First gen on 34.8s
Discussion in '1st Gen Tundras (2000-2006)' started by tundra00prerunner, Aug 28, 2022.
  1. Aug 28, 2022 at 4:12 PM
    tundra00prerunner
    tundra00prerunner [OP] New Member
    Josh
    2000 Toyota Tundra sr5 v8 4wd
    I’m wonder how big of a lift and what all needs to be done to be able to put 34.8 tires on a 2000 tundra with no rubbing on anything. i already have the wheels and tires which the wheels are 16x10 with a -38 offset and the tires are 315/75r16 which is 34.8x12.4 in inches
    5N0W808 likes this.
  2. Aug 28, 2022 at 4:33 PM
    Beefnbread
    Beefnbread Electric Soup
    Oregon
    2000 SR5 Tundra 4x4
    Without a serious lift kit (Like the sub bracket lifts), you are pretty much only able to lift it 3 inches. If you plan on going that route, 3 inches will clear if you do a lot of cutting.
    There are some videos on youtube on what to cut.
    5N0W808 likes this.
  3. Aug 28, 2022 at 5:18 PM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    I had an 01 with a 5" lift and 3" body lift. 35x12.5r18 only had a minor rub when full lock to the left.
    No cutting
  4. Aug 28, 2022 at 5:49 PM
    shifty` We call it “riding the gravy train”
    Probably important to list cabs in this thread, y'all.
    We have guys with double cabs who have the exact same lift as access cab trucks, and the access cabs are able to clear more tire with lesser or zero rub.
    The double cab is a distinctly different beast, with what seems like more tire limitations, if we go by direct member experience.
    Hooptytrix[QUOTED] likes this.
  5. Aug 28, 2022 at 6:01 PM
    Hooptytrix
    Dirty South
    2000-2002 only had standard cab and access cab, double cab is 03-06.
    OP has a 2000 so we be talkin bout 1st gen 1.0, not the fancy 1.1 (03-04 DC wit upgraded transmission) or extra fkin fancy ass 1.2 (05-06 DC wit VVTI and new transmission).
    I'm guilty though, I went from a 2000 to a 2001 then to the extra fkin fancy ass 2005 DC VVTI. Regret it though, should have kept my 01
    DarkMint likes this.
  6. Aug 28, 2022 at 6:02 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    Whew 16x10’s. I’d suggest some coil overs of your choice, Spc upper control arms, solo lower control arms, and getting the BFH and sawzall out
    that upper and lower control combo are gonna give you the most adjustability. As long as you can find a shop that knows what there doing
    5N0W808 likes this.
  7. Aug 28, 2022 at 6:12 PM
    Hooptytrix
    Dirty South
    I was on 18x9 rims, I don't remember the offset. I can't say if 16x10's would work without rub
  8. Aug 28, 2022 at 6:33 PM
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
    I've got 33.9 x 11, 3in Toytec up front with SPC control arms on a 05 double cab. I rub frame at the rear of the front tire. You need a lot of lift to pull off the tires you want. I had to cut the side steps back to clear these as well.
  9. Aug 28, 2022 at 6:54 PM
    Cummins3500
    Logan
    Probably be better off with long travel and fiberglass up front:anonymous:
    also out of curiosity who makes the wheels?
    Siebler and alb1k like this.
  10. Aug 28, 2022 at 8:00 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I think @shifty` is right about the differences between the models. I don't think you are far off on the LT and fiberglass. I'm very confident stuff will need to be cut. And, I can imagine the front fenders will be bumps stops at least one time if not modded hard.
  11. Aug 28, 2022 at 8:20 PM
    Hooptytrix
    Dirty South
    This was my 01. 5" tuff country lift, 3" body lift, camburg upper control arms.
    37x12.50 20x10 rim don't recall offset. They rubbed in quite a few places when you turn the wheel.
    I purchased the truck like this.
    35x12.5 18x9.5 rim. They rubbed the frame a bit at full tilt to the driver's side
    5N0W808, des2mtn, bmf4069 and 2 others like this.
  12. Aug 28, 2022 at 8:36 PM
    Hooptytrix
    Dirty South
    The offset will play a major factor in whether or not you have to start cutting things.
    5N0W808 likes this.
  13. Aug 28, 2022 at 9:57 PM
    Casper421
    In the woods
    06 DC
    No rubbing on anything? Sell the 315’s and run 285’s on a 6” bracket lift.
    bmf4069 and des2mtn like this.
  14. Aug 28, 2022 at 10:09 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    nom nom nom
    5N0W808 and Hooptytrix[QUOTED] like this.
  15. Aug 29, 2022 at 6:59 AM
    tundra00prerunner
    Josh
    I think i’m going to put them on an see how bad it is if they are real bad i’m going to try spacers and a jack it 5” suspension lift
  16. Aug 29, 2022 at 7:04 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    shifty`, 5N0W808, 2006Tundra and 3 others like this.
  17. Aug 29, 2022 at 7:16 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    But you're a terrible decision maker so this should be fine for you
    des2mtn[QUOTED] likes this.
  18. Aug 29, 2022 at 7:24 AM
    Casper421
    In the woods
    06 DC
    Trust me, it’s gonna be bad! I’m one of the very few dumbass’s who tries to wheel 35’s on 3” of lift. Our wheel wells aren’t meant to fit 35’s.
  19. Aug 29, 2022 at 8:09 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    What's up with that Ridgeline in your avatar lol
    bmf4069 and Casper421[QUOTED] like this.
  20. Aug 29, 2022 at 8:13 AM
    Casper421
    In the woods
    06 DC
    Life goals man, life goals!
    FrenchToasty and des2mtn like this.
  21. Aug 29, 2022 at 8:15 AM
    Hooptytrix
    Dirty South
    The Tundra has higher resale value so it stays home nice and safe whenever Casper is out doing dumb shit (90% of shit men do qualifies as something dumb)
    bmf4069 and texasrho83[QUOTED] like this.
  22. Aug 29, 2022 at 8:33 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah but then you never really have fun with the Tundra.
    5N0W808 likes this.
  23. Aug 29, 2022 at 8:34 AM
    des2mtn
    SW
    Tonto cover
    #ridgelinegang
    FrenchToasty, bmf4069 and Casper421 like this.
  24. Aug 29, 2022 at 10:15 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    It's a 1st gen thing.
    @Casper421 when did you change that? I dig it.
  25. Aug 29, 2022 at 11:02 AM
    Casper421
    In the woods
    06 DC
    :notsure: Few weeks ago. Ridgeline body on a Humvee chassis.
    bmf4069[QUOTED] and 5N0W808 like this.
  26. Aug 29, 2022 at 1:04 PM
    tundra00prerunner
    Josh
    i will keep y’all updated
  27. Aug 29, 2022 at 5:24 PM
    Hooptytrix
    Dirty South
    Yup, just a little bit though
