Filling Gas Issues
Discussion in '2.5 Gen Tundras (2014-2021)' started by xupkid2, May 22, 2018.
  1. May 22, 2018 at 9:49 AM
    xupkid2
    xupkid2 [OP] New Member
    Just had this problem start today but no matter what I do on my 2016 Tundra I can't fill the gas. I've tried 3 different pumps/stations so it's not a station issue. Problem is when I go to fill the pump auto shuts off after 1-2 sec. I've tried repositioning things as well as going slower (had to do this in the past a few times) and no luck. I checked and there is nothing blocking the filler neck. Removed the rubber hose that connects to filler and put a snake through it to make sure.
    Any ideas what could be wrong? I tried search and didn't find anything. Any assistance is greatly appreciated.
    Thanks
  2. May 22, 2018 at 10:00 AM
    15whtrd
    15whtrd Mr. Blonde
    The only time I’ve had this issue I found I had to really shove the gas nozzle in there. Other than that you may have another problem. Are you still under warranty? If so just take it in.
  3. May 22, 2018 at 10:01 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Sounds like you've tried what I would have done. I'd take it to the dealer next to see what up.
    Did you try and fill it with a 5 gallon gas can?
  4. Jan 21, 2019 at 7:53 AM
    KiltedWolf1
    KiltedWolf1 New Member
    ‘16 Platinum Crewmax White
    I have this problem, started yesterday trying to fill up before I drive 225 home. Can’t fill up, jammed it in and held it right and gas poured back out. Can’t see any blockage. What was the outcome? 2016 Platinum, scheduled service tomorrow since no appointments open. Missing 2 days of work.
  5. Aug 19, 2019 at 1:14 PM
    newguy
    newguy New Member
    2016 CM TRD off road limited.
    TRD Dual Exhaut TRD Pro wheels BFG KO2 275/70/18 GoRhino RB20s Blacked out tail lights Bilstein 6112/5160 combo Coach builder +1 in the rear
    I have a 2016 having the same problem right now. What ended up happening.
    Interesting that this is something being seen by multiple people on this forum.
  6. Nov 4, 2020 at 12:50 PM
    Jake 4x4 tundra
    Jake 4x4 tundra New Member
    What's up guys I'm just here to try to help I recently had the same fueling issue took me a few hours to track it down turns out the rollover valve on the tank was stuck closed I disconnected the filler tube from the gas tank and pushed a hard wire down on the valve and it came unstuck hope this helps anyone having the same problem thanks guys hope this helps
    Tundyfundy, GNTundra and BTBAKER like this.
  7. Nov 4, 2020 at 1:11 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  8. Nov 4, 2020 at 1:32 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
  9. Nov 4, 2020 at 2:38 PM
    Sunnier
    Sunny
    San Diego, CA
    Yep, probably your roll-over protection whatever-it’s-called (in the top of your tank) is stuck. Only official fix is to replace the tank— take it to a dealer if it’s under warranty. If not, you can drop the tank and pull out the part that’s stuck... but then you’ll give up that rollover safeguard (stops gas leaking out if you roll the truck). There are several threads on here, speaking to both solutions.
    YardBird likes this.
  10. Nov 4, 2020 at 8:47 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I wonder if you can disconnect the evap lime coming from the tank and then get an air hose with a rag wrapped around it to send some compressed air through the filler neck. I've done this alot to purge air out of lines in diesels. I figure enough air pressure will either open the valve or blow the filler hose off, either way I'd try it. I think it's worth a shot
    gosolo and 831Tun like this.
  11. Nov 4, 2020 at 9:19 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I tried that w/o success. I'm not sayin don't try it, just that it didn't work for me. Kind of a PITA but I dropped the (near empty) tank, removed the plumbing from the top of the tank and popped the valve open w/ a long screw driver. The valve is about 6-7" down inside the tank. I had no faith this would be the end of the problem so I disabled the valve. DISCLAIMER: I don't recommend disabling the valve, it's just what I did.
    gosolo likes this.
  12. Dec 9, 2020 at 5:53 PM
    Carlos22
    Carlos22 New Member
    Blacked out 4x4
    Hello 831 tundra
    What u did to ur valve did it work
    Can u fill up now without a problem??
    831Tun likes this.
  13. Dec 9, 2020 at 6:06 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yep, it's never been nor will it be a problem again.
    Carlos22[QUOTED] and HulkSmurf14 like this.
  14. Dec 9, 2020 at 6:13 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Unless you rolled the truck over ;-)
    Nice work on finding a work-around! The juice was worth the squeeze!!
    831Tun likes this.
