Fender flares bolts help
Discussion in '2.5 Gen Tundras (2014-2021)' started by gregfocker77520, Mar 1, 2018.
  1. Mar 1, 2018 at 4:33 PM
    gregfocker77520
    gregfocker77520 [OP] New Member
    luis
    2018 Graphie tundra crewmax sr5
    none yet!!
    Like to swap out bolts on fender flares to black ones, anyone happen to know the size? These flares came with truck when purchased new.
  2. Mar 1, 2018 at 4:40 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Nail polish is ur friend
    OBXTundra likes this.
  3. Mar 1, 2018 at 4:43 PM
    gregfocker77520
    luis
    none yet!!
    I was thinking plasti dip, wondering if flat black nail polish will hold up?
    I rather swap them out if I can find size.
  4. Mar 1, 2018 at 4:45 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    X2 on the nail polish. I'm OCD about my bicycles (high end road bike, enduro, and dirt jumper), when I need to touch one up, I wheel it into the nail polish section at CVS to get a perfect match. Or get an actual small artist/hobby brush and a small can of the exact color you want to use.
    You're going to create a lot of work pulling those flares off, pulling every bolt out, and then trying to reattach the flares (the tiny clips with self tappers don't like being used again).
    Les7311, NewImprovedRon and trayday like this.
  5. Mar 1, 2018 at 4:50 PM
    1UPPER likes this.
  6. Mar 1, 2018 at 4:53 PM
    I took all bolts off flares and painted a satin black.. 3 coats.. let's dry for few days to cure..no issues
  7. Mar 1, 2018 at 6:31 PM
    Wife had an old sheer like cotton material shirt top that was thrown away I cut small sections and taped to the torx driver wouldn't mess paint up and carefully screwed back on snug not super tight...another thing was I got a pallet slat n drilled several holes that the bolts fit snug enough to paint thoroughly and let dry several days with a heat lamp and out in the sunlight
    15whtrd and NewImprovedRon like this.
  8. Mar 1, 2018 at 6:49 PM
    ^^^Exactly. What I did. Need to do a redo though.
  9. Mar 1, 2018 at 6:54 PM
  10. Mar 1, 2018 at 7:01 PM
  11. Mar 1, 2018 at 7:34 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    I would try painting them as well. But, if you do decide to go with new bolts the size you want is 5/16"-18 x 3/8". Save the nuts from the originals as they're a thin nylock and won't be easy to find at a hardware store.
  12. Mar 1, 2018 at 7:49 PM
    gregfocker77520
    luis
    none yet!!
    Thanks, will
    5/16-18 x 1/2 be ok? Can’t find the 3/8 ones
  13. Mar 1, 2018 at 11:37 PM
    ZPMAN
    Minnesota
    Just in case you want a good nut and bolt to secure the flairs back in place you can get these from any auto body supply vender or check for them on e-bay. This set ran about $20 . I replaced all because i take the flairs down for cleaning.
    Sas likes this.
  14. Mar 2, 2018 at 12:41 AM
    TTund16
    TTund16 New Member
    are the bolts drilled into the fender or is there a flare base which is clipped on to the car and the bolts go in there?
    If you buy fender flares do you need to drill holes>
  15. Mar 2, 2018 at 5:20 AM
    chphilo
    chphilo Tundra addict
    Western PA
    No drilling. These are decorative bolts.
    TTund16[QUOTED] likes this.
  16. Mar 2, 2018 at 5:23 AM
    Your welcome Sir
    NewImprovedRon likes this.
  17. Mar 2, 2018 at 7:57 AM
    ZPMAN
    Minnesota
    Almost all fender flairs are easy screw on and very easy to install with only a 10mm socket + 1/4" ratchet. Mine are from bush wacker and what they give you for attaching flairs are screws that are a little longer than the exsisting one's that also hold up in place the wheel well liner and are made of plastic that eventually will get stripped out. The plastic clip/nut are difficult to remove and almost impossible to remove after putting the screw into them. What these 20180212_193549.jpg 20180212_193549.jpg
    Clip/nut and bolt will do is allow you to is drop your flairs and wheel well liners very fast and use repeatedly. One other note is that you should wax the contact area of the fender to flair to prevent excessive wear from rubbing.
    phogallen and TTund16[QUOTED] like this.
  18. Mar 2, 2018 at 3:07 PM
    duece292
    Greg
    Green Bay, WI
    I would test fit a 1/2" one first before committing to them. That extra 1/8" might end up sitting against your fender and you don't want that.
  19. Mar 13, 2018 at 11:59 PM
    gregfocker77520
    luis
    none yet!!
  20. Mar 14, 2018 at 1:18 AM
    On my post #11, post #12 describes what size you need the link has the size he described
    Sas likes this.
  21. Mar 14, 2018 at 3:55 PM
    gregfocker77520
    luis
    none yet!!
    placed order from route66mods, hope they fit.
  22. Mar 14, 2018 at 4:08 PM
    Let me know
  23. Dec 24, 2018 at 7:27 AM
    gregfocker77520
    luis
    none yet!!
    Yes it does
    Pm me I have a set from a different vendor that I’ll send to you for shipping costs only!
    Not sure if they will work for you. They are matte black
  24. Jan 17, 2019 at 4:30 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    I did this also and was happy with route66mods the bolts are slightly smaller but still work and fit well.
  25. Jan 17, 2019 at 4:34 AM
    Mnorris1206
    08 tundra
    Crap I removed all the black paint on mine lol your 2yrs late .You might look up fender flair bolt kit on eBay they might have some. And I do know their is a web site that does all kinds of them diferent styles lile spikes and all .
  26. Jan 17, 2019 at 4:35 AM
    Mnorris1206
    08 tundra
    These are cool and wont stick out to much
  27. Jan 17, 2019 at 4:39 AM
    Mnorris1206
    08 tundra
    Also found these
  28. Jan 17, 2019 at 4:54 AM
    Mnorris1206
    08 tundra
    Any cheeper I thought those where a little steep
  29. Jan 17, 2019 at 5:05 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I thought the size was 5/16-18x3/8 per posts above? These:
    No rush here so I was going to wait for an eBay coupon.
  30. Jan 17, 2019 at 5:19 AM
    Mnorris1206
    08 tundra
    I'm with you I would go as short as I could because plastic is jot very thick their. Would hate to have them to long and hit the paint.
