Flooded Tundra
Discussion in 'General Tundra Discussion' started by Coolhardy, Aug 6, 2017.
  1. Aug 6, 2017 at 8:37 AM
    Coolhardy
    Coolhardy [OP] New Member
    Harris
    2014 black tundra
    Too many to list
    Hello Tundra Pros
    I m thinking of picking up this flooded Tundra from Auction. It's a 2016 what looks like a limited Version to me. The water level was just above the Tundra badge on the side of the truck (shows on the picture). The truck won't start so it is what it is. I haven't looked at it in person (too far for me to get out there) so your guess is as good as mine.
    So what do so what do you guys think? Computer might be fried?? What else can go wrong considering the water level wasn't that high.
    Anyone close to Baton Rouge, LA who can take a look at the truck for me?
    IMG_2816.PNG.jpg IMG_2817.PNG.jpg IMG_2818.PNG.jpg IMG_2819.PNG.jpg IMG_2820.PNG.jpg IMG_2821.PNG.jpg IMG_2822.PNG.jpg IMG_2823.PNG.jpg IMG_2825.PNG.jpg
  2. Aug 6, 2017 at 8:49 AM
    T-Rex266 Tesla Live Crew Staff Member
    Sounds like a lifetime of electrical issues. Pass
  3. Aug 6, 2017 at 9:04 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    How bad is it for the truck to sit on the suspension that way?
  4. Aug 6, 2017 at 9:06 AM
    Tundra_mike89
    Tundra_mike89 New Member
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Toytec boss coilovers Toytec shackles Total chaos uca's Method wheels Nitto ridge grapplers
    Not bad for the suspension. But hard on the disc brakes. The most I'd pay for that piece of crap is 500 bucks. Any more and your getting raped
  5. Aug 6, 2017 at 9:10 AM
    Ragecage92si
    Ragecage92si New Member
    Josh
    17 blue TRD
    7" BDS lift kit,3” body, King 2.0’s, Mammoth Guards, Custom powder coating, Nitro 5.29, D.A.P. Tuned, Coachbuilder shims, Coachbuilder Steering kit, Wether Tech vent visors, and hood protector, spray in bed liner, Bakflip, Fuel wheels, 38” TOYO tires, Bushwacker fender flares, Dirty deeds exhaust , TDK front bumper, Rigid light bar/floods/spots. Husky fronts, Weather Tech rears, ESP under seat storage, PowerX2 battery, Android Tesla unit, AJT chrome delete, Horn Blasters, Custom switch cluster, Interior leds, Revere leds, 19 pro headlights, Rocklights, Custom MAYHEM projector
    Lots of good parts, if price is low enough
    757TUNDRA likes this.
  6. Aug 6, 2017 at 9:40 AM
    big_jarv
    big_jarv New Member
    2021 TRD Pro
    If it was enough for insurance to total it I'd say stay away.
  7. Aug 6, 2017 at 9:59 AM
    TheBeast The Beach
    risky bet..really depends on the price IMO. couple G's maybe
    Are you mechanically inclined ?
  8. Aug 6, 2017 at 10:09 AM
    signalbobby
    signalbobby New Member
    Robert
    AZ
    16 Tundra PRO & 4R PRO
    i wouldnt. the ECU probably got toasted. i wonder if it also got hydro locked which means the engine would be useless. water in the transmission. i really dont know what is useful there...
  9. Aug 6, 2017 at 10:44 AM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    I would totally pass. I see a money pit.
  10. Aug 6, 2017 at 10:49 AM
    TXRailRoadBandit73 TOYOTA,RAILROADER,RÖKNROLLN',BEER,MAX,GEMMA
  11. Aug 6, 2017 at 10:51 AM
    Ryan Mc.
    Ryan Mc. New Member
    Ryan
    Mission Viejo
    2015 Toyota Tundra SR5 Double Cab 5.7L
    Hand made bed divider, bed d-rings
    The water level up above the badge would mean there is no water in the engine or trans. These units are sealed...oil can't come out water can't go in. Water at that level probably reached the starter and just blew a fuse...hence won't start. Probably sitting for a while so a new battery would be in order, as well as an electrical fuse box check of ALL FUSES! The only way water would enter the engine is through the air box, so check the air cleaner and as many pieces you can remove to check for water spots/debris. Water can also enter the exhaust and rust from the inside out as well as damage the catalytic converter. Also water that high can enter every crack, cranny, hole, seam of the frame. And depending on how Toyota applies their paint for their frames, there may not be any sealant on the internals of the frame....bare metal, which leads to rust. Total weight on the brakes is really bad, you'll have to do a complete swap of all brakes and subsequent components. Next on the "what to worry about" list is the interior. Yes minor water from rain may not be able to enter due to the gaskets around the door, however there are tiny drainage holes at the bottom of all doors, this would allow water to enter inside the door itself, possible damage to window mechanism. Also depending on the force of the flood, stagnant water or raging river, water may enter into the cab interior. Check all carpet and upholstery. Also there is a computer/electrical component under the front passenger seat, most likely damaged if water entered the cab at that height.
    Bottom line for my thoughts, check all that you can without buying. Spend no more than $1k. If you can bring a battery to check electrical system then do it.
    You could always buy it and piece it out for parts.
    Coolhardy[OP] and Achuop like this.
  12. Aug 6, 2017 at 11:19 AM
    Coolhardy
    Harris
    2014 black tundra
    Too many to list
    Well,
    I m not worried about anything except the electrical issues like @Sean266 said. Coming from German cars, Toyotas electrical issues look like a piece of cake but then again you never know. Mechanical and bodywork, I can get almost anything done so @TheBeast that won't be a problem.
    Water didn't go too high. I agree w @Ryan Mc. that some of the things indeed need replacement which I am aware of. Rotors needs replacement, passenger seat amp probably gone, needs wheels and tires which I already have these parts laying around.
    It's salt water @WarEagleSteve which I know is a big no too. I will see if I can get a deal otherwise I will pass on it.
    Just the airbag assembly on this thing can be sold for $2500 on fleabay (have done it once).
  13. Aug 6, 2017 at 11:30 AM
    Be sure to hire @WarEagleSteve come out and give it a full detail if you get it. It'll need it lol
  14. Aug 6, 2017 at 11:39 AM
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    I've always wanted to buy something like this for cheap and start building an off-road truck! Most likely going to rebuild the motor when doing that anyways. Put in a roll cage and all that fun stuff. Not sure if I would trust this as a reliable daily driver though.
  15. Aug 6, 2017 at 11:53 AM
    LML 3500HD
  16. Aug 6, 2017 at 11:58 AM
    signalbobby
    Robert
    AZ
    A sealed transmission does not make it 100% water proof. If it sat in submerged water for some time, it very likely could have seeped in through a seal (rear/front/transfer case) or wherever else.
    Same goes for the engine. its not 100% bullet proof to be sealed if it sat in water for undisclosed time.
  17. Aug 6, 2017 at 12:18 PM
    Fiestee23
    Fiestee23 A CHICK'S TRUCK
    SOCAL
    White sr5 4wd
    Keep us posted if u do get it... I'm sure we would all love to see if it was worth It and what u do to it
    Coolhardy[OP] likes this.
  18. Aug 6, 2017 at 12:30 PM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    not sure i agree with everyone on the low value - but i do agree with most that you're potentially going to be chasing electrical gremlins for the rest of time. As for the value, depending on your time & space constraints, the salvageable parts are worth a pretty penny or two. I'll give you $200 for the headlights already! ;) Glass & undented panels are worth some too and there's plenty more in there that you can pull, clean if needed and resell if you get bored fixing electrical faults every weekend.
  19. Aug 6, 2017 at 1:22 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    I would only buy it to part it out. Doors, body panels, hood, bed and tailgate. It's nice to have spares right? ;) I wouldn't bother trying to get it operational.
  20. Aug 6, 2017 at 1:26 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    DO NOT GO THERE !!!!!
    SouthBoundSteve likes this.
  21. Aug 6, 2017 at 5:13 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    It was most likely backwater. I'm assuming it's from the flood from last year.
    Sewage....worse than either fresh or salt LOL
  22. Aug 6, 2017 at 5:52 PM
    Coolhardy
    Harris
    2014 black tundra
    Too many to list
    Bidding is already at $8500. Looks like it will go above 15k
  23. Aug 6, 2017 at 6:57 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Hope they have some good lube handy.
    smslavin and boardude like this.
  24. Aug 6, 2017 at 7:05 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    For that price there's no lube. Straight up dry raping is what that is
    smslavin and Law323[QUOTED] like this.
  25. Aug 6, 2017 at 7:11 PM
    Coolhardy
    Harris
    2014 black tundra
    Too many to list
    Auction has 9 more days to go. Keep you guys posted on the selling price. I have seen worse then this on Toyotas.
    FYI, it jumped from $2,000 to $8,500 in 5 days on what supposed to be a 14 day auction and it's a dealer only auction not open for public.
  26. Aug 6, 2017 at 7:16 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Just send this to the poor sumbitch that bids last.
  27. Aug 6, 2017 at 7:19 PM
    Coolhardy
    Harris
    2014 black tundra
    Too many to list
    Lol, probably the same guy who took the wheels out of the truck so he can bid and buy it back.
    Law323[QUOTED] likes this.
  28. Aug 6, 2017 at 7:20 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    That makes a little more sense. Dealers have parts and labor at their disposal to still make a profit. But it will still be a salvage title right?
    Law323 likes this.
  29. Aug 6, 2017 at 7:23 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Hahaha. Gonna be waddling worse than Yoda after that session
  30. Aug 6, 2017 at 7:25 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Just hope he doesn't pay more than insurance gave him! LOL
    NewImprovedRon likes this.
