Final Chrome Be Gone..Steering Wheel Badge
Discussion in '3rd Gen Tundras (2014+)' started by TundraCoast, May 15, 2019.
  1. May 15, 2019 at 10:22 AM
    TundraCoast
    TundraCoast [OP] Member In Good Standing
    Ian
    California
    2017 1794 4x4
    I've been chipping away at de-chroming my interior (1794 Edition) posting the progress along the way. Vinyl wrapped the steering wheel badge last weekend, turned out pretty good o the first attempt.
    Other de-chrome trim pieces (silver door handles)
    egibson606, Drk_Jdi, kgb4187 and 3 others like this.
  2. May 15, 2019 at 10:39 AM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    What procedure & product did you use? I’d like to dechrome my steering wheel emblem as well.
  3. May 15, 2019 at 10:53 AM
    Ostrich
    Ostrich One bit me once.
    Nikki
    Marion, Texas
    2014 MGM Crewmax SR5 4x4
    3/1 level, black leather, raptor style grille
    How in the heck did you wrap the steering wheel badge?? Did you take it off and re-attach it somehow?
    TundraCoast [OP] and KELZ84 like this.
  4. May 15, 2019 at 10:58 AM
    10TundraSR5
    10TundraSR5 New Member
    That steering wheel badge looks FANTASTIC!!!!!!! Please, share the details!
  5. May 15, 2019 at 11:09 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    patience of a saint
  6. May 15, 2019 at 1:34 PM
    TundraCoast
    Ian
    California
    2017 1794 4x4
    Bought vinyl “sample” from Amazon for $5 it’s enough to do the steering wheel badge twice. I went with satin black. There are a couple of vids on YouTube wrapping badges. The issue is the steering wheel badge is much smaller than exterior Toyota badging. I used a heat gun, small plastic pic tool, fine tip xacto-blade and an old credit card. I covered the badge loosely with the vinyl, swept over it with the heat gun a couple of times, then started working the vinyl into the crevices while adding more heat, (I went easy with the heat). It’s time consuming getting all the edges pushed down but not bad. The steering wheel badge is plastic welded to the air bag pod so I went wrap in place of trying to paint it. Hope this helps others, I took my time and wasn’t in a hurry.
  7. May 15, 2019 at 2:13 PM
    Kalashnikov 47
    Kalashnikov 47 New Member
    Minnesota
    Black CM 5.7 ff trd pro
    How did you black out the shifting console?
  8. May 15, 2019 at 3:38 PM
    TundraCoast
    Ian
    California
    2017 1794 4x4
    There are a couple way, you can tape off around it and paint, wrap. I chose to take the shifter surround off, it’s held in place by (4) plastic welded rivets. I cut hose off, painted piece then epoxied back into place using the same four plastic weld spots
  9. May 15, 2019 at 3:53 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Did you wrap the chrome rings around the climate control knobs as well? In place? That's all i have left inside my truck that is chrome
  10. May 15, 2019 at 3:58 PM
    TundraCoast
    Ian
    California
    2017 1794 4x4
    Hey Sean,
    I had the HAVAC out to have the vent rings painted so I disassembled the trim rings around the knobs and had those painted at the same time. Now that little ring of chrome around the 4x4 hi & lo is buggin....it’s all in the details.
    Watt maker and Pudge like this.
  11. May 15, 2019 at 4:10 PM
    Pudge
    CT
    Oh crap, you just had point out that tiny little piece is chrome too, lol. I never noticed before. Thanks alot!!!
  12. May 16, 2019 at 4:38 PM
    TundraCoast
    Ian
    California
    2017 1794 4x4
    You’re welcome, lol. Let me know what you work out for that trim ring on the 4x4 selector
    Pudge likes this.
  13. May 30, 2019 at 8:47 PM
    JTL
    JTL New Member
    Jon
    Phoenix, Az
    '17 MGM Platinum
    Trd CAI, Trd Dual Exhaust, ESP Locking storage, Center Console Safe, Trd Rear Sway Bar, BFG Ko2, Pioneer Avic 8400nex, Husky Liners, 19 Trd Headlights, iHacker Harness, Tech12Volts Sub Upgrade
    I couldnt find away to take the 4x4 knob apart. Looks like the only way is to tape and paint. I wouldnt vinyl unless you figure out how to take it apart. I would like to know if the ac knobs can be painted without looking like crap. The texture gripping doesn't look paint friendly. I went rustoleum soft iron on the trim and avery brushed black steel for the ac chrome, metra kit, and entire control panel.20190530_093745.jpg
  14. May 5, 2020 at 9:41 AM
    Mrlumens
    Mrlumens New Member
    Hey bud. Looks great. Could you tell me what vinyl you used for the emblem. I'm using stuff I got off eBay and it won't adhere to the sides. Thanks
  15. May 6, 2020 at 5:34 AM
    Rebel Tundra Man
    Rebel Tundra Man New Member
    Tyler
    Kentucky
    2016 Black Limited CM
    4" RCX Lift, 20x10 Fuel Coupler's, 35x12.50x20 Nitto Ridge Grappler's, Color Match Front End, LED Bulbs, RCX Tube Steps, Green LED Underglow
    Try using a heat gun and an exact-o knife
  16. May 6, 2020 at 5:51 AM
    Mrlumens
    Mrlumens New Member
    I was. Maybe there vinyl I got is garbage.
    Rebel Tundra Man likes this.
