Feedback on lift + wheel/tire combo quote
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sas, Jul 28, 2018.
  1. Jul 28, 2018 at 12:12 PM
    Sas
    Sas [OP] Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Went to a shop yesterday to get a quote on a lift and wheel/tire combo and would like y'alls feedback on what they recommended.
    FYI, I only have 6.5" of height to play with and it'll be on the road probably 90% of the time. When I do go off-roading the place I like to go is really rocky. ABS protectors are OTW and sliders and skid plates will be added as well (looking at either the RCI steel or BudBuilt stage 3 rock armor stainless steel).
    Finally, the other issue I'm looking to solve is I have the Bushwacker fender flares and they have basically swallowed up my current 20" wheel/tire combo making the stance look a little anemic. I'm wanting to correct that and make the stance look right. I'm hoping with the essentially 0 offset and a wider tire will do that.
    Lift
    Rough Country 3.5" Bolt-on Lift Kit
    https://www.roughcountry.com/toyota...MI88SB8bfC3AIVQ2V-Ch1sYwoQEAQYASABEgLk3vD_BwE
    Tires
    305/65R18 Nitto Ridge Grapplers
    https://www.nittotire.com/light-truck-tires/ridge-grappler-light-truck-tire/
    Wheels
    Fuel Vapor D560 18x9 (1 offset)
    http://www.fueloffroad.com/vapor-d560-w-19149.htm
    Thoughts?
    Mountun Goat likes this.
  2. Jul 28, 2018 at 2:53 PM
    The UCA'S look a lil wimpy, IMO,.find something better???
    Mountun Goat and Casper421 like this.
  3. Jul 28, 2018 at 4:10 PM
    Sas
    OKC, OK
    Open to suggestions!
  4. Jul 28, 2018 at 4:14 PM
    Sas
    OKC, OK
    Trying to figure out how much I'm going to push things out as well. I think I'm at a +25 offset currently. If I go from a 285 to a 305 tire and from a +25 to a +1 offset wheel does that mean I'm pushing things out 34mm?
  5. Jul 28, 2018 at 4:29 PM
    Camburgs
    Total Chaos
    MFabs
    FabTech
    SPC
  6. Jul 28, 2018 at 4:48 PM
    Sas
    OKC, OK
  7. Jul 28, 2018 at 5:05 PM
    831Tun and Sas[QUOTED][OP] like this.
  8. Jul 28, 2018 at 5:11 PM
    DCTRD
    DCTRD New Member
    I like the 305/65/R18...I have the BF KO2s same exact size on stock '16 TRD Pro, no rubbing at all
    Sas[OP] likes this.
  9. Jul 28, 2018 at 5:35 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    Call Toytec.
  10. Jul 28, 2018 at 5:42 PM
    Sas
    OKC, OK
    I looked at their kits. Most are more than I want to spend, but that 3" might work.
    Casper3[QUOTED] likes this.
  11. Jul 30, 2018 at 7:04 PM
    Sas
    OKC, OK
    Well, sent an email to @Toytec Lifts late Saturday night, but no reply yet of any kind. Kinda surprised about that. Heard back from Bilstein tho and at least they're working on it. Still waiting to hear back from ReadyLift as well.
  12. Jul 30, 2018 at 7:18 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    @Sas Im happy with SPC uca’s. Great adjustability and heavy duty. Along with the greasable ball joints which is a must for my climate. They work well with a 3.5” lift like mine.
    I was going to do an entry level lift and saved a bit longer for old man emu. Glad I waited. Just saying. But I do Wheel like I stole it.
    I want my lift to last longer than the truck. And it’s a Toyota so...
    Wheels will look awesome for sure
    Let’s see a pic of your truck currently
    831Tun likes this.
  13. Jul 30, 2018 at 8:44 PM
    Sas
    OKC, OK
    I actually inquired about a complete system from them, including taking the tires up to 325/65R18. Sent in a lot of details about it, so it may just be taking a while to process. I plan on doing some pretty fun off-roading as well so I may wait as well and do a more robust system.
    My profile pic is how it sits currently with the exception of the debris shield I put on a couple of hours ago. There are a ton of other pics in my albums as well if you're interested. Most of the work has been on the interior lately.
    Mountun Goat[QUOTED] likes this.
  14. Jul 30, 2018 at 9:15 PM
    Casper421
    In the woods
    06 DC
    Do it right the first time. Don’t waste money on a budget setup because you will always want bigger and better, trust me. Save up and buy the components you don’t think you need because you’ll eventually want them down the road.
  15. Jul 31, 2018 at 4:09 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    I think the truck will look good when finished! If you plan to off road the truck, I would definitely save a little more and get a better lift setup. Take a look at the Toytec/Eibach lift. It's roughly $850, plus you get a discount for being a forum member, but it's a 3/1 coilover lift. Comes with new struts and springs already assembled as well as the rear lift. Only downside is it does not include UCA's. Zone offroad has some pretty beefy UCA's as well you could look at.
    I went the budget route the first time, which has served my needs well, I don't take the truck offroad or anything like that. I'm hoping these stock shocks last until my next set of tires (I just got some, so another 45k+) and I plan to replace the shocks. When I do, I will most likely go with one of the lifted struts or Eibachs. By that point, my truck will have roughly 180k miles on it and I figure the shocks could use replacing. I did a 2" spacer and my truck has definitely settled some on the front end, which is why I was thinking of getting the new springs as well.
    Mountun Goat and Sas[OP] like this.
  16. Jul 31, 2018 at 5:13 AM
    Sas
    OKC, OK
    Good advice gents. Sounds like I'm going to wait a bit and spring for the better setup.
    Mountun Goat and boardude like this.
  17. Jul 31, 2018 at 6:30 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Smart! I can never understand why someone would want to throw on a $500 lift on a 40k - 50k truck only to make the ride worse and not functional.
    Buy once, cry once. Your truck will look and ride great!
  18. Jul 31, 2018 at 8:55 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yes, that is correct.
  19. Jul 31, 2018 at 9:23 AM
    Sas
    OKC, OK
    Apparently the TSS wheels I have are +50 offset and are 20x9. Can anyone verify?
  20. Jul 31, 2018 at 10:02 AM
    Sas
    OKC, OK
  21. Jul 31, 2018 at 11:48 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    What email did you send it to?
    shoot me a pm or an email direct at Davidm@toyteclifts.com and Ill take care of you!
    Thanks
  22. Jul 31, 2018 at 12:09 PM
    Sas
    OKC, OK
    I used the form mail at: I'll shoot you an email, thanks!
  23. Jul 31, 2018 at 5:39 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Everyone loves a good story :broccoli:
