Flashing lights
Discussion in '2nd Gen Tundras (2007-2013)' started by kriptnite, Aug 2, 2017.
  1. Aug 2, 2017 at 7:47 PM
    kriptnite
    kriptnite [OP] New Member
    Aaron
    2007 tundra sr5
    Need help with flashing 4lo light with Bell as well as vsa flashing and traction control on,does not engage in 4 lo but seems to be going into 4 hi???
  2. Aug 2, 2017 at 8:00 PM
    Sounds like AIP
  3. Aug 2, 2017 at 8:40 PM
    kriptnite
    Aaron
    2007 tundra sr5
    Aip?whats that mean?it all started after trying to take front wheel off and it was seized to hub so had to take a huge mallet and brake it loose from the hub to put new pads on front?
  4. Aug 2, 2017 at 8:49 PM
    Do you have a check engine light on?
  5. Aug 2, 2017 at 8:57 PM
    kriptnite
    Aaron
    2007 tundra sr5
    Yes for a long time scanned it said o2 sensor pre bank 2 but truck runs fine?still runs fine even with the flashing lights but have not scanned it with all these others lights on?put front pads on it like I said had to pound the wheel to get it off where it was seized on,got pads on backed out off drive way and it died.it would not start back.pulled bat loose and reset pc and it started back,went down the road a bit then vsa flashing traction control on and 4 lo flashing does not seem to be going into 4lo but yes o2 has been bad for quite sometime and engine light on
  6. Aug 3, 2017 at 5:01 AM
    kriptnite
    Aaron
    2007 tundra sr5
    so the aip or o2 sensor will cause it not to go into 4lo ?
  7. Aug 3, 2017 at 6:30 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    If there is in fact an issue with the Air Injection Pump (AIP) there will be engine codes specific to that system. Have them checked again to be sure. If your issue with the other lights started AFTER you replaced the brake pads, I would have to suspect that it may be a wire problem where one of the ABS sensor wires got damaged. That would be more likely to prevent 4lo.
    JTP likes this.
  8. Aug 3, 2017 at 6:56 AM
    kriptnite
    Aaron
    2007 tundra sr5
    I will check codes today,abs light is not on not sure if I mentioned that
  9. Aug 3, 2017 at 7:03 AM
    When I broke my abs wheel sensor I had 4hi/low/trac on. I then fixed that by ordering @sdhq_offroad abs wheel sensor guards.
  10. Aug 3, 2017 at 7:10 AM
    First thing I thought was speed sensor got damaged when removing wheel/rotor with mallet...
    Wynnded likes this.
  11. Aug 3, 2017 at 7:10 AM
    kriptnite
    Aaron
    2007 tundra sr5
    Got a c1201 code and a poo51
    Randy Morton likes this.
  12. Aug 3, 2017 at 7:13 AM
    Poo?
    Black Wolf likes this.
  13. Aug 3, 2017 at 7:17 AM
    kriptnite
    Aaron
    2007 tundra sr5
    Rotor came off fine it was the wheels its self after taking all the nuts off it was still stuck to the truck had to take a mallet to the tire I've seen them stick before but this one was really on there
  14. Aug 3, 2017 at 7:25 AM
    Sounds like it wasn't much fun. I messed up my drivers side speed sensor and got the flashing light show too. Replaced sensor and problem went away.
  15. Aug 3, 2017 at 7:32 AM
    kriptnite
    Aaron
    2007 tundra sr5
    Yea thx,that's what I'm thinking also
  16. Aug 3, 2017 at 7:35 AM
    kriptnite
    Aaron
    2007 tundra sr5
    Is this abs sensor?
  17. Aug 3, 2017 at 8:09 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    Could that be C10201? That's the code for a bad wheel sensor.
  18. Aug 3, 2017 at 8:25 AM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Are you trying to put it in 4lo? or are all the lights coming on
  19. Aug 3, 2017 at 9:37 AM
    kriptnite
    Aaron
    2007 tundra sr5
    Vsc flashing traction control light and 4 lo light all on code c1201,reset comes back on after couple miles does not go into 4lo I can go into 4 lo after resetting pc but once all the light come back up you can't go into 4 lo
  20. Aug 3, 2017 at 9:55 AM
    kriptnite
    Aaron
    2007 tundra sr5
    No it's c1201
    Randy Morton[QUOTED] likes this.
  21. Aug 3, 2017 at 10:30 AM
    Randy Morton
    Randy
  22. Aug 3, 2017 at 1:34 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Here's what my search yielded:
    "c1201 is not really a problem at all, If you notice whenever the check engine light comes on the VSC and TRAC OFF lights come on as well, since the VSC system heavily depends on the engine control systems it will stop working if the engine computer stores a code, So code c1201 says that there's an engine control malfunction."
    In this case, I guess that I would suggest that you start with resolving the Poo (P0051) code by cleaning the poo from the oxygen sensor, or just replace it. If I were to speculate, I would guess that the computers (engine and ABS/Traction Control) are programmed to not allow 4lo operation if it can't read the engines emissions to ensure that they're in spec, particularly if you're doing a 4lo low speed cruise.
    gosolo likes this.
  23. Aug 3, 2017 at 1:38 PM
    kriptnite
    Aaron
    2007 tundra sr5
    Also getting a po983 code as well now?
  24. Aug 3, 2017 at 1:42 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  25. Aug 3, 2017 at 1:51 PM
    kriptnite
    Aaron
    2007 tundra sr5
    O2
    o2 sensor has been bad for a year now just the engine light,all these other lights are new but going to start with the o2 sensor
    Wynnded[QUOTED] likes this.
  26. Aug 3, 2017 at 1:57 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ya, you kinda have to start somewhere. Keep us updated, feedback can aid others too.
    JTP likes this.
  27. Aug 3, 2017 at 2:02 PM
    kriptnite
    Aaron
    2007 tundra sr5
    Will do,might end up at dealership??$$$$$
  28. Aug 3, 2017 at 6:33 PM
    JTP
    JTP The Big Black Moose
    Sterling, Alaska (Formerly DFW Texas)
    The Big Black Moose
    Maybe Toyota will come out with the TRD NFE Tundra. (NO FUCKING ELECTRONICS)
    Im starting to think that TRD is short for Turd after all of my electrical wild goose chases that Ive been on over the last few weeks.
  29. Aug 3, 2017 at 6:45 PM
    kriptnite
    Aaron
    2007 tundra sr5
    My first tundra bought it used should have stayed with the t100 no power but bullet proof
  30. Aug 4, 2017 at 5:50 PM
    JTP
    The Big Black Moose
    Getting warmer on the issue.
    SO get this:
    Completely removed the HID head lights conversion, installed stock bulbs.
    Truck runs perfectly fine with the head lights off. NO DASH lights, No engine cutting out.
    Turn the head lights on and ABS and Trac lights come on. Drive for about 5 mins and the truck starts cutting out and trying to die.
    Turn the head lights off and the ABS AND TRAC lights stay on and the truck continues to try and die.
    Turn the truck off. Turn it back on.
    ABS and track lights are / stay on. (head lights still off)
    Hit the brake peddle one time and ABS and Trac lights GO OFF.
    Truck runs normal again.
