Fluid change checklist?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dukhnt, Jul 30, 2023.
  1. Jul 30, 2023 at 11:08 AM
    Dukhnt
    Dukhnt [OP] New Member
    I've done some searching but can't find a complete list.
    Has anyone ever posted a complete parts list for needed or possibly needed items for oil / tran / dif fluid changes?
    I get there is as many opinions as posts when it comes to fluids, but I was just wondering about washers, number of qts needed, small things you might forget.
  2. Jul 30, 2023 at 11:16 AM
    2mchfun
  3. Jul 30, 2023 at 11:20 AM
    2mchfun
  4. Aug 3, 2023 at 8:48 AM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    :popcorn:
    It would be really nice if we had a pinned spreadsheet that listed parts/volumes required for standard fluid changes. Maybe a few related install videos/any documentation we could scrounge up as well.
    I've been meaning to get around to making one myself, but I'm not due to start for a few months, so it hasn't been a priority.
    AggiePhil, Gene_in_FL and 2mchfun like this.
  5. Aug 3, 2023 at 8:00 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    This is a list I made for myself I can share
    Brakes
    Front Rotors 43512-0C020
    Front Pads 04465-02440
    Rear Rotors 42431-0C011
    Rear Pads 04466-02340
    Engine Air Filter
    17801-0P100
    Oil change
    6 quarts low mark
    7 quarts almost in the middle
    8 quarts to the full mark
    After running need to add .5 to get back to full mark so capacity with oil and filter is 8.5qts
    Cabin air filter 87139-07020
    Rear differential 75w90 4qts
    Front differential 75w90 2qts
    Transfer case 75w 08885-81080 2 cans
    ATF Drain and Fill 4qts or 4.5qts with cooler
    Fluid - 00289ATFWS
    Gasket 3516834020
    Filter 3533060070
    Filter O-Ring 9030131014
    Brake Fluid 2 qts DOT3
    Power steering 00718-ATF00 2qts
    Coolant 00272-SLLC2 50.50
    C0009-00120
    Spark plugs 90919-01191 Denso SK20HR11
    300BLK, GaTundra79, ajkamel and 15 others like this.
  6. Aug 6, 2023 at 7:04 AM
    ohiowa
    ohiowa Have you tried turning it off and back on again?
    Ohio
    2021 SR5 CM Cavalry Blue
    This is now bookmarked!
    Joe333x[QUOTED] and Gene_in_FL like this.
