Flowmaster on a 3.4L V6?
Discussion in '1st Gen Tundras (2000-2006)' started by jsvwx, Jan 19, 2025.
  1. Jan 21, 2025 at 6:14 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    I mean, a k-series would be more reliable and create better power numbers.
    And it has 2 less cylinders LOL
  2. Jan 21, 2025 at 6:19 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Mechanical injection and low peak torque rpm would be what i’m looking for.
  3. Jan 21, 2025 at 6:31 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I happen to agree with this :crapstorm:
    1lowlife likes this.
  4. Jan 21, 2025 at 6:57 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    189*
  5. Jan 21, 2025 at 7:05 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Uh.... Ok bro
  6. Jan 21, 2025 at 7:42 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    For inline or v6 engines, stay away from any straight thru designs, such as maganflow. Drone and crappy sound.
    Chambered mufflers do much better on these engines, so yes, 50 Flowmaster will give some deeper tone and gurgle without the rasp and rice sound.
    jsvwx[QUOTED][OP] likes this.
  7. Jan 21, 2025 at 6:02 PM
    Dustbox
    Dustbox New Member
    Southern Utah
    2000 Black AC 4.7l V8 4x4 SR5
    285/75/r16 tires on stock suspension Tubed Bumpers
    When it comes to stock yes honestly. The 2uz is limited to like 7 psi max boost before a skinny weak ass rod breaks. You'd need new rods and to convert to 4 bolt mains before making real power.
    At the point it has a different engine in it, it's not a pure tundra, so I didn't mention it. But that doesn't mean I won't LS swap mine when the time comes ;)
  8. Jan 21, 2025 at 6:47 PM
    FishNinja
    Lee
    06DC2wd
    Yes.
    Dustbox[QUOTED] likes this.
  9. Jan 22, 2025 at 7:10 PM
    jsvwx
    jsvwx [OP] New Member
    New York
    2001 AC SR5 V6 5M 4WD
    The Summit site didn't give my Tundra as an option to pick. I'll search through the forum to see if anyone else with the 3.4L Tundra installed it. Thanks!
  10. Jan 22, 2025 at 7:14 PM
    jsvwx
    New York
    Wow that's impressive! My biggest complaint with this truck is the power, especially with the MT. I feel like I have to get on it to not feel like a pig. Aside from the baffle, what would you recommend next for power improvements without spending thousands right now.
  11. Jan 22, 2025 at 7:17 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    No, it's all pretty much going to be expensive. Most of the power mods require the supercharger first.
    But the URD short throw shifter is easy to install and will make you shift a little faster.
    https://urdusa.com/urd-short-throw-shifter-3-4-liter-5vz-fe-trucks/
    Here's a link to the headers
    https://urdusa.com/?s=5vz+headers
  12. Jan 22, 2025 at 7:22 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Nobody needs to shift faster.
    @jsvwx its a truck, let it do truck things. Take your time, and everything (parts, brakes, gas, tires, etc) will last longer.
    or swap in any v8 and have the coolest 1st gen tundra on earth.
    jsvwx[OP] likes this.
  13. Jan 22, 2025 at 7:24 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Well I liked it on the T100. Also a good opportunity to replace the bushings while you're in there.
  14. Jan 22, 2025 at 7:55 PM
    jsvwx
    New York
    Sorry but no way an automatic V8 is cooler than my MT! I have a V8 Sierra and this Tundra is a toy with that 5 speed. Don't get me wrong, my truck is definitely fun to drive. Just would love to put a little more power into it without going broke!
  15. Jan 22, 2025 at 7:58 PM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    No, i mean stick a v8 in front of that 5speed.
    jsvwx[OP] and 455h0le_dachshund like this.
  16. Jan 22, 2025 at 8:02 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    4.30 gears or if you have bigger tires 4.56 gears would pair well. But it's not a cheap upgrade. 4.88 of you have 33's and up. The install is the expensive part. And with 4x4 you'll pay double for the parts and the install.
  17. Jan 23, 2025 at 4:57 AM
    jsvwx
    New York
    Now we're on the same page! Yeah that would've been definitely better!
  18. Jan 23, 2025 at 5:14 AM
    jsvwx
    New York
    Maybe you would know what exactly is in my truck. I've tried searching it online and it says I have either the 4.30s or 4.56s. My door code reads A04A/R150F.
  19. Jan 23, 2025 at 5:23 AM
    #49
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    How to install a 99 Lexus LS400 obtained V8. And how to figure out your trucks axle gear ratio.
    455h0le_dachshund likes this.
  20. Jan 23, 2025 at 5:56 AM
    #50
    jsvwx
    New York
    This link and most of the stuff I found online says I have the 4.30s but there are places online that say the 4 in A04A means 4.56. Can I assume it's one of the two?
  21. Jan 23, 2025 at 7:38 AM
    #51
    Johnsonman
    Austin
    Sequoia
    4.30s were typically assigned to 4WDs especially those with Multimode (Limiteds).
  22. Jan 23, 2025 at 7:44 AM
    #52
    What's multi-mode?
    FrenchToasty likes this.
  23. Jan 23, 2025 at 7:51 AM
    #53
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You have 4.10 according to the info I've seen
    2000-2003
    3.91 - V8, 4x4, auto trans
    3.92 - V8, 4x2, auto trans
    4.08 - V6, 4x2, auto trans or manual trans
    4.10 - V6, 4x4, manual trans
    4.30 - V6, 4x4, auto trans
    2004, Regular Cab or Access Cab
    2004, Double Cab
    4.08 - V8, 4x2, auto trans
    4.10 - V8, 4x4, auto trans
    2005-2006
    3.77 - V6, 4x2, auto trans
    4.08 - V6, 4x2, manual trans
  24. Jan 23, 2025 at 8:18 AM
    #54
    Johnsonman
    Austin
    Sequoia
    Feature of the day borrowed from the LC Prado. It allows 2wd - AWD and 4WD. The only downside is to achieve the 3 - they moved the locker from the rear diff to the center diff. So now front to rear axles are locked but each axles wheels still can slip on each other. Does very well in sand ice snow.
    Last the last central Tx icestorm in 2022 - I rode to get my son about 30 miles away whose power went out for a few days. Along they way there are several moderate hills. Saw over a dozen Jeeps stranded and abandoned on roadsides along with the expected minivans - light 2wd trucks but did not expect to see 4wd Jeeps at all. The Runner just breezed thru it like nothing cruising 30 mph LOL.
  25. Jan 23, 2025 at 10:03 AM
    #55
    jsvwx
    New York
    The plot thickens! This is new news to me. Is that information posted somewhere online or in a sticky?
  26. Jan 23, 2025 at 11:24 AM
    #56
    Guessing that’s a feature available in the Seqouia then?
  27. Jan 23, 2025 at 3:56 PM
    #57
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Another tundra forum called Tundra solutions
  28. Jan 23, 2025 at 4:46 PM
    #58
    It’s a :tumbleweed: these days
    jsvwx[OP] and FrenchToasty like this.
