD on a cement crewmax? Thinking the combo would look cool, but would love to see a pic ahead of ordering.....
  4. Jun 27, 2018 at 5:34 PM
    Wintyfresh
    Wintyfresh New Member
    Ramona, CA
    17 Inferno 4x4 DC LB SR5
    285-65-18s on Bronze BFDs, 2" lifted 6112s up front and 5160s in the rear.
  5. Jun 27, 2018 at 5:35 PM
    fundra_goes_west
    fundra_goes_west I’m just a guy with a girl
    Evan
    2022 SQ8
    That’s exactly what I want on my black beauty!
  6. Jun 27, 2018 at 5:35 PM
    fundra_goes_west
    Evan
    2022 SQ8
    Rubbing? Trimming needed?
  7. Jun 27, 2018 at 5:37 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
  8. Jun 27, 2018 at 5:37 PM
    Wintyfresh
    Ramona, CA
    Rubbed a tiny bit at stock height (and I had to remove the mudflaps in front of the tires), zero rubbing with the lift.
    Big J[OP] likes this.
  9. Jun 27, 2018 at 6:26 PM
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    3” front 1.5” rear 295/70R rub in reverse. Setting up CMC
  10. Jun 27, 2018 at 8:20 PM
    The FN BFD's have the sweet spot offset. Only made for our tundras. Only limitation is tire size....
    zcarpenter92 likes this.
  11. Jun 28, 2018 at 3:44 AM
    fundra_goes_west
    Evan
    2022 SQ8
    What do you mean? If I do the 5100’s on the middle setting in the front based on what I know most I could squeeze would be 285/70’s right? (Probably have to take off the mud flap and push the liner forward I think) Thank you so much in advance!
  12. Jun 28, 2018 at 5:46 AM
    285/70/18 should be a good fit. I had to remove mud flap and push liner forward when I went up to 295/70/18
  13. Jul 4, 2018 at 5:42 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    NOT BFD's but close!
    BFD to make it legit
  14. Jul 4, 2018 at 5:45 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I've got an FN BFD but I think I'd be banned if I shared a pic here...
    Black Wolf and zcarpenter92 like this.
  15. Jul 4, 2018 at 5:46 PM
    ninjajay
    Spoolston, TX
    what center caps work with the BFDs? Ambit didn't supply me with any
  16. Jul 4, 2018 at 6:00 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    295/70’s fit just fine on mine, once I adjust the driver side coilover I’ll have no rubbing. All I did was remove mud flaps on front and rear, and pushed the liner forward.
    That’s a good question, my center caps came with the wheels.
  17. Jul 4, 2018 at 6:44 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Such a nice looking combo Matt, you still liking those tires? I am especially curious about the wet traction.
  18. Jul 5, 2018 at 5:15 AM
    The ST Maxx have excellent wet traction and do quite well in loose rock too. Thread design has two vertical spaces near the outer lugs that allow for water dispersion. Minimal hydroplaning for such a large tire. Quite pleased.
  19. Jul 5, 2018 at 5:22 AM
    #49
    Mine came with center caps. I read that FN was going to discontinue providing center caps due to so many folks not using them and wanted a cleaner looking non tapped rim. Like Zach said his new FNs still came with a set of caps. Not sure what's up with that now. I personally don't use them.
  20. Aug 20, 2018 at 1:32 AM
    #50
    Noname415
    Noname415 Old slow and broke
    2012 white 3in lvl and 305s
    Bmc and skid plate trim
    • I'm looking at bfd's because they are a fouth of the cost of the real te37's can anyone tell me do they tuck or do they stick out and if so by how much
  21. Aug 20, 2018 at 11:13 AM
    #51
    Big J
    Big J [OP] New Member
    2020 4x4 crewmax
    Wanted to ask how much inside clearance did you have with the 12.5 wides? Was thinking of going a little wider if there is room. :D
  22. Aug 20, 2018 at 11:39 AM
    #52
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    clearance is tight. you can get away with pulling caster forward. plastics and all that stuff will need attention.
  23. Aug 20, 2018 at 1:35 PM
    #53
    Big J
    2020 4x4 crewmax
    Ah so probably can’t get a 13” wide on there? Was thinking of some 325mm width.
    dcsleeper408 likes this.
  24. Aug 20, 2018 at 1:43 PM
    #54
    zcarpenter92
    Zach
    NE Colorado
    In sig
    I think that’s be pushing it, at minimum. I know a few guys on here have tried 325’s and they rubbed the frame.
  25. Aug 20, 2018 at 1:47 PM
    #55
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    I wouldn't recommend unless you are up for the extra work.
    Big J[QUOTED][OP] likes this.
  26. Aug 20, 2018 at 3:17 PM
    #56
    Big J
    2020 4x4 crewmax
    Thanks! Just curios and trying to plan head. :thumbsup:
  27. Oct 5, 2018 at 1:29 PM
    #57
    damonhimself
    damonhimself New Member
    Damon
    2018 Tundra TRD Off Road
    What are you guys using for lug nuts with these wheels?
  28. Oct 5, 2018 at 2:21 PM
    #58
    zcarpenter92
    Zach
    NE Colorado
    In sig
    The ones that came with the wheels. I also bought a set of locking ones that I haven’t put on yet.
  29. Oct 5, 2018 at 8:59 PM
    #59
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Nice! Got any more pics of that Inferno red and bronze color combo?
  30. Mar 1, 2019 at 12:02 PM
    #60
    Kurdt
    Kurdt New Member
    Austin TX
    2019 Cement CrewMax TRD OR
    I wondering the same thing about these wheels. I really like them but since they are only offered at a +12 offset, I'm worried about them sticking out too much. I do not have flares, so would these stick out an inch or more? Anyone got pics looking straight on from the front?
