Flow master 40s with cut outs
Discussion in '2nd Gen Tundras (2007-2013)' started by Bgsxrunner, Jun 12, 2019 at 5:44 PM.
  1. Jun 12, 2019 at 5:44 PM
    Bgsxrunner
    Bgsxrunner [OP] New Member
    Tuesday
    New Mexico
    2012 Black Toyota Tundra Crewmax Platinum 5.7 4WD
    Pretty much everything
    Here is my setup with two, single in single out flow master 40s with an H pipe right before them. They both flow to 18” echo chambers that are angled so you can’t see them. Also the secondary cats have been removed 82E58C70-FCE8-4188-8C81-46E54482E6BE.jpg
    There’s the tips here’s the mufflers and cut outs. The cut outs are before the H pipe so you get the straight pipe sound
    Here is a link so you can hear the two options
    https://youtu.be/Ofo07gUmJBY
    ARamirez73, Troynjade and Grey Wolf like this.
  2. Jun 12, 2019 at 8:15 PM
    Troynjade
    Troynjade Beast mode
    Troy
    Wa
    2008 Toyota Tundra
    7" procomp lift, 3" body lift. Amp research powerstep, 22" fuel rims, 38" nitto tires, Custom leather seat covers black with red stiching, alpine inz928 deck, 2x10" subs, 1500 watt alpine amp, 400watt amp for door speakers. Procomp Traction bars, fuel grille, Black headlight housing with 6000k hid, rear airbags, rear and front camera, k&n air intake, 40" light bar. Rear under bumper led light bar. Prodigy trailer brakes. 4.88 revolution gears
    Sounds great, do you notice a little boost in your gas pedal..lol
    Bgsxrunner [OP] likes this.
  3. Jun 12, 2019 at 8:20 PM
    cmiller219
    cmiller219 New Member
    Oahu, HI
    2018 Cement CM Tundra
    pretty cool and good work. The sound isn't for me but credit is given where due. Cool to see people coming up with their own idea and new setups.
    Bgsxrunner [OP] and Grey Wolf like this.
  4. Jun 12, 2019 at 8:57 PM
    Bgsxrunner
    Tuesday
    New Mexico
    Honestly no going through two separate mufflers I think it’s about the same back pressure
  5. Jun 12, 2019 at 8:58 PM
    Bgsxrunner
    Tuesday
    New Mexico
    I appreciate it there’s almost nothing the normal way on this truck
    cmiller219 likes this.
