FlexFuel Fuel Pump Issue?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Scorpion006, May 4, 2023.
  1. May 10, 2023 at 5:01 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Dang. that stinks. Well. Get a copy of techstream and see if you can reset the alcohol density. Go from there.
  2. May 10, 2023 at 5:05 PM
    BrandonL812
    Brandon
    well, I don’t know. Because there are others who have had the fuel pump replaced under warranty and STILL have the problem. Would that mean the fuel pump is bad again?
  3. May 10, 2023 at 5:12 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    No. It’s means that Toyota has no fix to keep the alcohol density percentage correct and they don’t plan to find one. As long as you own a flex fuel Tundra you’ll have the problem. The pump does nothing.
    itshelly and BrandonL812[QUOTED] like this.
  4. May 10, 2023 at 5:41 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    I feel the best approach is to keep an eye on the fuel alcohol percentage via obd reader. When it starts creeping up, reset the percentage via dealer, techstream, or one of the bi-directional scanner/readers that have the capability.
    BrandonL812 and BTBAKER[QUOTED] like this.
  5. May 10, 2023 at 5:51 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    You are correct. I didn’t have the capability, unfortunately. The fuel pump did nothing for me.
  6. May 10, 2023 at 6:58 PM
    BrandonL812
    Brandon
    I will have to keep an eye on our sequoia then. It too have the flex-fuel engine. At 32k, so far nothing yet. Hopefully it wont show up. But can never be too sure. I do have the knockoff techstream that I’ve used to change couple setting like seatbelt chime volume and key reminder chime volume. So I’m some-what familiar with how it works.
  7. May 17, 2023 at 12:41 PM
    coopsdaddy23
    coopsdaddy23 New Member
    Quinton
    2019 dclb
    Na
    Are all the 2017s flex fuel?
  8. May 17, 2023 at 1:28 PM
    CTundraForMe
    CTundraForMe New Member
    I believe manufacturers were mandated to create a certain percentage of them. Not all of them, thank God!
  9. May 17, 2023 at 4:24 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Not so much mandated as every flex fuel vehicle was assumed on paper to run gas half the time, so it boosted the brand's fleet mpg to meet the federal standard. I wonder if that bonus may have ended as a lot of flex vehicles have gone away
    Imagine every ffv 5.7 counted as a 28 mpg vehicle
  10. May 17, 2023 at 4:36 PM
    Scorpion006
    Scorpion006 [OP] I'm athletic - I’m known to surf the web for hours
    Austin, TX
    2017 White Tundra 1794
    Definitely not...
  11. May 18, 2023 at 8:23 AM
    coopsdaddy23
    Quinton
    2019 dclb
    Na
    If you were in the market for a 2017-2020 would you pass on the flex fuel Versions,or is it a something that’s affecting just a few.
  12. May 18, 2023 at 8:34 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    I would buy based on condition and price. If it happens to be non flex-fuel, then you got lucky.
    The issue can be contained by resetting the fuel alcohol percentage, so long as you do this before the fuel pump burns out.
  13. May 18, 2023 at 8:35 AM
    Scorpion006
    Austin, TX
    I bought one not knowing that it was a Flex Fuel version.... I see it as a benefit - that I can basically run any E85 if I wanted or I can just run regular gas. (Almost Hybrid like:rofl:)
    Other than this possible Fuel Pump issue - nothing to complain about...
  14. May 18, 2023 at 9:49 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    E85 cleans carbon buildup like crazy and makes more torque so it's not all bad. Some ffv trucks never have a problem
    jtwags likes this.
  15. Jun 1, 2023 at 7:52 AM
    c_western
    c_western New Member
    2018 SR5 TRD Off-Road
    Same issue over here. 2018 FFV that had a hard time starting if it was 40* or below. Luckily its still under the federal emissions warranty, but it's been at the dealership waiting on a fuel pump since February 15th and they still have no idea ETA for when they'll receive fuel pumps.
  16. Jun 1, 2023 at 8:25 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    I don't know that it affects all flex fuel engines. I have a 2015 and have never had the issue with mine.
  17. Jun 2, 2023 at 10:26 PM
    alanc3
    alanc3 New Member
    2015 silver tundra SR5 off-road
    Cold air intake, pedal commander throttle response control
    I finally got my issue fixed! Cost about $1,100 and about 6 months of waiting but they replaced the fuel pump and recalibrated the fuel-alcohol ratio and she runs perfect again!
    huntsonora likes this.
  18. Jun 14, 2023 at 10:59 AM
    MyActualName
    MyActualName New Member
    My 17 flex fuel truck starts fine even in cold weather, but has intermittent lurches/pulsing vibrations in 5th and 6th gear at highway speeds only when the weather is below 40-50 degrees. My initial assumption is torque converter since it goes away if I shift to 4th.
    Has anyone else with a bad fuel pump experienced this?
    My alcohol percentage is a pretty constant 2.75%, even when filled up with non-ethanol fuel which is a little strange.
    I won't be able to test it for another 6-7 months when it gets cold.
  19. Sep 27, 2024 at 5:23 PM
    #49
    BoatBroker
    BoatBroker New Member
    Sarasota, Florida
    2016 Tundra SR5
    That is 100% the fuel pump. I'm just replying on here in hopes to help others. The hesitation and feeling of a misfire is a very unusual symptom of a bad fuel pump so most shops won't be able to figure it out. Here is my video on replacing the pump etc.
    https://youtu.be/B6jRlR8gbjw?si=E6e1f9VLqiT7PVcz
  20. Sep 27, 2024 at 7:22 PM
    #50
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Or for $170 throw a Deatschwerks dw300 fuel pump in the canister. It fits with no modifications needed. Most have gone this route.
  21. Sep 27, 2024 at 8:36 PM
    #51
    68vert
    68vert New Member
    AZ
    2011 Rock Warrior
    This is what I did. Replaced the second OEM pump on my Tundra.
    Did the same pump on my supercharged Tacoma as well. Good results both times.
  22. Sep 27, 2024 at 9:35 PM
    #52
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Which DW300 pump? They seem to have several to choose from.
  23. Sep 27, 2024 at 11:03 PM
    #53
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    They are all 340lph. The 9-1026 kit has a decent filter. Can re-use the suction hose with fuel injector clamps to ensure a good seal.
    Edit: part number and deleted some info that didn't belong.
    dt325ic[QUOTED] likes this.
  24. Sep 28, 2024 at 5:02 AM
    #54
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Off topic but what head unit is that?
  25. Sep 28, 2024 at 6:19 AM
    #55
    BoatBroker
    Sarasota, Florida
    2016 Tundra SR5
    Thanks for that info. I couldn't find what pump motor could be replaced since Toyota doesn't just sell the motor.
    Mdl[QUOTED] likes this.
  26. Sep 28, 2024 at 6:20 AM
    #56
    BoatBroker
    Sarasota, Florida
    2016 Tundra SR5
    That is a Dasaita. It's about $500-$600 and you can find the newer version on Amazon. It's been excellent the 3 years I've had it. Carplay works awesome, youtube, streaming... basically whatever app you want that runs on Android
  27. Sep 28, 2024 at 8:04 AM
    #57
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It's very good video and lots of information. It's a mix of people who will have Toyota fix it, diy with the canister only or take everything apart to swap just the pump. For some it's a bit too involved with taking the canister apart to swap pump. Installing the supercharger you have to swap pumps out for the higher flow in non-flex setups.
    250000yota likes this.
  28. Sep 28, 2024 at 8:40 AM
    #58
    BoatBroker
    Sarasota, Florida
    2016 Tundra SR5
    Thank you and you're absolutely right in your summary. The list price on the FFV entire assembley is $600. My local dealer runs 25% off a few times a year online only and I was able to get the whole fuel pump assembley for $382 w. tax and free shipping. The pump I took out that was original from factory in 2016 says "Made in Brazil" which I thought was interesting.
  29. Sep 30, 2024 at 6:06 AM
    #59
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Thanks. I noticed they sell DW300 and DW300C (compact?), and I didn’t know if that mattered.
    This seems like a good, proven replacement that doesn’t break the bank.
  30. Sep 30, 2024 at 8:59 AM
    #60
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The 9-307-1026 is Toyota specific. Yes it's a compact dw300c. It's pretty much plug and play.
    https://deatschwerks.com/products/9-307-1026
