Filter housing on so tight it broke my filter wrench. What now? (Solved)
Discussion in '2.5 Gen Tundras (2014-2021)' started by panicman, Apr 16, 2023.
  1. Apr 22, 2023 at 6:42 PM
    pursuit2550
    pursuit2550 New Member
    Yeah, for real. $280 to just go to a spin-on and no other benefit.
  2. Apr 22, 2023 at 6:46 PM
    pursuit2550
    I did an oil change today and my housing and drain plug were tight ASF. Dealer did an oil change without my consent when I when in for a battery warranty exchange. I still had 2 free oil changes left. And don't get me started on the wheel lug nuts. FML
    WILLINH, JimboSlice413 and bulldog93 like this.
  3. Apr 22, 2023 at 8:26 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Let me guess. They stretched the lug bolts.
  4. Apr 22, 2023 at 8:35 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Same one. The brand is Motiv X.
  5. Apr 23, 2023 at 4:26 AM
    pursuit2550
    No, nothing happened. Heres the quick story. My truck is leased. Did take it to them for the 1&2 scheduled maintenance. Decided to keep it after the whole ridiculous price increases. Never went back. But they were the last to rotate the wheels and they were torqued with a 1” impact gun. Also, one of my oil changes, they didn’t change the oil filter.
  6. Apr 23, 2023 at 8:03 AM
    DFW_SoldTacoBoughtTundra
    DFW_SoldTacoBoughtTundra New Member
    DFW
    2021 Limited 4x4
    6112s, Icon add-a-leaf pack, Icon 17s
    I’ve been doing my own oil changes for a while (I do them at 5k). I’ve been using a torque wrench to reinstall the filter housing to spec. Seems like it takes hardly any torque to get the wrench to click. When I go to loosen it for the next oil change it is considerably tighter (I end up needing to use my breaker bar to get it loose) than what I tightened it to. Been trying to think of what would cause it to tighten up so much.
    WILLINH likes this.
  7. Apr 23, 2023 at 8:35 AM
    bulldog93
    Jeff
    The vibration of the engine/vehicle seems like it's the reason for the filter to tighten. I've been changing my own oil for almost forty years and with regular oil filters, I always hand tighten it, but it always requires a filter wrench to remove.
    Henry1jg likes this.
  8. Apr 23, 2023 at 12:04 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Plastic or metal cap? I never have that problem with the metal ones on either the Tundra or daughters Lexus.
  9. Apr 23, 2023 at 1:56 PM
    DFW
    2021 Limited 4x4
    Plastic
  10. Apr 23, 2023 at 5:01 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Why are you using a torque wrench to remove something? Maybe just me but I wouldn’t use a calibrated device in place of a breaker bar….just seems like the wrong application.
    coldcanuk and JLS in WA like this.
  11. Apr 24, 2023 at 6:57 PM
    panicman
    panicman [OP] Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Didn’t have a cheater and that is a HF torque wrench that I don’t believe is accurate. No quality tools were damaged while creating this thread.
  12. Apr 24, 2023 at 10:31 PM
    FO LO
    FO LO New Member
    17 CM w/ 5.7 and 4.30s
    They use impacts on the plastic thing?? For the love
    What are the torque specs on the oil change pieces and parts? I haven't seen those
  13. Apr 24, 2023 at 10:35 PM
    icodeintx
    icodeintx New Member
    Scott
    Palacios, Texas
    2021 Cement Gray Tundra SR5 CrewMax
    LED Headlights, LED Fog Lights, LED Interior lights
    Lefty-Loosy :)
    bulldog93 likes this.
  14. Apr 25, 2023 at 5:09 AM
    pursuit2550
    If your old school then you should know when tight is tight enough. The oil filter cap seals by o-ring same as a spin on. No need to TQ it with an impact, lol. There are just some things that don’t need to be torqued in my opinion. Just like the trans drain plug and rear diff plugs. But if you want to know it’s on the cap itself.
    SWB Tundra and bulldog93 like this.
  15. Apr 25, 2023 at 5:53 AM
    DFW
    2021 Limited 4x4
    18 ft-lbs if I recall correctly
  16. May 27, 2023 at 8:52 PM
    panicman
    Eric
    Just going to tack on an undesired update.
    When I was changing the oil, I had just blown out my floor jack and I needed to get a new one before I could rotate the tires. Had time this weekend, so as I was getting ready to start I found the dealer has either left lug nuts off, or didn’t tighten them. I use blackout covers, so I didn’t notice.
    I’ve been running on 3 lug nuts for who knows how long.
    pricks
  17. May 28, 2023 at 5:32 AM
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    Holy smokes! I'm glad nothing happened! That is crazy!
  18. May 28, 2023 at 6:04 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    :eek::mad:
  19. May 28, 2023 at 6:08 AM
    #49
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    FOLKS. If this near-death story doesn't convince you to do maintenance work yourself (and/or with friends, sons, buddies, etc.) then I pray for you
    Glad you survived.
    ohiowa, ATV25 and coldcanuk like this.
  20. May 28, 2023 at 7:36 AM
    #50
    EddieBolt
    EddieBolt New Member
    David
    2020 CM SR5 4x4
    Consider yourself lucky. wow!
  21. May 28, 2023 at 3:48 PM
    #51
    panicman
    Eric
    Definitely freaked me out. I’ve been driving around a lot for work, and last week I felt a little shimmy in the wheel and figured I’d waited long enough to rotate my tires, and I got a new jack 2 weeks ago.
    When I was starting to loosen the lugs (none were very tight :confused:) I found those two missing on the front passenger side.
    I am going to write that dealer a letter. They will kill someone doing this.
    I got replacements today and got everything on and tight.
  22. May 28, 2023 at 6:09 PM
    #52
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I would send the dealer a copy of the receipt along with the letter.
  23. May 31, 2023 at 2:13 PM
    #53
    DFW
    2021 Limited 4x4
    Just an update on what I experience. I just changed the oil this past weekend and noticed that (this time) the effort required to loosen the filter housing was consistent with the torque to which it was tightened when I had previously changed the oil. Only difference is my engine was still hot from driving where in previous oil changes the truck has always been sitting and engine is cold. May or may not have had anything to do with it. I will also add that I'd been using the Costco special oil at $40 per 10 qts. This time I went with Amsoil OE 0W-20 and noticed that my engine seems to be running a bit quieter than it does with the Costco variety. May or may not be something to that high dollar Amsoil stuff.
  24. May 31, 2023 at 2:23 PM
    #54
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I know some people can't or don't have time to do their own work, but you have to inspect their work. In the engineering world, trust but verify.
  25. May 31, 2023 at 3:03 PM
    #55
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Switch to 5w30 and see how much quieter is gets.
    ATV25 likes this.
  26. May 31, 2023 at 9:50 PM
    #56
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    It takes quite a bit more torque to move something from a stop than to keep something moving that’s already in motion. Though I’ve seen estimates showing Less torque is required on loosening a stopped fastener than in tightening it. This fails to take into account that, Once stopped, the friction surfaces and heating and cooling cycles, as well as corrosion come into play, so it could make a significant difference in loosening vs tightening torque.
    I should add that there’s much more qualified people to speak about this than I am. I am NOT an engineer.
