First Gen Tundra 4x4 blinking
Discussion in '1st Gen Tundras (2000-2006)' started by sniffierbird665, Sep 29, 2024.
  1. Sep 29, 2024 at 10:29 AM
    sniffierbird665
    sniffierbird665 [OP] New Member
    Cavan
    03 Tundra
    I recently purchased my 03 tundra and the previous owner told me that the 4x4 worked great. Stupidly, I took his word and didn't test it but I suspect he wasn't intentionally lying so I believe that the 4x4 probably worked semi recently.
    • When I hit the buttons they both blink respectively and don't go in, I also had somebody hit the button as I was under the car and I hear nothing from the ADD actuator or the Transfer Case actuator.
    • I checked both the fuse under the hood and the one in the drivers footwell.
    • I also jacked the front of the truck up and did my best to tap on the actuators as I was spinning the front wheels all to no avail.
    • The transfer case to front dif driveshaft spins freely no matter if the button is pressed or not.
    My next plan is to take a better look at the plugs although I have ensured they are fully pressed in.
    If I do clean an actuator's internals which should I start with?
    Any insight would be greatly appreciated, thanks
  2. Sep 29, 2024 at 11:03 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Jesus. Im fk'n dense sometimes. Thanks shifty.
    Welcome!
    Read the mega thread start to finish. It is a literal goldmine of information for common problems, fixes, etc.
    So ... you wanna buy / just bought a 1st Gen Tundra, eh?
    This thread is what you are looking for currently:
    4WD Issues
    9 times out of 10 it seems like the cause is corrosion under the actuator cap
  3. Sep 29, 2024 at 1:39 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Start with your transfer case actuator. Plenty of pics on this site to figure it out. Oh, and I shouldn’t have to say this, but play with the 4wd on loose pavement or dirt.
  4. Sep 29, 2024 at 1:45 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    …or going in a straight line.
  5. Sep 29, 2024 at 4:37 PM
    sniffierbird665
    Cavan
    03 Tundra
    cool thanks
