Firestone Riderite air suspension
Discussion in '2.5 Gen Tundras (2014-2021)' started by rds95991, Oct 3, 2019.
  1. Oct 11, 2019 at 8:58 AM
    MAK
    MAK Searching for Gnarnia
    San Diego
    2014 SilverSky DC TRD Limited
    FRAC, Console safe, Amazon special-console organizer, Rhino liner, Pace Edwards retractable tonneau cover, Drivers side swing case, AJT shift knob and matching key fob!, Interior trim De-chrome with Faux carbon wrap, color matched door handles and mirror covers, Maxpider 3D Floor mats, Custom Dog bed in DC area, BFG Radial TA KO tires, 18 x9 +20 Fuel Shok wheels, Toytec Boss 3:1(shackles), White Knuckle offroad sliders w/diamond plate step, Bumper skins, Blackout badges, Firestone airbags, RCI skid,
    ^ Where did you mount the compressor? I'm assuming it's a simple install.
  2. Oct 11, 2019 at 3:13 PM
    Zero One Actual
    I decided to remove my left rear seat and mount it internally behind the seat in the space there behind the seat and the firewall. It fits perfectly there, wires up easily there and is never exposed to any elements like if it were mounted on frame. When it inflated or deflated I can still carry on normal volume conversations. But it’s only ever on when I use remote or on start up to get PSI correctly. I leave remote on visor and have three presets already ready to go.
    Pudge likes this.
  3. Oct 11, 2019 at 4:57 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Great idea. There are plenty of rubber grommets on the cab floor to run wires and air hoses through. I would not have thought of that placement.
  4. Oct 11, 2019 at 7:42 PM
    Zero One Actual
    I can’t get pictures for another week. I am traveling for work right now. But if you can wait a week, I will post pics here.
  5. Oct 11, 2019 at 9:30 PM
    MAK
    San Diego
    Interesting. I was thinking of mounting it somewhere under the bed, on the frame or something....
  6. Oct 11, 2019 at 10:15 PM
    Red Freighter
    Red Freighter Red Freighter
    Oregon City
    2013 double cab sr5 trd red
    2014 TRD wheels and TRd pro center caps. Stock 2014 running boards. Stereo gps dvd deck two 12" subs w/amp. Dvd Headrests. Rear air bags with compressor and air tank.
    Run individual air lines to each airbag. if you only use one air line with a tee the pressure from one air bag can increase the pressure in the other bag.
    When you go thru a turn with a heavy load the outside bag will be compressed sending pressure to the inside bag causing the the vehicle to lean more.
  7. Oct 12, 2019 at 5:10 AM
    Zero One Actual
  8. Oct 12, 2019 at 9:36 AM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    I had always been told that. And I think it makes sense on a big rig since they dont have leaf springs to dampen the effect of air traveling between the bags. But after 100k of towing/heavy hauling miles in 1/2 and 3/4 ton trucks I actually think it is safer to have bags tied together. It is more dangerous to have one bag at 40psi and the other at zero. I ran a few work trucks with heavy loads in the bed with separate lines and in extreme cold a line would fracture and empty a bag, which would immediately try to pull me to the low side and create a huge pucker incident. Now when I have a leak, both bags deflate at the same time and I can fix it later. This was especially important when others would be driving my truck.
    But I am no expert, just found what seems to work best for my driving style.
  9. Oct 12, 2019 at 10:01 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I'm running a single air line also, Not towing much weight, so no issues ever.
  10. Oct 12, 2019 at 10:55 AM
    Zero One Actual
    My bad!!
  11. Oct 12, 2019 at 1:51 PM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    decided to go with
    Suspension Kit by Timbren
  12. Oct 28, 2019 at 1:14 AM
    Leetomnsx
    Leetomnsx New Member
    2016 Toyota Tundra Platinum
    Air lift, black out emblems, wheels, tonneau cover, tires, led lighting, hidden step rail, remote start.
  13. Oct 29, 2019 at 2:00 PM
    RideorDie
    RideorDie New Member
    Denver
    Took 2 hrs, 2 sets of hands, and a six pack. Easy. Clean. Enjoy the way it rides, but I carry 1.5k lbs daily and will likely add a leaf to improve ride quality slightly.
