Firmer shifts after pan drain and fill
Discussion in '2nd Gen Tundras (2007-2013)' started by 1rooster, Mar 10, 2020.
  1. Aug 2, 2024 at 1:12 PM
    #151
    1rooster
    1rooster [OP] New Member
    Tony
    2007 crewmax
    yes, the 3rd to 4th issue resolved and the truck has been doing great, up until now. I had to put a new starter on it about two years ago but that wasn’t that bad to replace. I went with an OEM denso hoping it could go another 15 years
  2. Aug 2, 2024 at 8:06 PM
    #152
    SpooledReel
    SpooledReel Insufficient Funds
    RickyP
    Spanish Fort, AL
    2015 Tundra CM Limited 4x4
    Was it the zip kit that ultimately solved your issue?
  3. Aug 3, 2024 at 10:03 AM
    #153
    1rooster
    Tony
    2007 crewmax
    Yes I believe. Over time I just stopped caring about it (lost interest) and just drove it. I realized it it was dependable and shifting good so I stopped being so ocd.
    SpooledReel[QUOTED] likes this.
  4. Aug 3, 2024 at 5:18 PM
    #154
    blackdemon_tt
    blackdemon_tt Battery Slayer
    It shifts to 2nd to a point then back to 2nd to pick up speed. In other words 1st gear slips. Will probably have 0 power and just like turbo lag just picks up and gos.
    1rooster[QUOTED][OP] likes this.
  5. Aug 6, 2024 at 6:56 PM
    #155
    1rooster
    Tony
    2007 crewmax
    Finally had some time to pull the trans pan off and do an inspection. Fluid looked great and pan and filter were flawless. Barely anything on the magnets. Shift solenoid S1 ended up being bad. It was reading 61.5 ohms when it should have been 11-15 ohms. SLT read 5.7. Normal is 5-5.6
    Put it all back together with some fresh fluid and went on a 20 mile ride and done great. I’ll report back if anything changes
    07 Tundie and hagrid like this.
  6. Aug 15, 2024 at 4:07 PM
    #156
    1rooster
    Tony
    2007 crewmax
    It is still running strong after several hundred miles. I’m glad it was an easy fix.
    07 Tundie likes this.
