Fluid Film worth it or just a gooey mess?
Discussion in 'General Tundra Discussion' started by plumber802, Sep 11, 2018.
  1. Sep 12, 2018 at 2:44 PM
    Can Amsoil be sprayed on anything also?
  2. Sep 12, 2018 at 2:45 PM
    tacomawv
    tacomawv New Member
    Richard
    I may try the amsoil. I need it on my Jeep. I only drive it in the snow. It is already rusty.
  3. Sep 12, 2018 at 2:47 PM
    tacomawv
    tacomawv New Member
    Richard
    I need to know this too.
  4. Sep 12, 2018 at 2:48 PM
    Ditto.
    Not sure which one to go with.
  5. Sep 12, 2018 at 3:25 PM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    Ive used corrosion x and or acf 50, but i have it readily available to me.
    I wouldnt wash the under carriage with simple green unless you know for a fact that you are getting it 100% off when done.
    Years ago the military stopped using regular simple green because it was found to be very corrosive to aircraft. Simple green then made an aviation specific version that works well for what it does.
  6. Sep 12, 2018 at 3:28 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    Just sprayed my rig 2 weeks ago with fluid film, ended up using almost 3 cans. I was spraying that shit the way a stripper applies perfume.:D if only that stuff smelled as good.
    Dunchues and Pudge like this.
  7. Sep 12, 2018 at 5:18 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    I'll have to look into the Amsoil again. I prefer it over the CRC.
  8. Sep 12, 2018 at 5:24 PM
    lewi3069
    lewi3069 New Member
    2017 Crew Max 4x4 Sunset Bronze
    I'm going to apply Amsoil to my tundra in a few weeks, when I do my pre-winter wash and wax. Just picked up 6 cans of HDMP for about $9 ea.
    ZPMAN likes this.
  9. Sep 12, 2018 at 6:26 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    My plan will be to powerwash underneath really well and let it dry a few days then get under there and spray away. I'll also do fenderwells, engine bay walls, the underside of my steps, rear bumper and hitch, all suspension components, and maybe inside the rockets and lower parts of doors. Will likely be done yearly in the fall. Possibly mid summer if I plan a beach trip.
  10. Sep 13, 2018 at 11:32 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    Anything? No, avoid glass, your brakes, and your shock shafts. Other than that, it's pretty versatile as an undercoating. It dries as a lightly tacky wax-like coating and is difficult to remove without acetone and some elbow grease. Same goes for overspray on your skin, use Dawn and scrub it. That's why I say use some PPE.
  11. Sep 13, 2018 at 11:42 AM
    Thanks
  12. Sep 13, 2018 at 1:23 PM
    Warreng
    Warreng New Member
    I like krown better. In my mind the thinner Krown gets in more places then the snotty, smelly fluid film. Also doubles as generAl purpose lube.
  13. Sep 13, 2018 at 2:34 PM
    nowayout
    nowayout New Member
    NY
    17 CM
    I sprayed the Amsoil and wasn't careful about where I spayed except for the brakes and and some of the hoses that are easily avoided.
  14. Sep 13, 2018 at 4:54 PM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    Why not the shock shafts? I was planning to use ff or maybe ams and would like to coat my coil overs an rear shocks as well. Curious..
  15. Sep 13, 2018 at 4:59 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    FF works good for corrosion protection in general but just be sure to not get it in/on your heim joints or uniballs.
    Tundradrenalin likes this.
  16. Sep 14, 2018 at 7:14 AM
    Tundradrenalin
    Virginia Beach, VA
    It's not clear, it's an orange color. Amsoil initially launched this product as a motorcylce chain lube. They've since redirected the marketing to an undercoating and now they have a different line for chain lube. I avoid areas that are meant to be clean and smooth, like shock shafts, heims, and unis. Those items are meant to be clean and smooth; the shocks have shaft wipers on them and a tacky film may hinder the wiper performance.
    ZPMAN likes this.
