First Time Tundra Buyer: Need Input
Discussion in '2.5 Gen Tundras (2014-2021)' started by VadersTundy, Jun 15, 2019.
  1. Jun 17, 2019 at 1:03 PM
    chadjamesr
    chadjamesr New Member
    Chad
    Atlanta
    2016 Tundra Platinum 4x4 Crew Cab
    Fox 2.5 w/ DSC Remotes F&R Coach Builder +3 Shackles RW Wheels w/285/75/17 Terra Grappler G2 Interior and exterior changed to LED Retrofit headlights with DS2 4.0 Morimoto LED fog lights Morimoto 40" LED bar in front bumper Retrax PRO Tonneau cover RCI front skid plate Crystalline tint on all windows and windshield P&P Rock sliders and full skip plates
    I would also suggest going with the CM unless you need the bed length. The CM is awsome with kids, in-laws, and dogs if you transport any of those. I had a friend who went with a double cab at first and then upgraded to the CM as his kids outgrew the DC.
    The biggest feature I would make sure the truck had is the optional 38 gallon gas tank for the SR5. This is even more important if you plan to tow. I love that my Platinum CM can go 500+ miles on a road trip without refueling. I remember with my Tacoma having to stop at each major city to refuel when on a road trip.
    For the tires you can go with 285/70/r18 if the offsets are right without rubbing. You could also look at 295/65/r18 and shouldn't have a problem rubbing. Both sizes will not hurt your MPG to much, at least it hasn't with mine.
    Most all the other features you can add on later if you want, but the above make the most sense to get from the factory to begin with.
  2. Jun 17, 2019 at 1:42 PM
    TacoWuzzaTurd
    TacoWuzzaTurd Loving my Tundra
    Scottsdale AZ
    2018 SR5 4x4 Crewmax, TRD Offroad
    6112s @1.9", TRD Dual Exhaust, rims, tires, jl audio system
    I added 275/70r18 only 1" larger than stock and it took my MPG down by 2mpg avg combined. Wouldnt recommend Adding suspension mods or tires for anyone wanting to tow 6000lbs+ on a recurring basis. Lifting the truck only further degrades towing capability.
  3. Jun 17, 2019 at 2:57 PM
    TomyTun
    TomyTun New Member
    CA
    2016 TRD Off Road, Crewmax, 5.7L Non-FFV
    None
    The 38 gallon tank comes with the SR5 upgrade package. It sure is nice to go longer between fill ups, especially on road trips.
    VadersTundy[OP] likes this.
  4. Jun 17, 2019 at 3:06 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I got my similar truck through costco for about the same price. DC 4x4 sr5.
    I thought it was a good deal. See if you can get them to add the extended warranty free. Sounds like they want to sell it badly. Hold em to it!
  5. Jun 17, 2019 at 6:10 PM
    VadersTundy
    VadersTundy [OP] New Member
    2019 black sr5 crewmax
    Well I went crewmax. Just got to work to ditch the chrome!
    TacoWuzzaTurd likes this.
  6. Jun 17, 2019 at 6:27 PM
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    2017 TUNDRA SR5 TRD OFF-ROAD
    TRD Pro Grilled, Color match bumper end caps, OEM LED headlights, MX4 Bed cover, GoRhino RB20,TRS LED Fog Lights, Camburg leveling kits, SR8 wheels, STT Pro tires 295/70/18 and heritage decal.
    Good choice and congrats!
  7. Jun 17, 2019 at 6:57 PM
    TomyTun
    TomyTun New Member
    CA
    None
    Great choice, and welcome to the club. Forgot how good black looks clean:)
  8. Jun 17, 2019 at 7:07 PM
    ardnuT 91’ notsuoH
    ardnuT 91’ notsuoH Colorado Texas Guy
    DM
    Houston, God Country USA
    ‘19 Cement CM
    Grille and bump color match Pro headlight swap Rear taillight swap Bumpers wrapped Antenna swap Tint with 3M Crystaline on windshield Husky mats BAKFlip MX4 (need to install) FRAC (need to install) Interior LED’s (need to install)
    ^^^ same truck full of little girls and love that they have the room they do and still can’t reach dads seat!
    VadersTundy[OP] and TOYOTRD8 like this.
  9. Jun 18, 2019 at 8:38 AM
    nodak67
    nodak67 New Member
    JR
    true but i shouldnt have to spend $400-$700 dollars for the same storage that the double cab already has.
