Finally got the ok for a Supercharger
Discussion in 'Performance and Tuning' started by 19PlatinumCrew, Aug 10, 2023.
  1. Oct 11, 2023 at 4:21 PM
    #331
    19PlatinumCrew
    19PlatinumCrew [OP] New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    UPDATE......problems with truck after dyno, did not elaborate in text message but said he will call me tomorrow
    WinterWarlock21 likes this.
  2. Oct 11, 2023 at 6:39 PM
    #332
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    That’s a shitty message to get
  3. Oct 12, 2023 at 4:26 AM
    #333
    19PlatinumCrew
    Dave
    The biggest problem with all of this needless Drama is I don't have ANY TRUST in the end product. Yea they can get it running,might run great when I pick it up but what about the long term.
    This is my retirement/towing truck that up until this happened new it would get me and the wife home,yea anything can break but I've lost the confidence that it will happen when we are traveling. We are all Adults,make our choices so this may be an expensive lesson. Do your homework before you choose a shop,I thought I had......
  4. Oct 12, 2023 at 4:30 AM
    #334
    I’m sure they’ll get it sorted.
    Saltyhero13 likes this.
  5. Oct 12, 2023 at 4:32 AM
    #335
    19PlatinumCrew
    Dave
    Thanks....at this point I can only hope so
  6. Oct 12, 2023 at 4:51 AM
    #336
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    my $.02 >>>keep in mind my $.02 is devalued do to me being the Forrest Gump of Forced induction.
    once you get it tuned & settled, you should be fine. short of fuel pump drama.
    I thank my luck stars every time I get in my truck....if you recall, I had my S/C put on before the ECU was even open! and went thru the Harrop connector issue.
    and I hear you on the daily driver thing. I use this truck for work, so that is my primary reason for driving it like a grandpa.
    these forum guys taught me (which is hard to do!) to watch your AFR...like all the time in your first few days/weeks. Once I reach PE, my AFR immediately goes to low 10's. as should yours.
    If I get into the pedal, it ain't for long. it doesn't need to be...you'll hit 70mph quickly.
    I sincerely wish you well & thanks for the updates. I continue to send positive mojo in your general direction.
    Saltyhero13 and e30cabrio like this.
  7. Oct 12, 2023 at 4:53 AM
    #337
    19PlatinumCrew
    Dave
    Thanks..I need all the positive mo jo I can get right now.....can't sleep and Moma ain't happy either.
    Mdl likes this.
  8. Oct 12, 2023 at 6:01 AM
    #338
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I agree with nobody, I also had a bunch of drama (fuel pump) that included it stranding me 250 miles from home but now that it has been 100% for months (just awful MPGS) I love it!
    nobodyintexas and Mdl like this.
  9. Oct 12, 2023 at 6:35 AM
    #339
    19PlatinumCrew
    Dave
    Funny.....just realized that tomorrow pick up is Friday the 13....this is why I don't gamble used all my luck up when I met my Wife
  10. Oct 12, 2023 at 1:35 PM
    #340
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    What was up with fuel pump? Their idea of a 450 fitting in a standard canister? @19PlatinumCrew did they state what your issue was? Good Luck!
  11. Oct 12, 2023 at 3:05 PM
    #341
    19PlatinumCrew
    Dave
    Another Update.........Drum roll..........Bricked the ECU.....yes sports fans National Speed the premier performance shop has bricke my ecu yesterday trying to load the final tune
    They are supposedly getting a New ecu overnight and will use a 3rd party to reprogram it....what a cluster f!!k
  12. Oct 12, 2023 at 3:22 PM
    #342
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    I don’t even have words. I’m so sorry.
    nobodyintexas and Saltyhero13 like this.
  13. Oct 12, 2023 at 3:24 PM
    #343
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    FFS!:mad:
  14. Oct 12, 2023 at 3:27 PM
    #344
    19PlatinumCrew
    Dave
    At this point all you can do is play the hand that's delt to you. My problem is they are using a 3rd party to program it so if anything goes wrong they will probably blame them. So how is your truck running.....
  15. Oct 12, 2023 at 3:40 PM
    #345
    Saltyhero13
    Saltyhero13 Throbbing Member
    Oh geez. What a fucking goat rope! Saddened to hear about the terrible experience you are having with them. Regret recommending them after having two of three positive experiences with them.
    I hope they get it all sorted for you.
  16. Oct 12, 2023 at 3:46 PM
    #346
    19PlatinumCrew
    Dave
    Dude ...the only people at fault is National Speed, everyone asks for recommendations, we scour reviews and you pray it all works out this is the new way nobody seems to have pride in the job and do it right......let's get it out the door asap is the norm.
    Saltyhero13[QUOTED] likes this.
  17. Oct 12, 2023 at 3:48 PM
    #347
    WinterWarlock21
    South Jersey
    knock on wood still running great. No check engine light. Nothing. I wonder if national speed is fin3 with magnuson but can’t figure out the harrop?
  18. Oct 12, 2023 at 3:51 PM
    #348
    19PlatinumCrew
    Dave
    What is really concerning is Not One Call from a manager or someone that is in charge.....and I don't think the guy I'm dealing with is the Boss,if he is God help them.
  19. Oct 12, 2023 at 3:52 PM
    #349
    19PlatinumCrew
    Dave
    Looks to be an issue
  20. Oct 12, 2023 at 4:45 PM
    #350
    Saltyhero13
    I feel terrible hearing about your negative experience. I would have never expected this from them.
    My first guy was horrible. The motherfucker never escalated my issue to a tech or management. I thought he got fired but his lackadaisical attitude sounds like the same guy you are dealing with. Chris from Harrop helped me get sorted and one of the guys from the General SC thread verified the issue.
    My next two project were smooth minus the tranny jizz incident; one of the project guys even responded to my questions on weekends and his days off. QC was on point and they were proactive about updates.
    Nat Speed did have some shit Google reviews but they seems to be around centered around a few specific years. Seems like that shop goes through waves of great and terrible service.
    What time are you picking up tomorrow?
  21. Oct 12, 2023 at 5:07 PM
    #351
    19PlatinumCrew
    Dave
    Not getting it till Monday, ecu should be in tomorrow late afternoon then they need to set up that ecu to the truck as it was explained to me.
    Mdl likes this.
  22. Oct 12, 2023 at 5:09 PM
    #352
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Maybe someone needs to work a Saturday....
    You're being quite patient, kudos to you.
  23. Oct 12, 2023 at 5:33 PM
    #353
    19PlatinumCrew
    Dave
    I'm fortunate that the truck is a garage queen and used for weekend camping trips,got a beater for everyday duties.
    I think that the situation requires a level head for now
  24. Oct 12, 2023 at 7:33 PM
    #354
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    A level headed response usually gets things moving along but don't be a door mat either. Modding a vehicle has its own short falls we all have responsibility for. They need to stand behind their work and nake it right. At least your not getting it on the 13th...
  25. Oct 13, 2023 at 2:17 PM
    #355
    19PlatinumCrew
    Dave
    UPDATE.......I had to call AGAIN for a status on the bricked ecu replacement,was told everything has been updated and transferred over to the New ecu and I can pick it up on Monday.....but we have played this game before.
    I have tried to give everyone the events as they have happened, I would like to thank everyone who has helped me through this cluster f...k and would like opinions on the compensation that I feel is owed to me for the time and expense that has been incurred. They say everything has been fixed,they say it was installed correctly, realistically I have waisted about 13 hours and a tank of fuel for me and my wife. What do you guys feel is fair....truck has been there for 2 weeks.
    reywcms likes this.
  26. Oct 13, 2023 at 2:51 PM
    #356
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    You might have to see what they decide to invoice you for first.
    Mdl and Saltyhero13 like this.
  27. Oct 13, 2023 at 2:54 PM
    #357
    19PlatinumCrew
    Dave
    I do realize that just wanted extra eyes on a bad situation....they still have the truck and I still owe them 3200.00 from the original estimate.
  28. Oct 13, 2023 at 4:24 PM
    #358
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I would expect to pay original estimate
    all the extra time is on them
    shit happens
    I waited a week just to get my gauges put in. One of the gauges was broke from factory
    I would ask for extended priority attention if something goes wrong in the next 60 days. In writing
    you’ll love truck. The end will justify the means
    I smile like a jackass eating bedslats every time I give it a go.
    As will you
  29. Oct 13, 2023 at 4:28 PM
    #359
    WinterWarlock21
    South Jersey
    So tough for me to tell since I had a good experience. If I was in your situation, I’d probably ask 20/25% off and settle at 10/15%. You waisted over an extra week, they had awful communication, on top of the trust factor of the installation. Plus you didn’t ask for something that was different or difficult. It was a kind of a standard installation.
    I arrived at 10/15% because that’s what I was given when a shop near me kept my truck for an extra 5 days on my 5.29 gears install.
    But I’d still wait to see what they say first before you ask.
  30. Oct 13, 2023 at 4:28 PM
    #360
    nobodyintexas
    nobodyintexas What?
    South of Houston
    And yes, all the while my wife is wondering why I do this shit
    women, in general, don’t comprehend these things
    ex. Why are you putting on another supercharger. I’m not. It’s just a pulley
    like the penguins in Madagascar, I just smile and wave
