First Camper Trailer
Discussion in 'Towing & Hauling' started by cmb46, Mar 27, 2020.
  1. Mar 27, 2020 at 6:57 AM
    cmb46
    cmb46 [OP] New Member
    2008 Tundra
    So my wife and I plan on buying a camper this weekend. It weighs approx. 3700lbs. I just had new brakes installed on my 2008 tundra and was wondering how does a trailer with brakes work. I read about the prodigy brake controller but how does that communicate with the trailer? The wire harness on the Tundra connects to the prodigy and I assume the round connector by the hitch is what communicates but not sure. If anyone can explain that would be greatly appreciated.
  2. Mar 27, 2020 at 7:44 AM
    ezdog
    ezdog New Member
    Gateway To The West
    First off you need to use a cable and harness system on the truck that mates to the trailer wiring completely enough to send a brake control voltage to the trailer.
    Just having the right connectors between the two does not always mean that a brake control signal can be sent as sometimes the truck is not wired entirely as it might seem and without the control wire,no braking.
    The Brake Control sends a voltage down the wire in the harness to the trailer brakes and the brakes activate based on that voltage.
    There are different types of controllers and the early and now cheaper ones send a fixed voltage basically that you can set from the control but that is not always in any way related to the braking that the trailer/truck combo needs at any time,just a constant set voltage.
    The better controls and they are not too pricey really send a signal proportional to the brake pedal pressure you are applying to the vehicle at any given time.....in theory at least.
    So the harder you brake the truck the harder they brake the trailer.
    This is what you want.
    The Prodigy and in fact all of the Tekonsha brand controls are widely accepted as the best of these and work great for me and everyone that I know that uses one.
    There is also a lever on the controls that let you apply added brake as needed in case you need to panic stop for example or want to use the trailer brakes independent of the truck brakes for controlling sway for example which can be really handy too.
    Does that answer the question?
    This is without going into much detail of course too.
  3. Mar 27, 2020 at 8:14 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    I have a Tekonsh P2.
    You buy the brake controller and the harness that connects it to your Tundra. Then your camper to the 7 way plug on the back of your Tundra. If everything is communicating properly, then the display on my P2 shows “C”. I think when it is not connected or not communicating correctly, then it shows either “n” or “na”.
    You can also test this by applying the brakes manually on the controller with the lever. While driving slowly, apply the manual brakes on the controller and you should feel the camper slow you down. You don’t want it to fully lock harshly, but you do want it to be able to slow the camper and truck down without using the truck’s brakes. There are YouTube videos you can watch about adjusting the camper’s brakes at the drum and adjusting the power at the brake controller.
    Good luck and congrats.
    GODZILLA likes this.
  4. Mar 27, 2020 at 8:19 AM
    cmb46
    2008 Tundra
    Thank you guys that’s what I wanted to hear. So I checked the 7 way plug and mine was really corroded and actually a pin broke off since it was so corroded. I called the dealer and they have 1 in stock so getting a new one today. I just hope I can get the rusted bolts off.
  5. Mar 30, 2020 at 11:37 AM
    lonelydriver
    lonelydriver New Member
    make sure to soak the new one in dielectric grease so that doesnt happen again
  6. Mar 30, 2020 at 6:15 PM
    cmb46
    2008 Tundra
  7. Apr 3, 2020 at 4:14 PM
    Cpl_Punishment
    Cpl_Punishment Young men never die.
    Rosy
    2020 MGM SR5 CM 4X4
    What make and model? Looks like about what my wife and I are looking for.
  8. Apr 3, 2020 at 7:17 PM
    cmb46
    2008 Tundra
    2005 keystone zeppelin 2, 24’ long
    Cpl_Punishment likes this.
  9. Apr 3, 2020 at 7:54 PM
    biebs96
    PA
    Do you need the brake controller harness? I have one.
  10. Apr 3, 2020 at 7:59 PM
    BlueDream
    BlueDream New Member
    2015 Tundra Dbl cab SR5 5.7
    6" procomp stage 3 lift, Method NV 18x9, Cooper STT pro 305/70R18, AFE air cleaner, LED fogs, Ranch hand Grille guard, Rhino liner, retrax bed cover, Flowmaster Duals, 15% Tint, vinyl chrome delete
    looks like you could use some airbags in the rear, to level out when towing.
    Skey44 likes this.
  11. Apr 3, 2020 at 8:30 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Sweet! What does a trailer like this cost?
  12. Apr 4, 2020 at 3:43 AM
    cmb46
    2008 Tundra
    My wife and I paid $5600 for it.
    georgiey22 and Cpl_Punishment like this.
  13. Apr 4, 2020 at 8:54 AM
    georgiey22
    We'll start shopping soon. We have two children under 5 and staying in hotels isn't easy.
