FF Unichip Quarter Mile
Discussion in 'Performance and Tuning' started by Talstar, Mar 9, 2016.
  1. Mar 9, 2016 at 11:22 PM
    Talstar
    Talstar [OP] New Member
    15 Tundra TRD PRO
    13.6@100.3mph
    CM Pro FF with Unichip
    FirstGenTundra likes this.
  2. Mar 10, 2016 at 5:39 AM
  3. Mar 10, 2016 at 6:38 AM
    Talstar
    15 Tundra TRD PRO
  4. Mar 10, 2016 at 2:09 PM
    Mike Tread lightly.
    south carolina
    What as the conditions at the time of the test? Temp and R/H and B pressure. factor those in on times.
  5. Mar 10, 2016 at 5:10 PM
    Talstar
    15 Tundra TRD PRO
    Temp was low 60's, low humidity and I lauched in 4 Hi for that run. Couldn't hook up in 2 wheel drive. Ran a 15.5 at 100 in 2 hi. Then in 4 hi 13.6 and a 13.9.
    Very happy with results!!
    Mike likes this.
  6. Mar 10, 2016 at 5:16 PM
    Mike Tread lightly.
    south carolina
    very very good. good deal. people say the unichip/piggyback is not worth it.. LMAO. proof.
    and yours a ffv
  7. Mar 10, 2016 at 7:19 PM
    Talstar
    15 Tundra TRD PRO
    Thanks for the like, definitely wanted to clear up the FFV SC Tundras not having as much power as the non. The shifts could be better but the Unichip doesn't control that.
  8. Mar 11, 2016 at 9:24 AM
    Mike Tread lightly.
    south carolina
    What would really be sweet is to bring up the hydraulic pressure in the transmission and change the shift points. That way you could getting better shifts and faster shave your maybe .6 if not more off the time.
  9. Mar 11, 2016 at 10:17 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I remember seeing a kit that you add on to the bottom of the transmission to give the manual shifting a leg up.
  10. Mar 11, 2016 at 11:15 AM
    Talstar
    15 Tundra TRD PRO
    I'm thinking about changing the valve body as a whole or waiting to see if bulldog comes out with a FF tune which would be cheaper.
  11. Mar 11, 2016 at 11:26 AM
    Mike Tread lightly.
    south carolina
    That would help alot .
  12. Mar 11, 2016 at 11:29 AM
    Mike Tread lightly.
    south carolina
    Valve body will be way more than the bullydog. If the valve body is build stronger and the actuators are stronger than stock, then you can safety run it harder.
