Fixing axle wrap after installing leveling kit
Discussion in 'Suspension' started by tripletundra, Jul 3, 2020.
  1. Jul 3, 2020 at 4:04 PM
    tripletundra
    tripletundra [OP] New Member
    Stuart Fl
    2021 Tundra Platinum
    K n N Cold air, 20x9 +1 Moto Metal, Winjet Tail lights.
    Hey guys I’ve installed a 3/1.5 leveling kit on my 19CM. Immediately I’ve noticed a little axle wrap. Before I spend $200 bucks on something. Are these any good? And will shackles get rid of the axle wrap? Thanks in advance.
  2. Jul 3, 2020 at 4:28 PM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    I have been ruining those and they are very well built.You have to reuse your factory bolts. Just knock them out with a hammer. They are a nice shackle. Look into reply your leaf spring bushings while you have it apart
    pretty sure I used the 1.5” shackle though
  3. Jul 3, 2020 at 4:37 PM
    tripletundra
    Stuart Fl
    I saw that on there site about the bolts. I’ve only got 7200 miles on mine so I should be all set with bushings.
  4. Jul 3, 2020 at 5:03 PM
    How did you discover the axle wrap? I know larger blocks in the rear end can potentially cause it, but I have never heard of anyone having it with a 3/1.5 setup. I ran a 3/2 without issues. I'm not doubting you by any means at all. I'm asking for more of a learning opportunity for all of us on here. :hattip:
  5. Jul 3, 2020 at 5:10 PM
    tripletundra
    Stuart Fl
    Tundra234 I believe the reason is the blocks I put in are not tapered at all. I’ve never had this problem in the 7200 miles I’ve put on this truck (brand new) until today after installing and lining it up. Another guy who does lifts as a job suggested shimming my carrier with around 1/2” of shims.
  6. Jul 3, 2020 at 5:15 PM
    Yes the non-tapered blocks could be the issue. What kit is it? The carrier bearing spacer will adjust the drive angle, but the common cause of needing it is for vibrations when accelerating froma dead stop. Coachbuilder spacers are like $13 bucks or so. I have them in mine. I have some Readylift 2 inch tapered blocks sitting on my garage floor. I went from the Readylift 3/2 to Toytec coilovers and shackles.
  7. Jul 3, 2020 at 5:19 PM
    tripletundra
    Stuart Fl
    That’s what I’m getting is a slight vibration from a dead stop. What’s you get a about 20 mph or so if you get aggressive with the throttle I don’t notice it. I can’t remember the kit. It was something I got from a local shop. It’s a nice billit aluminum kit. SPC or something like that.
  8. Jul 3, 2020 at 5:31 PM
    Hard to tell without seeing pics of it.
  9. Jul 3, 2020 at 5:31 PM
    mkeegan27
    mkeegan27 New Member
    CT
    2018 platinum crewmax
    just installed readylift 3/2 and was getting vibration up to about 20 mph. ordered carrier bearing drop from toytec and its gone.
  10. Jul 3, 2020 at 5:40 PM
    tripletundra
    Stuart Fl
    Tundra234 I’ll get some for you tomorrow.
    Mkeegan27 that’s what I’m getting for vibration as well. Up to about 20 mph
  11. Jul 3, 2020 at 5:43 PM
    mkeegan27
    CT
    So I would order the carrier bearing drop kit from toytec....its a 2 aluminum spacers that toytec sells for 12 bucks. You reuse factory bolts and can be installed in under 15 minutes.
  12. Jul 3, 2020 at 5:48 PM
    tripletundra
    Stuart Fl
    Just ordered them. So once you put these your vibration went away?
  13. Jul 3, 2020 at 5:51 PM
    Yes they will take care of it.
    atrinh15 and mkeegan27 like this.
  14. Jul 3, 2020 at 5:51 PM
    mkeegan27
    CT
    yup, its gone! Not sure why some trucks get it and some don't but i'm glad its gone.
  15. Jul 3, 2020 at 5:58 PM
    tripletundra
    Stuart Fl
    Thanks for the advice.
  16. Jul 3, 2020 at 6:06 PM
    tripletundra
    Stuart Fl
    How thick are those shims? 1/4” or 1/2”?
  17. Jul 3, 2020 at 6:08 PM
    They are 1/2 inch and used for rear lift up to 2 inches. They fit with the stock bolts as well.
  18. Jul 3, 2020 at 6:10 PM
    tripletundra
    Stuart Fl
  19. Jul 3, 2020 at 7:01 PM
    atrinh15
    atrinh15 New Member
    495-93 area
    2018 PLATNIUM White CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
    Im so close to pulling the trigger on the bilstein 6112/5160. And buying CB shackles. Getting a vibration and tires wearing out. With my 3/2 ready lift. Would the carrier drop fix it all? Besides the front tire wear?
  20. Jul 4, 2020 at 2:02 PM
    tripletundra
    Stuart Fl
    So an update. I added 1/2” of shims to the carrier today and zero vibration. Thanks guys for the advice.
    monaco730 and atrinh15 like this.
  21. Jul 4, 2020 at 8:58 PM
    :thumbsup:
  22. Jul 5, 2020 at 12:28 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I’ve got the shackles no issues super good buy can’t beat em for the price
    tripletundra[OP] likes this.
  23. Jul 8, 2020 at 4:23 AM
    atrinh15
    atrinh15 New Member
    495-93 area
    Which shackles did you end up getting? The same as the OP?
  24. Jul 8, 2020 at 6:04 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    I have the pro form shackles too. No issues.
  25. Jul 8, 2020 at 7:36 AM
    xtyfighterx
    Ty
    North Idaho
    Yes
  26. Jul 9, 2020 at 9:50 AM
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    I did this setup at 3in with SPC UCA'S, CB front spacers, random Amazon diff drop a,nd CB carrier bearing drop, with CB +3 shackles.
    Still have vibrations. But I also had it stock some how also. Ymmv.
    LOVE the ride, handling, and stance now. Totally worth all the money and work it took to do it.
  27. Jul 9, 2020 at 10:01 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    your front tire wear is due to poor alignment with the 3 inch lift. You need upper control arms
  28. Jul 9, 2020 at 10:20 AM
    atrinh15
    atrinh15 New Member
    495-93 area
    You still had vibrations? In the rear or front? My kids carseats shake like crazy when there not in the truck with me. More at certain speeds.
    i just bought the whole setup minus the UCAs. New tires at the end of week.
  29. Jul 9, 2020 at 10:23 AM
    atrinh15
    atrinh15 New Member
    495-93 area
    All within spec. But right on the line. I think i have a little more the. 3” of lift in the front. Im suppose to be level but currently have a cali lean.
  30. Jul 9, 2020 at 10:32 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Look up alignment specs on this site. Toyota “spec” isn’t ideal
