Fifth Wheel Towing Question
Discussion in 'Towing & Hauling' started by Elizabeth21, Mar 17, 2021.
  1. Mar 17, 2021 at 9:32 AM
    Elizabeth21
    Elizabeth21 [OP] New Member
    hi I'm new from New brunswick. Can I tow a fifth wheel on 255 70r18 113t tires
  2. Mar 17, 2021 at 11:02 AM
    Cpl_Punishment
    Cpl_Punishment Young men never die.
    Rosy
    2020 MGM SR5 CM 4X4
    The tires are the least of your problems trying to tow a fifth wheel with a halfton, especially a Tundra. I'd recommend checking out the payload of the truck vs the pin weight of the trailer. There are a few other threads on this already.
    GODZILLA likes this.
  3. Mar 17, 2021 at 6:01 PM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    ATHiker and Turk980 like this.
  4. Mar 17, 2021 at 7:13 PM
    Elizabeth21
    I've been hauling my 30 footer for 4 years now, no problem
    CO_Native likes this.
  5. Mar 17, 2021 at 7:32 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I believe that. Most people are just going to go by what the manual says.
  6. Mar 17, 2021 at 8:42 PM
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 GMC 2500 AT4 Gasser
    Realistically a 30’ 5th wheel will put your total payload WAY over the ratings. I know that wasn’t your question but it is a safety issue for your family and everyone you share the road with. Obviously the choice is up to you and the liability you are willing to take if something does happen.
    If you continue to haul a large 5th wheel with a Tundra I would hope your tires would be E rated.
  7. Mar 18, 2021 at 10:57 AM
    Elizabeth21
    Thank you all for the input. I guess I'll be purchasing a bigger truck or a smaller fifth wheel.
    johnxmccoy and gosolo like this.
  8. Mar 22, 2021 at 2:14 AM
    OPSteel
    OPSteel New Member
    2017 White Tundra TRD Crewmax
    TRD grille, Bushwacker OEM flares, stereo system
  9. Mar 22, 2021 at 2:17 AM
    OPSteel
    OPSteel New Member
    Good idea! I would recommend getting a different truck. I loved my 2017 Tundra Offroad until I started looking into towing a travel trailer. I would never have bought a Tundra had I known the payload limitations would be such an issue. Hard to believe. 1190 is what mine says. I can’t even find a truck camper that will be safe in my truck.
    usaf.2012 and My big taco like this.
  10. Mar 22, 2021 at 3:33 AM
    Tracy Perry
    Tracy Perry New Member
    Tracy
    East Texas
    2019 MGM TRD Off-Road 4x4
    I love my Tundra, but I'd be looking at a different truck if I was in that position. In fact, I'm still contemplating getting a 1 ton SRW just for our 29ft bumper pull. The payload on the Tundra is really atrocious. It's within 250lbs of our Camry (door sticker to door sticker). I like the reliability of the Tundra (but I have had 2 recalls already on it and a possible TSB out) but am leaning towards having adequate tools for the job, and the Tundra just isn't it.
  11. Apr 1, 2021 at 8:20 PM
    Doug2000
    Doug2000 New Member
    London, Ontario, Canada
    2017 Tundra SR5 5.7L DC 4X4
  12. Apr 2, 2021 at 9:46 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    High Five.
    It is nice to see someone who appreciates a quality vehicle AND a quality camper. There are only about 6 different companies making trailers that will still be working in 50 years. This is one of them.
    ATHiker likes this.
  13. Apr 21, 2021 at 5:54 PM
    Ccalloway
    Ccalloway New Member
    2019 sr5 crewmax
    Hi, new here and hoping for some recommendations. Has anyone installed an b&w flip ball gooseneck hitch on 5.5ft bed? If so how was the installation process? I’m exploring pulling a 27ft fifth wheel camper. The Camper is a 94 with mid to narrow front nose, the gvwr is 8700 and will travel much lighter. My concern is cab clearance? What if any fifth wheel to gooseneck adapters and or extensions has anyone tried or know of that’s had success? Thanks truck is 2019 sr5 2x4 crew max gvw will be around 6,000 pounds.
    rgrogan614 likes this.
  14. Apr 21, 2021 at 6:46 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2, SmartCap, Ride Rite, Bora spacers, 35” rugged ridge tires.
    If you’re going to doll this you must have a sliding hitch. I have Pullrite auto slider. Won’t tow without it. And I have a long bed one ton.
    ColoradoTJ likes this.
  15. Apr 21, 2021 at 7:02 PM
    A-A-Ron
    Aaron
    Seattle
    How much is the pin weight? Payload will be an issue long before total trailer weight.
  16. Apr 22, 2021 at 7:34 AM
    Ccalloway
    2019 sr5 crewmax
    Pin weight is usually around 20% of gtw so if use the camper gvwr which is overstating pin weight would be 1,740lb max?? I estimate actual pin somewhere between 1,400-1,500 lbs. does that sound about right?
  17. Apr 22, 2021 at 7:36 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    What is the cargo capacity of your truck? Post your door sticker.
  18. Apr 22, 2021 at 7:43 AM
    Ccalloway
    2019 sr5 crewmax
  19. Apr 22, 2021 at 8:23 AM
    Cpl_Punishment
    Rosy
    2020 MGM SR5 CM 4X4
    The other door sticker.
  20. Apr 22, 2021 at 8:28 AM
    Ccalloway
    2019 sr5 crewmax
  21. Apr 22, 2021 at 8:37 AM
    Cpl_Punishment
    Rosy
    2020 MGM SR5 CM 4X4
    So if your trailer weighs 6000 lbs and the pin weight is 20% of that, you have 280 lbs for all passengers and gear inside your truck, including any mods you've made to it.
    Might be worthwhile weighing your truck to confirm that payload number but I think you'll be pushing it if not over your truck GVWR. I'd also be concerned about breaking my rear window if towing a fifth wheel with a short box. My wife's grandfather has an older fifth wheel and it only works with an 8 foot box.
    ColoradoTJ and onesojourner like this.
  22. Apr 22, 2021 at 8:48 AM
    Ccalloway
    2019 sr5 crewmax
    Same here Cab clearance is my concern more than at weight. Trips would be mostly flat and not a high rate of speed. Reason for the post was to see if anyone has any experience with the combination of 5.5 bed and 5rs?? I’m exploring 2 options: 1 auto slide fifth wheel hitch (not a huge fan of leaving or reattaching the hitch) 2: B&w turnover ball hitch for the truck and hide a ball fifth wheel to goose adapter with offset) this would/should give additional cab clearance width and height if needed)
  23. Apr 22, 2021 at 9:56 AM
    Cpl_Punishment
    Rosy
    2020 MGM SR5 CM 4X4
    Sounds to me like you should also be concerned about weight. If you're tied to that trailer, probably a good idea to consider a 2500 with at least a 6.5 ft box.
    A-A-Ron likes this.
  24. Apr 22, 2021 at 11:23 AM
    Ccalloway
    2019 sr5 crewmax
    Thanks for the advice. Def not tied to the camper, It was given to me to try out camping with the fam. Not interested in trading up trucks for a camper that will rarely get used and travel no more than 4 hours away maybe a couple times per year.
    Cpl_Punishment likes this.
  25. Apr 22, 2021 at 5:02 PM
    Cpl_Punishment
    Rosy
    2020 MGM SR5 CM 4X4
    In that case, I'd look for a bumper pull that's 24 feet or less.
    Tracy Perry likes this.
  26. May 12, 2021 at 6:51 PM
    Tracy Perry
    Tracy
    East Texas
    If the trailer is in good shape, there is a STRONG market for used trailers right now. I was offered $2500 more for my 2.5 year old Winnebago 2401RG than what I paid for it recently (no sale as I got it for the long haul and love the layout). You could always take that money and invest in a 20-24 foot trailer with bunkhouse if you have kids. You would still have some outgo on it odds are, but would better fit the truck. I would NOT look at a 5'er with any Tundra, although there are people that do it. The trailer selection you can use is very limited and usually you will have pranged your payload (which is abysmal on the Tundra anyway) with your pin hitch weight.
  27. Aug 28, 2021 at 4:00 AM
    NateG
    NateG New Member
    Nate
    2015 SR5 Double Cab
    :cool:
  28. Sep 11, 2021 at 3:34 PM
    Dirt Dawg
    Dirt Dawg "It'd be a lot cooler if you did"
    Connor
    Denver, CO
    2014 Toyota Tundra Limited CrewMax 4x4
    I bought my truck with a turnover ball already installed. My points:
    -These trucks really aren’t great for heavy towing IMO due to the frame design. I was getting ALOT of frame flex towing with it. And that was with a low pin weight just around town.
    -The PO towing with it completely wrecked the leaf springs. I had to buy new ones.
    -Everything else seemed to hold up fine, but you could tell it took a toll on the truck
