Fender Flare Loose
Discussion in '2.5 Gen Tundras (2014-2021)' started by Spectre, Mar 2, 2021.
  1. Mar 2, 2021 at 12:46 PM
    Spectre
    Spectre [OP] New Member
    Huntsville, AL
    2022 Tundra TRD Sport 4x4
    I have a 2019 TRD Sport with fender flares that were factory installed from purchase new. They have been tightly fitted against the body up until recently when I noticed a gap on both passenger side. They are loose enough I can easily pull them out and put my finger between them and the body. They are not loose in the wheel well. Is there something I can do to tighten them up against the body or should I have the dealership fix them under warranty? Or are they somehow warped and needing to be replaced? I’ve never installed or messed around with fender flares prior to having them on this truck ‍♂️ Prefer not to use the dealership if there is something I can do myself. Thanks for your help or advice.
  2. Mar 2, 2021 at 1:11 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    I’d take it back to the dealership and let them fix it, being that they are already that loose my next concern would be the paint underneath the rubber. That much movement will quickly wear though your clear, paint and primer.
  3. Mar 2, 2021 at 1:16 PM
    timsp8
    NY
    Yep. Let the dealer fix it. I had aftermarket ones that had a little gap and they rubbed the paint. Got rid of them for ones that actually fit.
    Spectre[OP] likes this.
