FIXED: Trailer/Backup Guide/Camera Errors
Discussion in '3rd Gen Tundras (2022+)' started by WifeSaidPlatinumTRD, Nov 20, 2023.
  1. Nov 20, 2023 at 5:34 PM
    WifeSaidPlatinumTRD
    WifeSaidPlatinumTRD [OP] New Member
    2024 Tundra Platinum TRD Off-Road
    Have any of you dealt with this? I’ve lost backup guides and ability to select different camera views… my truck said trailer assist malfunction see dealer, but I haven’t seen it again for picture. I do have an error in the trailer menu but no idea what it is. It’s rainy pretty hard in Tennessee and I have no clue what this is. Does my truck think there is a trailer attached? I have never pulled a trailer. When I try to delete a trailer in the menu or add one it just goes to error. Could this be the rain???
  2. Nov 20, 2023 at 5:41 PM
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    dang that screen is scratched up lol
    Sisu87TRDOR likes this.
  3. Nov 20, 2023 at 8:14 PM
    WifeSaidPlatinumTRD
    Yeah I’m looking to replace that too.. that was one cleaning attempt with a clean microfiber…
  4. Nov 21, 2023 at 5:30 AM
    WifeSaidPlatinumTRD
    I’m taking it to dealer this morning: it appears that rain may have penetrated the backup roof camera/sensor which is why it’s all jacked
  5. Nov 21, 2023 at 10:09 AM
    WifeSaidPlatinumTRD
    FIXED: apparently hard rain on the 2024 Tundra can throw off sensors and requires a recalibration
    pwpblue likes this.
  6. Dec 28, 2023 at 7:34 PM
    Nio9
    Nio9 New Member
    Really, rain! On a brand new vehicle? I am having same issue. No back up guides nor am I able to change camera. Toyota QC is becoming a joke!
    TundraDan723 likes this.
  7. Jan 4, 2024 at 5:48 AM
    ambrosjb
    ambrosjb New Member
    Also have this trailer backup guide issue. Can this “recalibration” be done at home? Really don’t want to go to the dealer every rain storm….
  8. Jan 6, 2024 at 4:03 PM
    ambrosjb
    ambrosjb New Member
    Went to the dealer. Confirmed that I need a "calibration" fix. They didn't even know what the solution was. They needed to call their Toyota Tech support line to figure it out. They need my truck for AN ENTIRE DAY to do the calibration... Not ideal for a 2 month old truck. We'll see if this is a chronic problem.
    In short, I had an error message pop up one morning on the dashboard side that said something like "Trailer Backup Sensor Malfunction. Contact Dealer". I'm not currently towing anything, so what this meant was that I lost my backup camera "guide lines" which turn depending on how I turn the steering wheel. I believe I also lost some of the yellow/red proximity sensor animations. We'll see if they end up fixing it next week. Will report back and hopefully help others.
    pwpblue and ryanwgregg like this.
  9. Jan 10, 2024 at 5:25 AM
    Exinos
    Exinos New Member
    I'm having the same issue on the 2024. Not ideal for a truck less than a month old. Were you able to find out if the calibration can be done at home or is taking to the dealer the only option?
  10. Jan 10, 2024 at 6:53 AM
    firehawk003
    firehawk003 New Member
    it appears the protective plastic may still be on the gauge. Some dealers forget to take this off.
  11. Jan 10, 2024 at 2:47 PM
    ambrosjb
    ambrosjb New Member
    Have to go to dealer… dropping off this Friday for “all day” to recalibrate.
    Agree on protective film. Didn’t have on my dash gauges but was the case with my entertainment screen.
  12. Jan 13, 2024 at 6:01 PM
    Exinos
    Exinos New Member
    Update - Dropped it off at the dealership Wednesday and said will have it back at the earliest Monday. No clue what’s taking so long. Will post another update with the work done on it.
    feels bad
  13. Jan 14, 2024 at 8:50 AM
    ambrosjb
    ambrosjb New Member
    Update: Dropped at dealer 9-12pm. Here's what was on the write up:
    "Cause: Circumference camera ecu out of adjustment. No lines on backup camera.
    Correction: Had to calibrate camera circumference ECU then go into radio diag mode and adjust all viewing cameras"
    Unfortunately service was closed by the time I picked up the truck, so no idea if this will happen again or if I can just DIY. Sounds like both an adjustment to the camera itself AND some sort of diagnostic mode in the radio. Hopefully this helps someone else out there.
    tsu14 and pwpblue like this.
  14. Jan 23, 2024 at 5:05 AM
    tsu14
    tsu14 New Member
    Travis
    2024 Tundra Platinum HV
    any updates? my truck did the same thing this morning. Gave a "trailer backup malfunction, see dealer" message accompanied with no back up lines. Not really excited if this is a normal occurrence and requires an all day dealer visit......
  15. Jan 23, 2024 at 8:26 AM
    ambrosjb
    ambrosjb New Member
    Unfortunately, that was my update. Had to drop it off only for a couple of hours. Didn't have a chance to get time 1 on 1 with the tech since they were closed. When I initially dropped it off the tech had no clue how to fix it and had to call the Toyota Technician mothership. Not 100% certain, but google searches on calibrating the ECU in a vehicle does not seem like an easy DIY. Hopefully they make it a recall and fix for everyone before others have the issue. At least it's now been a week and a half and I have not seen the issue again.
  16. Jan 31, 2024 at 2:00 PM
    jeremy.j.henry
    jeremy.j.henry New Member
    Anyone else dealing with this? Dealer said it was because I grille swapped for a trd pro and the camera is off but my front,back, and top view camera work fine I just don’t have side cameras or back up lines now.
  17. Feb 25, 2024 at 9:57 AM
    mjdtrdpro
    mjdtrdpro New Member
    I am experiencing this same issue myself in a 2024 Tundra TRD Pro
    This is crazy.
    I ran the Truck thru a car wash - just water jets. Do you think this caused this problem. I think it was also malfunctioning before this.
    I Had camera system set on auto and noticed it was not doing auto anymore and no guides.
    Very annoying.
  18. Feb 25, 2024 at 10:01 AM
    tsu14
    tsu14 New Member
    Travis
    Not sure what the cause is, mine started randomly doing it one morning. Took it to the dealer during an oil change and they calibrated it the same day….hopefully it’s a one and done issue and not a repeat.
  19. Feb 25, 2024 at 11:42 AM
    mjdtrdpro
    Would like to know what fix is.
    I found on youtube that Camrys have a reset method to recalibrate 360 cameras.
    Is there a service menu for Tundra that we can access?
    0w40 likes this.
  20. Feb 28, 2024 at 4:34 PM
    mjdtrdpro
    I took my car 2024 TRD Pro to the dealer to get the 360 camera system fixed as above
    Dealer has been working on for 2 days so far - in. a RAV 4 Limited - not impressed at all.
    Is this just a 2024 problem? Dealer said they have never seen this problem before.
    Really questioning Tundra Quality - my 2021 Ram Rebel is abetter truck than the Tundra TRD Pro in my opinion. Sad to say
  21. Feb 28, 2024 at 6:47 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Oh dam! lol I’m ordering screen protectors right now
    Tundrastruck91 likes this.
  22. Mar 30, 2024 at 3:17 PM
    mo-jo
    mo-jo New Member
    Josh
    2024 MGM Tundra Platinum
    Wondering if anyone has any updates on this? The error message came up on mine this morning. No parking guide lines, no side camera views, and no auto camera. 550 miles on the tundra got it 3 weeks ago...
  23. Mar 31, 2024 at 8:11 AM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Post 5
    Welcome to the forum!
  24. Apr 7, 2024 at 4:19 AM
    mjdtrdpro
    I had this problem in February and had the dealer fix mine - I believe they hasd to recalibrate the cameras. - So far so good.
  25. Apr 21, 2024 at 2:20 PM
    Gii
    Gii New Member
    I have a 23 sequoia and I have the same problem with my parking guidelines. One morning, I tried to backup and the lines went away even the front camera lines. The automatic camera also went away. Any fixes dyi fixes before I go to the dealer?
  26. Apr 22, 2024 at 6:41 PM
    roguepacket
    roguepacket New Member
    Same problem here. 2024 TRD Pro. Headed into the dealer on Wednesday. :(
  27. Apr 22, 2024 at 7:31 PM
    Gii
    Gii New Member
    Update: took to the dealer and recalibrated the camera. But I have to take them again because I noticed the recalibration is no accurate so check them before you leave.
  28. Apr 27, 2024 at 7:49 PM
    pmcgill
    pmcgill New Member
    Patrick
    2024 MGM Tundra SR5 Offroad
    Same problem. Happened today 20 minutes after running it through a brushless car wash.
  29. Apr 29, 2024 at 1:49 PM
    FarmBoy
    FarmBoy New Member
    Same problem after a heavy rainstorm ('24 Tundra). Been at the dealer for A WEEK and still no word except telling me they tried what Toyota Tech told them, didn't work, waiting to speak with Tech again. This is obviously not an uncommon issue and Toyota needs to address it. Insane for this to happen on a new vehicle and makes me question overall build and the potential for long term issues.
  30. Apr 30, 2024 at 1:53 PM
    pmcgill
    pmcgill New Member
    Patrick
    Took to the dealer today, they recalibrated. Took a couple hours. Service advisor said Toyota has not issued anything yet on the issue, but they expect them to soon.
    Champster likes this.
