Finally! A Tundra forum worth reading!
Discussion in 'New Member Introductions' started by LuckyLainey, Feb 11, 2023.
  1. Feb 11, 2023 at 4:00 PM
    LuckyLainey
    LuckyLainey [OP] New Member
    06 Toyota Tundra SR5 Double Cab 4.7L V8
    Hi y’all! I’m Lainey and I love my Gen 1 Tundra!
    06 Tundra 4.7L V8 Double Cab SR5 2wd
    I have been reading all of the posts regarding an issue I’m having with my LED upgrades.
    1. Fog lights won’t turn on.
    2. Twist Fog light control turns on high beams.
    3. Hyper flicker turn signals. (Error)
    I know I need a HB4 9006 Canbus anti-flicker, decoder, relay, resistor etc etc because of the low electrical draw causing the error.
    Some of the relays generate a lot more heat than others right?
    How many do I need? Mixed information. One for each?
    Saw a YouTube video and the guy installed one on the passenger side head light and the other the passenger side fog light.
    Whatcha got guys? Help a lady out! I love my Gen 1 Tundra!
    831Tun, Leo's first and texasrho83 like this.
  2. Feb 11, 2023 at 4:02 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Welcome from TX!
    You've got the best 1st gen truck group ever assembled here !
    831Tun and LuckyLainey[OP] like this.
  3. Feb 11, 2023 at 8:24 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  4. Feb 11, 2023 at 8:37 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Welcome from MA
    Paging @shifty` and the gang
    shifty` likes this.
  5. Feb 11, 2023 at 8:46 PM
    Nice truck! Even if it's got one too many non-suicide doors :rofl:
    A lot of the info you'll need for your truck can be found in this sticky thread, specifically. It's broken out in sections and is a knowledge dump we owe to members past and present, here and banstick'd.
    On the resistor, yes, this is a common issues as is seen in that sticky. And the general consensus is, 1 resistor, and most people who've done it are dropping it on the passenger side of the lighting circuit.
    LuckyLainey[OP] likes this.
  6. Feb 19, 2023 at 12:04 PM
    LuckyLainey
    One issue solved. Fog lights now work correctly. Rotate the fog light switch on the turn signal indicator and it’s perfect.
    Second issue still remains. Hyper flashing turn signals.
    Can this be resolved by incorporating, two signal bulbs that have resistors built in? One on the passenger side and the other on the drivers side?
    or?! Do all 4 bulbs need resistors? (Either built in or the other way, which I am trying to avoid)
    Has anybody tried using the new led bulbs with the built in resistors?
    Directions on how I solved the Fog light issue. These come in a 2 pack.
    *I plugged one into the drivers side head light & the other into the passenger side headlight:
    Visit the Auxbeam Store
    3.6 out of 5 stars1,712Reviews
    Auxbeam H4 9003 HB2 P43T LED Headlight Canbus Error Free Anti Flickering Resistor Decoder, 2pcs/set Enhanced LED light Decoder Canbus Drivers
  7. Feb 19, 2023 at 12:17 PM
    Welcome from NY.
  8. Feb 23, 2023 at 4:57 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
    Welcome from So Cal
  9. Feb 23, 2023 at 7:32 PM
