Finally got rid of those annoying no seatbelt ding noises
Discussion in '3rd Gen Tundras (2022+)' started by La1dbackdude, Dec 14, 2023.
  1. Jun 29, 2024 at 1:09 PM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Went the Carista way too. I shut the selt belt chimes off, turned the fake engine noise off, and did the -2 degree AC calibration adjustment, which really improved the functionality of the AC.
    I may have to look into the window opening with FOB thing. It would be nice to let the super heated air out of the cab before doing a remote start to cool the cab down. Never thought I'd use the remote start much, but it was nice to have on our recent trip to Florida.
  2. Jun 29, 2024 at 2:26 PM
    mtnkrake
    mtnkrake New Member
    Be careful if you keep your keys in you pocket. I have had my fob roll the windows down a couple of time during the rain. All night long.
    Tundrastruck91 likes this.
  3. Jun 30, 2024 at 4:58 PM
    bootedguy
    bootedguy New Member
    2024 Tundra SR5 Crewmax (Lunar Rock)
    Just a heads up for you iPhone guys trying to use an inexpensive ELM 327 ODB adapter (https://www.amazon.com/dp/B0C8T76CPC) instead of the Carista one, they only work on Android. But it does work just fine. Just bust out an old Android phone or tablet and disable seatbelt chimes to your heart's content. I also recommend changing the auto turn signal from 3 to 5 blinkers.
  4. Jun 30, 2024 at 7:36 PM
    Hella Krusty
    Hella Krusty New Member
    what's in your pocket?? You have to hold the button in, and continue to hold it in while they roll down. it isn't like you press the magic down button
    Spartanfam likes this.
  5. Jun 30, 2024 at 8:25 PM
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    Correct!
  6. Jul 1, 2024 at 4:42 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
  7. Jul 1, 2024 at 4:55 AM
    TundraDan723
    I rent cars 2-3 times a month and usually get a RAV4 or a Highlander. BOTH of these cars are MUCH less obnoxious. I can't understand why the TUNDRA is so much worse...
  8. Jul 4, 2024 at 1:28 PM
    awpk03s
    awpk03s New Member
    That’s sweet. I need to get Carista….
  9. Jul 6, 2024 at 4:36 AM
    DrumChaser
    DrumChaser New Member
    2022 Tundra TRD Sport
    Are there any cheaper ones on Amazon that you can turn off the seatbelt alarms etc that do work with iOS?
  10. Jul 6, 2024 at 9:07 AM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Had perfect performance with the VeePeak adapter on AMZ. It also works perfectly with the Car Scanner App for Trans Temp, Gear Pos, Boost Press, Engine Oil Temp and Press, Engine Temp, and Battery Voltage.
  11. Jul 6, 2024 at 10:26 AM
    TundraDan723
    I finally did it! I already had a ODBII scanner, so I downloaded the Carista app! What was I waiting for???
    Since I already had a scanner it DID give me a MONTH free before the charges for the app start. I will use the full month and then decide if I want to keep it.
  12. Jul 6, 2024 at 11:20 AM
    ocman40
    ocman40 New Member
    Found this out when I switched to an iphone. Ended up using my Chromebook though! works great
  13. Jul 6, 2024 at 3:19 PM
    DrumChaser
    Could you adjust the ac and turn off the seatbelt alarm?
  14. Jul 6, 2024 at 11:11 PM
    PNW Tundra Mike
    Southern Cal
    Wait until your 1 yr free Nav runs out and it will stop! Hero?
  15. Jul 6, 2024 at 11:12 PM
    PNW Tundra Mike
    Southern Cal
    Yes. Worked perfectly with Carista too
  16. Jul 7, 2024 at 11:54 AM
    mtnkrake
    mtnkrake New Member
    15 keys, $1.46 in change, a tape measure. and gum. lol
  17. Jul 7, 2024 at 1:08 PM
    rx3
    rx3 New Member
    Really? Mine ran out a couple days ago. I'm going to drive by the school by my house to test this. And yes, you will be my hero if the notification is gone! That's how much it annoyed me.
  18. Jul 17, 2024 at 6:58 AM
    CC TIGER
    CC TIGER New Member
    2024 Limited 4x4
    Heritage Grill
    I just bought the Veepeak scanner. What add-ons are required with the Car Scanner App? Is is a Toyota package or one just for the 3rd Gen Tundra (I have two other Toyota models at the house)? Just to be sure, the app you are using is: Car Scanner ELM OBD2? Thanks!
  19. Jul 17, 2024 at 7:59 AM
    #49
    sandiegosteve
    sandiegosteve New Member
    San Diego
    24 Limited TDR Lunar Rock
    I just tried the Car Scanner app on a Carista last weekend. In the app, you start with "connect" it will can for bluetooth devices. I found that doing this right after powering on puts the OBDII device in pair mode. It showed up, I clicked it and then you choose the profile you want.
    For the settings, it looks like I chose Adapter oBDII ELM327: Bluetooth LE (4.0). Connection Profile: Toyota OBD-II EODB ~2016 - Present CAN + extra sensors. I remember their being more in the name when I clicked it, but that is what I see in the app now. Then you lots of menus to explore. It does take some time exploring the values it can get.
  20. Jul 17, 2024 at 11:31 AM
    #50
    PNW Tundra Mike
    Southern Cal
    Once connected click the All Sensors button at the top right on the home page. You can scroll through that list and take note of the active ones you want for your custom dash
    CC TIGER likes this.
  21. Jul 17, 2024 at 3:36 PM
    #51
    DrumChaser
    So to clarify I can make all the adjustments with a veepeak scanner if I download the carista app? Like ac adjustment , seat belt alarms etc?
    PNW Tundra Mike likes this.
  22. Jul 17, 2024 at 10:20 PM
    #52
    PNW Tundra Mike
    Southern Cal
    Yes Sir! ( you do need a Carista subscription for one month, then cancel ($9.95)
