Fire Pit chit chat
Discussion in 'Garage / Workshop / Home Improvement' started by Outbound, Apr 22, 2020.
  1. Apr 22, 2020 at 10:25 AM
    Outbound
    Outbound [OP] SSEM #2.5, AmeriCanadian, OG 1st Gen Rabble Member
    Aaron
    Northern Alberta
    2022 CrewMax Third Gen, 2005 DoubleCab Best Gen
    I'm going to use some of my down time to build a fire pit in my backyard. Right now, I'm debating if I should buy the raw materials and build it myself or if I should grab one of the "kits".
    I have to meet the following bylaws with regard to construciton:
    - The Fire Pit should be either dug into the ground, or constructed above ground in a manner which will prevent the fuel from falling out of the container
    - The above ground portion of the pit is constructed of stone, masonry, metal, or other non-combustible material
    - The Fire Pit should be no more than 3 feet in diameter or equivalent size if rectangular
    - The Fire Pit shall be covered by a substantial screen or grate with openings not to exceed 0.5" in any dimension
    I'm considering just using paving stones or landscaping blocks to build the pit itself. However, I would need to figure out what to use for the screen. If I can source screen material, I think I can build something cheaper than a kit. I was unable to find anything suitable from our scrap bin at work before my lay off. Unfortunately, I don't have access to a welding machine now that I'm laid off either so anything I find will need to basically be pre-fabbed or only require minor cutting and fitting.
    Alternately, there is this kit which includes a screen.
    https://www.rona.ca/en/stackstone-firepit-39925064
    nopsFU and Mountun Goat like this.
  2. Apr 22, 2020 at 10:29 AM
    Azblue
    The Dirty T ( ^_^)_且
    Really, bylaws for a backyard fire pit?
    Canada is dumb. :p
  3. Apr 22, 2020 at 10:33 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    @TXRailRoads73 built one and might have some pointers and suggestions.
  4. Apr 22, 2020 at 10:36 AM
    Outbound
    Aaron
    Northern Alberta
    I'm on a city lot so it kind of makes sense. I need to get a permit to burn as well. $10 per year for that. But yeah, as a general principle it's annoying. LOL
    TokerJoker and Azblue[QUOTED] like this.
  5. Apr 22, 2020 at 10:41 AM
    Boerseun
    Boerseun New Member
    Ferdie
    Sarasota Florida
    2026 Limited, Wind Chill Pearl, CrewMax 4x4
    The stone part would be easy to do without having to buy a kit. The screen is a little difficult without a welder. I would suggest buying the stone similar to that in the kit that you have shown, and do it with a 22" diameter, the size of a weber kettle. You can buy a 22" weber grill grate that will then fit in that opening. Buy 2 pieces of rebar about 30" long and install in the top layer of brick, criss cross, which will give you a surface to lay the grate on.
    The grate will have long 'slots' instead of square openings - it depends how tight your bylaws are regarding that. If it is an issue, get 2 grates and lay them on top of each other with one turned 90 degrees to the other one, creating square openings, or if you have a grinder, buy a piece of expanded metal - you can get 24"x24" pieces at Home Depot. Cut a 22" circle and tie it to the weber grill with bale wire (not zip ties! lol).
  6. Apr 22, 2020 at 10:48 AM
    DaBoro54
    DaBoro54 Beach Fisher
    Leveling kit, 285/70R18 EXOs
    I did mine with stone. No grate needed here.
    I think if I did I would go to the hardware store and get some heavier wire. Use bar stock to bolt the wire to it. Make a handle and you’re in business. Later on if you want to make it fancy when you get a welder you could tack it all up
  7. Apr 22, 2020 at 10:50 AM
    Outbound
    Aaron
    Northern Alberta
    I'll check out the expanded metal option. I was looking into that. I would like the option to cook over the fire with a cast iron pan so I'll see what I can come up with that can support it. I really need to buy a welding machine for my garage. LOL
    Boerseun likes this.
  8. Apr 22, 2020 at 11:07 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    We went with a city slicker pit lol our lot is smaller so it made more sense.runs on propane or natural gas.
    These are a good buy at Costco right now. 65000 BtU’s. Once I get property I’ll build I nice one I have a couple crusher cones that work awesome for a pit.
    AggiePhil, equin, toyofan87 and 8 others like this.
  9. Apr 22, 2020 at 11:20 AM
    It was a kit from Home Depot
  10. Apr 22, 2020 at 12:16 PM
    Doylfish
    Doylfish New Member
    2016 Tundra 1794 Crewmax
    Is that really true? I’m not pretending to know your laws, but I’m in a town where we are required to get a permit to ‘burn’ (think brush pile) as well ... however a fire for ‘cooking’ wink wink (in pit or not) no permit is needed.
    That is why whenever I’m burning whether the intent is for s’mores for the kids or chores for me there is always food around ie marshmallows or hotdogs
  11. Apr 22, 2020 at 12:49 PM
    Boerseun
    Boerseun New Member
    Ferdie
    Sarasota Florida
    In my County we are technically also not allowed to have open fires, but a bbq pit is an exception, so as long as you have a bbq grate handy to place over the fire when someone shows up you should be good. Kind of silly, but that's how it works.
  12. Apr 22, 2020 at 1:36 PM
    Outbound
    Aaron
    Northern Alberta
    Yep
    https://www.cityofgp.com/city-services/emergency/fire-department/residential-fire-pit-permits
  13. Apr 22, 2020 at 4:34 PM
    SunTundra413
    SunTundra413 New Member
    Ned
    Massachusetts
    2019 Black TRD Sport DC 4X4
    ARE Cap
    Here's my fire pit. I didn't build it, it was there when we moved in.
    Unfortunately, the previous owner had been burning all of his construction debris in it for the past 10 years so I had quite a job shoveling all of that shit out of it. I was cursing him with every shovel full of nails, screws, electrical fixtures, melted plastic, etc. I must have pulled about 75 joist hangers full of nails out of there along with about 50 drawer tracks from furniture that the asshole burned in there too. I'm still taking it to the transfer station a few bags at a time.
    But, the fire pit is great now that it's had all the toxic waste cleaned out.IMG_20200422_180756.jpg
  14. Apr 22, 2020 at 4:59 PM
    Home Depot kit, believe 44" across
    GAknight, DalTee, kevine0001 and 10 others like this.
  15. Apr 22, 2020 at 5:03 PM
    Outbound
    Aaron
    Northern Alberta
    That looks nice. What's the inner ring made of?
  16. Apr 22, 2020 at 5:07 PM
    Heavy gauge steel, can't tell you how thick, sorry, but it holds up good, it's been through over 20+ fires, kit doesn't come with rock that sits in between steel n pavers, that ring is 2 pieces, 4 bolts
    Outbound[QUOTED][OP] likes this.
  17. Apr 22, 2020 at 5:20 PM
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    Did you get that in the store or online? That fire pit looks really nice.
  18. Apr 22, 2020 at 5:49 PM
    biebs96
    PA
    20x26 patio then stoned area for the pit.
  19. Apr 22, 2020 at 6:28 PM
    55kcement
    55kcement New Member
    Troy
    Sonora ca
    2020 TRD Off Road limited Double cab
    Currently none
    8750313D-64F8-48D3-8FC7-33C794B1B266.jpg A person could always get something like this and just stack your brick around it ! I think it’s around $250
    Mountun Goat and Outbound[OP] like this.
  20. Apr 22, 2020 at 6:32 PM
    Theonlyway
    Theonlyway New Member
    User
    This is my goal
  21. Apr 22, 2020 at 6:36 PM
    Outbound
    Aaron
    Northern Alberta
    I would love a yard like that. Houses with that much greenery and trees are expensive around here though. LOL
  22. Apr 22, 2020 at 6:40 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    That is my goal for retirement a nice green roomy outdoor area to chill maybe entertain friends a family ! That back yard is sweet.
  23. Apr 22, 2020 at 7:17 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Wallygator and Outbound[OP] like this.
  24. Apr 22, 2020 at 8:34 PM
    Sunnier
    Sunny
    San Diego, CA
    Um. I’m pretty sure my metal insert from an old washing machine is rocking those bylaws!
  25. Apr 22, 2020 at 8:35 PM
    Sunnier
    Sunny
    San Diego, CA
    Except those irregular pavers will be s tripping hazard :bananadead: to all the drunks at the party. :rolleyes: said a friend of mine that read it somewhere.
    Northern and FrenchToasty like this.
  26. Apr 23, 2020 at 6:03 AM
    xtyfighterx
    Ty
    North Idaho
    Store it’s cheaper $339
    vhstejskal[QUOTED] likes this.
  27. Apr 23, 2020 at 7:28 AM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    Ok mom
    Bob_Wiley and Sunnier[QUOTED] like this.
  28. Apr 23, 2020 at 7:41 AM
    Sunnier
    Sunny
    San Diego, CA
    Ha! It’s us moms I’m talking about. ;)
    Northern, speckmon[QUOTED] and Kung like this.
  29. Apr 23, 2020 at 8:22 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    2026 Lunar Rock CM TRD OR
    This isn't mine but I built one almost identical to it. Went to a tractor salvage yard and picked up an old rim from a Ford 8N and wrapped it in retaining wall block. It worked great and cost me about $75. Tractor-Rim-Fire-Pit-09.jpgThe rim had the clamp rings inside it which worked great to support a cooking grate. I had a friend cut me some expanded steel to fit inside for cooking over a bed of coals.
  30. Apr 23, 2020 at 8:37 AM
    Outbound
    Aaron
    Northern Alberta
    That looks really good. :)
