Fiberglass Fenders or Pro Comp Long Travel Fenders
Discussion in 'General Tundra Discussion' started by ReCKzX, Jun 17, 2017.
  1. Jun 17, 2017 at 7:51 AM
    ReCKzX
    ReCKzX [OP] New Member
    2023 Tundra TRD Pro Ice Cap
    Need some help. Might be making some changes to my truck sometime down the road. One of the changes being Camburg long travel up front.
    Would you rather run fiberglass up front and no fiberglass in the rear or Pro Pomp long travel fenders in the front and rear? I can't run fiberglass in the rear because I have a shell and I don't plan on getting rid of it anytime soon. With the Pro Comp long travel fenders I can run them both in the front and rear. A guy just did Camburg long travel with the pro comp flares and it looks pretty good. Just don't know if the flares really do accommodate the full long travel articulation.
    Here are some pictures below.
  2. Jun 17, 2017 at 8:16 AM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    If you're just doing the front then I would say you can take the Pro Comp road. I've done them at work and they require some cutting which in turn not only is required to install but also gives you some additional clearance for travel. I lean more towards the Glass Works, McNeil, SDHQ, and Fiberwerks. They are shaped better to me and have more clearance that you'll ever need. Both those trucks look very nice though!!
  3. Jun 17, 2017 at 8:30 AM
    ReCKzX
    Yeah I do like the true fiberglass better but just don't know how it will look with the front only. Decisions, decisions, decisions...
  4. Jun 17, 2017 at 8:42 AM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
  5. Jun 17, 2017 at 8:52 AM
    ReCKzX
    Yeah I know Camburg has front fiberglass only on there rig. Looks pretty cool.
  6. Jun 17, 2017 at 10:17 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Those Pro Comp fenders look really good on that white tundy! But I have to agree that I'm a bigger fan of the fiberglass. Just looks cleaner and more professional. Either way your truck will look killer with these on!
    ReCKzX[OP] likes this.
  7. Jun 17, 2017 at 1:26 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Seems like a no-brainer. Get the ones that are compatible with your shell.
  8. Jun 17, 2017 at 9:27 PM
    TheBeast The Beach
    damn that gen 2 looks great
  9. Jun 17, 2017 at 9:37 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    Having had a Camburg LT kit on my old truck ('98 Tacoma) I suggest that you run a mudflap (yeah I know) or color match rhino lining the bottom of the cab and doors. With the tires sticking out that much further, they throw up a LOT of stuff you don't think about and it will destroy your paint.
