FFV Supercharger
Discussion in 'Performance and Tuning' started by balou, Jan 2, 2017.
  1. Apr 18, 2017 at 6:44 PM
    Not sure that's accurate. My buddy has the Hypertech installed with the tires rated (35") in and still pulls good mileage. You actually increase MPG as it's less effort for your engine to work. If you drive it like an ass- then ya, expect crappy MPG.
    atman84 likes this.
  2. Apr 19, 2017 at 6:01 PM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Not even sure how to respond to that post. Do you understand how a supercharger works? Do you understand how an engine works? So I have a 5.7L engine that takes X amount of fuel to run naturally aspirated to keep it at stoich. I bolt a small 1.9L engine on top of my 5.7L but instead of supplying it with its own ability to make power I have to run it off my 5.7L engines crank shaft, creating parasitic loss due to additional drag on the crankshaft essentially robbing the base engine of power. Now the upside to that is I now have a 1.9L engine sitting on top of my 5.7L engine that is an air pump pushing more O2 in to my 5.7L essentially turning it in to a 7.6L engine. The MAF and O2 sensors see this extra air coming in from that added 1.9 L air pump and they prevent that lean condition by compensating for the extra air and they richen up the mixture with added fuel (hence the need for larger injectors) to compensate for the extra air to prevent a lean condition and piston melt down. This happens at any engine speed regardless of RPM or throttle input.
    The stock engine makes 67.54 hp per liter, and the 5.7L engine with the 1.9L blower makes 74.11hp per liter. Not an amazing increase considering thatt you have bolted $8000 on top of the engine.
    Adding 35" tires does not increase mileage either. You are effectively strapping another 1000 lbs to the truck by increasing rotational mass. You cant slow it down as fast either due to that added rotational mass. Hence why the truck wants to coast further faster when you let off the gas with larger tires. The gyroscope on the hub has increased in size exponentially due to that weight moving further out from the pendulum point.
    If your theory were correct, that placing a SC on the truck with 35" tires I should see 20mpg from the Tundra. Following this theory, since my car has twin turbos (which have no parasitic loss) as they only use exhaust gas to turn them, my 6.0L engine that makes 1200hp should provide me with 40 to 50 miles per gallon. Unfortunately that is not true. I get about 7.4 mpg foot in and 9.2mpg in light throttle applications. Due to the fuel dump required to keep the engine running richer than stoich to prevent piston melt down.
    Now I don't know much about engines and cars as I have only been a ASE certified master mechanic for 32 years, and an automotive Engineer for 30 years. And the car below was the fruit of a lot of peoples labor, including mine. That little engine is a bit of a gem at 650hp at 8lbs of boost and 1200hp at 14lbs of boost.
    1UPPER likes this.
  3. Apr 19, 2017 at 6:06 PM
    What is that car?
  4. Apr 19, 2017 at 6:19 PM
    NJBBPTUNDRA
    NJBBPTUNDRA New Member
    Sal
    2016 Blazing Blue Tundra Platinum
    TRD Exhaust TRD Cold Air Intake TRD Sway Bar
    Could there be a group buy in the near future???
  5. Apr 19, 2017 at 6:38 PM
    Vector W8
    1992 Vector W8 Twin Turbo.
  6. Apr 19, 2017 at 6:46 PM
    Harris1881
    Harris1881 New Member
    Oregon
    15' black CM SR5
    I've got a unichip I might part with if anybody is interested.
  7. Apr 19, 2017 at 6:56 PM
    TL; DR.
    Nowhere did I say 35" tires increase it. I said SC does, has- and I will stand by my statement.
    But yes, I know SC's pretty well. I also own one on my 5.7. I can speak from first hand experience- and it's not just my knowledge, but others.
    Harris1881 likes this.
