Fitment 35/12.5r18 General grabber x3
Discussion in 'Wheels & Tires' started by TRDpro619, May 31, 2017.
  1. May 31, 2017 at 9:14 AM
    TRDpro619
    TRDpro619 [OP] Follow My Build on Instagram:TRDorcaTUNDRA
    San Diego
    TRD Pro CM
    Looking to upgrade tires on my pro. Found a good deal on some 35/12.5r18 general grabber x3 tires and want to know who has run them and what they had to do to make them fit.
    I'm thinking i might need 1" bora spacers to keep the tires from hitting the UCA. I'm running all stock right now and don't plan on touching the suspension, but I know I might need to do some stuff around the wheel well. Please give me your i inputs and explain.
    And I know these tires will fit even though my rim is 8" width and it's not recommended to go 12.5" tires I'm going to do it anyways hah
  2. May 31, 2017 at 10:08 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    I do 35x12.5x17 on 8" wide wheel with no issues. even hard off road
    dcsleeper408 likes this.
  3. Jun 1, 2017 at 9:08 AM
    trdlife
    trdlife Toyota Master Technician
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    Im running 35*12.5r18 on factory pro wheels. i have a 1/4 space on mine and I clear with no rubbing.
  4. Jun 1, 2017 at 9:10 AM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    here are a few pics of fitment. the spacer in the picture is what i used, but for tundra lug pattern.
    PermaFrostTRD and Halfjap like this.
  5. Jun 1, 2017 at 10:13 AM
    TRDpro619
    San Diego
    TRD Pro CM
    Do U have a picture from the side, want to see how they look if I got a 1" or 1.25" spacer
  6. Jun 1, 2017 at 10:41 AM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
  7. Jun 1, 2017 at 11:11 AM
    Puud
    Puud Graveyarder
    Nebraska
    2017 Crewmax
    Im running X3's 35x12.50r18. But I have a 7" lift with +1 offset wheels. My tires just barely grazed the front plastic right after install, but after a couple thousand miles dont touch anymore. I really like the tires so far. Havnt tried them in the snow yet and only had them for a couple thousand miles so I cant speak for the durability. IMG_0936.jpg
    GNTundra, Dustydirt19 and joonbug like this.
  8. Jun 1, 2017 at 12:10 PM
    TRDpro619
    San Diego
    TRD Pro CM
    Do you have any kind of lift on the stock pro suspension?
  9. Jun 1, 2017 at 12:12 PM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    I have 2 coachbuilder shims on each side in the front & +3 shackles in the rear.
  10. Jun 1, 2017 at 12:13 PM
    TRDpro619
    San Diego
    TRD Pro CM
    Do you think I'll clear it without?
  11. Jun 1, 2017 at 12:21 PM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    I think it should, it will be close
  12. Jun 1, 2017 at 12:23 PM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
  13. Jun 1, 2017 at 12:26 PM
    TRDpro619
    San Diego
    TRD Pro CM
    I'm going to attempt it, finding better deals on 35x12.50r18 then on 295/70r18. Just gotta make sure 1" spacers will clear stock wheels hubs. Might just go 1.25" to be safe and ride that wider stance
    trdlife[QUOTED] likes this.
  14. Jun 1, 2017 at 12:28 PM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    yea plus the spacers do look good too. the 295 will fit better stock, since they are a big skinnier. I was going to get generals when i went to 35s but i found a set at a local shop here for like $650
  15. Jun 1, 2017 at 12:35 PM
    TRDpro619
    San Diego
    TRD Pro CM
  16. Jun 2, 2017 at 8:03 PM
    TRDpro619
    San Diego
    TRD Pro CM
    Just found a set of 35/11.5r18 so they are 1" narrower and should clear the UCA. They are also $300 cheaper too. Can't find anyone running these to see what modifications id have to do to make them fit if anh
    Big J and trdlife like this.
