Fishing rod transportation
Discussion in 'Fishing' started by Njmike13, May 14, 2017.
  1. May 14, 2017 at 7:05 AM
    Njmike13
    Njmike13 [OP] New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    I live in NJ but have cabin in NY. I love fishing and spend more than I tell my wife on high end rods. I don't want to leave them at my place in NY and I need to transport them safely between N.Y. and NJ. Before the tundra I was able to hang them from the ceiling in my SUV. any ideas? All the rods are between 6' 10" and 7' 6".
    Thanks
  2. May 14, 2017 at 7:13 AM
    Does your bed have a tonneau cover ? I made a make shift rod holder with 6 rod holders from academy sports n outdoors and 2 1x8 planks treated wood the back of the boards had 3 metal straps galvanized 1" wide 6" long drilled 4 holes spaced them out screwed on the back then 2 more metal straps foot n half long made them into j shapes that screwed to back of boards then hung over back of bed if you have a tool box I screwed to tool box but i made 2 wedges to tip the top of rod holder forward so that tool box lid wont hit rods
    Fiesta346 and Bob like this.
  3. May 14, 2017 at 8:22 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    I custom made my rod holders. It's on my build page. For something quick and inexpensive. Take and measure the slots in your bed. Cut a 2x8" treated to fit. Get you some of the galvanized 1" straps aramirez73 suggested and buy you some 2" pvc piping. Cut your pvc to fit , also cut you a notch where your reel will sit down in pipe. Secure pipe with straps. If you want to get a little more fancy, take another 2x8" and put it on top of your installed 2x8" , cut it @ a 45* angle and install your pvc pipe on the top plate. This will have your rods @ a angle instead of straight up. Keeps them low profile and away from tree limbs . One quick note, when I say cut it @ 45, I mean cut your 2x8 that will sit vertical, and cut the top off @ a 45. Then secure your other 2x8 to that. Not insulting your intelligence, just making sure I'm making sense. Haha. Hope this helps. Post pic of you do it. Thanks
    SouthBoundSteve and Bob like this.
  4. May 14, 2017 at 8:32 AM
    fishinfool
    fishinfool New Member
    Joe
    Bakersfield, Ca
    14 CM SR5 Silver
    None.... YET!!
    I use 1" conduit, width of bed, and cut in half. Use a 1" coupler in center of pipe for easy removal. Wrapped w 3m type pipe insulation so rods aren't riding on pipe. I have notched the insulation so rods don't "slide" while driving. Use a bungee cord to secure them. Can load pics if you would like. Camping at the moment...
  5. May 14, 2017 at 8:33 AM
    Bob
    Bob Member Staff Member
    Bob
    07 Tacoma PreRunner Black
    Any pics of these holders you guys created?
    Fiesta346 likes this.
  6. May 14, 2017 at 8:35 AM
    fishinfool
    Joe
    Bakersfield, Ca
    14 CM SR5 Silver
    None.... YET!!
    When we get home can snap some...
  7. May 14, 2017 at 8:52 AM
    rons23
    Ron
    Kill Devil Hills
    Yes Bob, thought it was in my build, but found it when unique mod contest was ran.
    Here's minee49a6f2fba7d7692d767b3c2c04685ad_c9cb607d3902fb2fa0cce1322501601d57b43cb2.jpg8293b9d4cd1c916e8bc4f972619082bc_02609ab1a30ff412a3669a79d86d8961e72a7e33.jpg
    Bbombs, Skippy, blue16 and 6 others like this.
  8. May 14, 2017 at 8:57 AM
    rons23
    Ron
    Kill Devil Hills
    Ron, I would imagine transportability. You can always put them in your cab if you have to stop and go into store or something. If you're like me, I don't want my rods bouncing around in the back of my truck, too much $$$$
    NewImprovedRon likes this.
  9. May 14, 2017 at 10:20 AM
    rons23
    Ron
    Kill Devil Hills
    Your talking on the butt end, where your rod will sit.. Not sure if I'm following you right
  10. May 14, 2017 at 10:23 AM
    15whtrd
    15whtrd Mr. Blonde
    I think he's more talking about a large PVC pipe that you put the entire rod in. Maybe three or 4 inch PVC. Put a cap on the back of the pipe and a female adapter with a screw on plug at the end where you put the rod in at.
  11. May 14, 2017 at 10:26 AM
    rons23
    Ron
    Kill Devil Hills
    Yeah, that would be for like traveling abroad, then you would go with travel rods. I agree with you on that.
  12. May 14, 2017 at 10:28 AM
    15whtrd
    15whtrd Mr. Blonde
    But you could mount the pipe to the truck somewhere like the deck rail system.
  13. May 14, 2017 at 10:31 AM
    Out of town for work not til after Tuesday
    Skippy and Bob[QUOTED] like this.
  14. May 14, 2017 at 10:32 AM
    rons23
    Ron
    Kill Devil Hills
    That's an option Ron, always looking ahead.
  15. May 14, 2017 at 10:34 AM
    15whtrd
    15whtrd Mr. Blonde
    I realize the poles are too long for that. But it would fit corner to corner.
  16. May 14, 2017 at 10:41 AM
    Pipe i used was 2" pvc...notch i cut out was almost 3/4 of an inch wide inch n a half long so rods can sit and 2 one inch holes so i can screw to back of board.. length of pvc i believe is foot n a half...but now they already sell those white rod holders with the top part flanged out with notches n holes to secure few bucks a piece
    rons23 and NewImprovedRon like this.
  17. May 14, 2017 at 10:42 AM
    15whtrd
    15whtrd Mr. Blonde
    I was thinking those rubber straps I saw someone use to mount their fire extinguisher would work perfectly for the pipe. Shit you could even rig some plumbers tape and a couple of big washers with nuts and bolts.
    Even more stealth would be some black ABS pipe.
  18. May 14, 2017 at 11:49 AM
    rons23
    Ron
    Kill Devil Hills
    That's how i ROLL! Steve. Like the tide hahaha
  19. May 14, 2017 at 4:19 PM
    fishinfool
    Joe
    Bakersfield, Ca
    14 CM SR5 Silver
    None.... YET!!
    IMG_20170514_140328191.jpg IMG_20170514_140320778.jpg IMG_20170514_140320778.jpg
    Bob likes this.
  20. May 14, 2017 at 4:21 PM
    fishinfool
    Joe
    Bakersfield, Ca
    14 CM SR5 Silver
    None.... YET!!
    Don't know why it doubled up the 2nd pic.. but this is my "rack"... About 8 or so inches away from tailgate, so rods do not bounce off of it. I do not have a tool box and usually travel with reels on...
  21. May 14, 2017 at 5:25 PM
    Screenshot_20170514-191121.jpg Screenshot_20170514-191140.jpg Screenshot_20170514-191206.jpg Screenshot_20170514-191223.jpg i had wife go into garage and look for the J hooks tha screw to back she cant find..but this is what i made almost 10 years ago..pvc is foot in length..the metal straps are 1" wide galvanized..boards are 1x6 42" long it hung against the back of bed..then i bought a tool box and screwed it to box with a slight tilt back so that tool box could close
  22. May 15, 2018 at 8:16 AM
    Jesusquintana
    Jesusquintana New Member
    Roger
    Central Texas
    2018 Crewmax 4x4
    Have you looked at the bass master pros trucks? Most are tundras with the camper top deal on the back and some large pvc like tubes for rods. I don't have a camper top but would like to get a tube similar to what they use and mount them on the side rails when I go fishing.
    https://www.bassmaster.com/mike-iaconelli/kayak-craze
  23. May 15, 2018 at 8:29 AM
    DaBoro54
    DaBoro54 Beach Fisher
    Leveling kit, 285/70R18 EXOs
    My rod rack bolts to my tool box. Works well and I can move it between trucks.
    rons23, blue16 and NewImprovedRon like this.
  24. May 15, 2018 at 8:33 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
  25. May 15, 2018 at 11:30 AM
    thetwood
    thetwood New Member
    Louisville, CO
    2017 Blazing Blue Limited CrewMax TRD
    Kings, SPC, Icon Six Speed, Falken Wildpeak AT3w
  26. May 15, 2018 at 11:46 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    I guess it would depend on the type of fishing rod you are transporting.
    a buddy has one of these on his topper for his fly rods. The boxes are really nice and strong. Saw one after a roll over and the rods survived.
    http://www.flyrodbox.com/
    PNWOffroader likes this.
  27. May 15, 2018 at 1:09 PM
    thetwood
    thetwood New Member
    Louisville, CO
    If I had a topper I would have went with one of these solutions. Easy, durable and efficient.
  28. May 15, 2018 at 3:14 PM
    swede78
    swede78 Not so new member
    Lars
    westminster co
    2019 tundra platinum mgm crew max
    Nothing yet
    I will take some pics of my set up when I get home, holds 6.5ft rods to the inside of the bed.
  29. May 15, 2018 at 5:38 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
  30. Jun 29, 2018 at 6:21 AM
    ktugboat42
    ktugboat42 New Member
    Pete
    Cape Cod
    2018 Cement Tundra TRD Double Cab
    Ive got a set of these Big Johns adjustable rod holders bolted to my tailgate that work great. I'll carry rods up to 11' in it.
