Fender Flare Ideas????
Discussion in '1st Gen Tundras (2000-2006)' started by BlueHen87, Oct 16, 2020.
  1. Oct 16, 2020 at 8:24 AM
    BlueHen87
    BlueHen87 [OP] New Member
    2006 Tundra
    Removed the fender flares from our 2006 Tundra as they were a weird color. Looking for some pics or thoughts on ideas to replace.....paint them? purchase another brand???....concerned that the ones i see online are wide enough to cover the holes in the body for the clips????.......anybody do anything else.......thought i saw someone say they might fill the holes with bolts......might get the same look as a bolt on without the width????.......any recommendations?????
  2. Oct 16, 2020 at 8:37 AM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    Your truck a double cab or access cab?
  3. Oct 16, 2020 at 8:54 AM
    BlueHen87
    2006 Tundra
    Double Cab
  4. Oct 16, 2020 at 9:37 AM
    Cummins3500
    Logan
    They ain’t much out there for the double cabs. Best option is to re-paint your oem’s. That’s what I’m gonna do for mine. I don’t think the bolts would ever look right if you just shove a bolt through
  5. Oct 16, 2020 at 10:01 AM
    BlueHen87
    2006 Tundra
    agree on the bolts but was hoping to hear from anyone who tried it......probably need to order new "rubber gasket" that goes along edge between flare and body......probably best to go with OEM on that too???........what kind of paint are you gonna try??
  6. Oct 16, 2020 at 10:03 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I bedlined the ones on my 2001 Tacoma... came out great witg adhesion promotor and duplicolor bedliner in a can. If I go see the truck later today I’ll get pictures
    The gasket can be had for the flares from the dealer
  7. Oct 16, 2020 at 10:17 AM
    Cummins3500
    Logan
  8. Oct 16, 2020 at 11:06 AM
    Professional Hand Model
    Hand Protectors
    Rustoleum Bedliner sprayed on cleaned/prepped trims. Red Accent Duplicolor Toyota Barcelona Red.
  9. Oct 16, 2020 at 11:29 AM
    BlueHen87
    2006 Tundra
    i like the spray on bedliner idea......definitely need the new gasket and probably some new clips too.......got some shopping and prep work to do for sure.....the OEM flares are just so much wider than any other ones I can find from another source......
