Finding the GCWR of my 2018 Tundra
Discussion in 'Towing & Hauling' started by KirtH, Aug 11, 2020.
  1. Aug 11, 2020 at 11:45 AM
    KirtH
    KirtH [OP] New Member
    I am trying to figure out the GCWR for 2018 Tundra. My door tag gives me the GVWR no GCWR?
    I have gone to the Toyota website and my account entered the VIN, no where on the site does it show the GCWR?
  2. Aug 11, 2020 at 1:46 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    If I recall correctly, there's a table in the owner's manual.
    mountainpete likes this.
  3. Aug 11, 2020 at 1:53 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Match up your model code (USK56L-CRTLGA) according to the chart below. If you have a 4WD, standard box, trailer towing package and large fuel tank it's 15,400 lbs.
  4. Aug 11, 2020 at 1:59 PM
    mountainpete
    For the reference of others, these are all of the related pages from the USA 2018 manual.
    DOUBLECAB:
    CREWMAX:
    ColoradoTJ and Cpl_Punishment like this.
  5. Aug 11, 2020 at 2:00 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    Yep, beat me to it.
    mountainpete[QUOTED] likes this.
  6. Aug 11, 2020 at 3:19 PM
    KirtH
    Thank you
    ColoradoTJ likes this.
  7. Aug 12, 2020 at 10:18 AM
    KirtH
    Okay if I got this straight. The GCWR of truck according to the manual is 15,400 lbs. The GVWR of my truck is 7100 lbs. 15,400 - the 7100 = 8300 lbs which should be the max I can tow.
  8. Aug 12, 2020 at 10:30 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Towing weight is one thing, however you will probably run out of payload long before ever reaching max tow weight. If I saw your sticker correctly you have 1300 payload which includes passengers, cargo, accessories added and whatever the tongue weight is of the trailer. Add the tongue weight and the cargo and items you are carry.....should be under the 1300 lb.
    GODZILLA and Cpl_Punishment like this.
  9. Aug 12, 2020 at 10:50 AM
    Frichco is correct. Towing weight is seldom met before you max the payload on a Tundra. It's the one weakness of these trucks. Head over to the towing section of the forum and you'll have plenty of info to brush up on.
    Freedom 2020 and Cpl_Punishment like this.
  10. Aug 12, 2020 at 10:58 AM
    Should be 9100 lbs according to the chart.
