Floor jack
Discussion in 'Product Reviews' started by TelemarkTumalo, Jun 14, 2020.
  1. Jun 14, 2020 at 8:54 AM
    TelemarkTumalo
    TelemarkTumalo [OP] New Member
    Mark
    Bend, OR
    2020 Tundra TRD Pro Double Cab Army Green
    Driver side grab handle Door sill protectors Falken WildPeak 295/70 R18 X-Pel clear front paint protection 20% front window tint Go Rhino RB20 side steps - Bedliner finish Lock'er Down 1/2 console safe Toyota bed cargo divider Toyota auto tail gate lock
    Not the most sexy of postings. I'm ready to get myself a decent floor jack. I'm doing more of my own maintenance these days and asked one of my neighbors about his floor jack. His is from HF and he swears it hasn't given him any trouble in 5 years, but I'm always skeptical about getting lowest budget item. Especially, when I'm crawling under a 3 ton vehicle. I doubt that I'll need one for lifting more weight than my Tundra, but wondering if any thoughts on this one, or can you recommend another option. https://www.bendpak.com/shop-equipment/floor-jacks/rfj-3tp/
    YardBird and Hondoman like this.
  2. Jun 14, 2020 at 9:04 AM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    I recently bought this one at HF. It came highly reviewed and is one of their more expensive models. I needed the extra height. So far so good. 20200603_191411.jpg
  3. Jun 14, 2020 at 9:50 AM
    TelemarkTumalo
    Mark
    Bend, OR
    Thanks I'll check it out.
    Hondoman and YardBird like this.
  4. Jun 14, 2020 at 9:54 AM
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    +1 for this HF jack. Very good quality. Several of my friends have it and we all swear by it.
  5. Jun 14, 2020 at 9:56 AM
    TheBeast The Beach
    most of them are made in China anyways..doubt there is much difference imo. that Daytona looks nice.
    Hondoman, jc153 and YardBird like this.
  6. Jun 14, 2020 at 10:04 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Here's an ancient HF floor jack that's been to hell and back. Gifted to me by my compadre that abused it by jacking tree stumps out of the ground which warped the frame completely.
    I took it to work and straightened out the frame as best I could ~ to this day only 3 wheels touch the ground when I maneuver it around.
    It still works like a champ in spite of the abuse. I can't help but think the newer HF Daytona floor jack is heads and shoulders above this one in quality and dependability.
    Never get under a vehicle that's supported by a jack of any kind ~ always use good quality jack stands. My needs are very simple ~ if I need another jack I will go to HF to buy a new one.
  7. Jun 14, 2020 at 10:10 AM
    TheBeast The Beach
    I have an old Craftsman pro and a costco low profile one. I tend to use the old craftsman most of the time.
    I also use jack stand and wheel chokes plus the tire that was removed to block the frame in case of jack failure.
    Pinay, Hondoman and YardBird like this.
  8. Jun 14, 2020 at 10:11 AM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    I have the HF low p r o it Jack's up higher than the non low pro. I also use Jack stands, I'm not about to die for my truck
    YeeYeeTundra, Pinay, Hondoman and 2 others like this.
  9. Jun 14, 2020 at 10:12 AM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Yep, even craftsman now. What isn't made in China will cost $$$ and everyone is about saving money.
  10. Jun 14, 2020 at 12:06 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Another Daytona user, I opted for the low profile with long reach. Low enough to get under my car and lifts high enough to get my truck up. Also using Esco jack stands, very good design.
    Pinay, Hondoman and jc153 like this.
  11. Jun 14, 2020 at 12:13 PM
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    I had that exact same orange HF jack years ago, and had some young welders make me a handle for it...worked great, then left it at my wife's grandfathers farm, which got sold 5+ years ago. Great jack!
    Now, I use a 40+ year old Craftsman as my go-to. Have an aluminum CM, but it tends to slowly lower when left in the up position with a load on it.
    Darkness and Hondoman like this.
  12. Jun 14, 2020 at 12:35 PM
    I have 3 aluminum race jacks from Craftsman and 2 from Harbor freight and I believe that the Harbor freight are a little better jack to my surprise. Like someone else said they are all made in China anyways which is a shame.
    TelemarkTumalo[OP] and Hondoman like this.
  13. Jun 14, 2020 at 4:21 PM
    TelemarkTumalo
    Mark
    Bend, OR
    Thanks everybody. I'll chill on my HF bias and keep an open mind.
    Hondoman and Pinay like this.
  14. Jun 14, 2020 at 4:35 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Try bleeding it. My old aluminum jack was doing the same, I cracked the bleeder and pumped a few times and tightened it again, problem solved.
  15. Jun 15, 2020 at 3:39 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    I have an HF jack and an old no name China jack I inherited. Both work fine.
    About your comment on safety and low budget items when crawling under a vehicle. I'm sure you didn't mean that you would be working under a vehicle supported by a jack only, but I wanted to check. Make sure to use a jack stand. Before I did my suspension, I bought the Hein-Werner HHW93506 stands. Very stable, plenty tall enough and the supports are wide enough for the frame to sit inside of.
  16. Jun 15, 2020 at 3:56 PM
    41bigdawg
    41bigdawg Let the BIG DAWG Eat
    Robert
    Tennessee
    2013 Tundra DC 5.7
    Magnum front, Iron Cross rear bumpers, SB Cold air intake and Gibson Metal Mulisha exhaust, Fender flares, Tow mirrors, 18" Outlaw wheels, 12k Smitty X2O winch, Tech 12v auto start, Firestone Air Bags, Pedal Commander, Devil Horns, etc...
    Have 2 HF jacks, lo pro and regular. Never had a problem with either one. Like everyone else spend the $$ on some quality stands and never trust a jack by itself when you are under the truck.
