Fat Bob's Garage Setup
Discussion in 'Suspension' started by 1BadTundra, Oct 1, 2017.
  1. Oct 1, 2017 at 3:01 PM
    1BadTundra
    1BadTundra [OP] New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    Ok, after comparing the differences and similarities, and weighing opinions of reviewers and pros... I went Fat Bob's. Bang for the buck they seemed to win out. Bobs made me a deal I couldn't refuse, and these things are awesome. I can't compare to Toytec, but compared to the Bilstein yellows, and 5100s on my buddy's Tundra, these run right along side with them, if not better. I say better, because the ride is a cunt hair firmer. It feels like it helps with less body roll. So, starting with packing, they came to my door 6 days after ordering o a Friday evening, from Utah to PA. They arrived in a single box with molded foam sandwiching the parts. Two spanner wrenches, and the coilovers, pre-assembled. The install was straight forward, I replaced my brakes, (front rotors & pads) the whole job took about 4 (3-6:45) hours (including cleanup) It took a ltitle longer because I had some stubborn bolts, two guide pins had to be cut out of one caliper, and then a run to Autozone for new ones. Then both rotors had to be beat off of the hubs, as the 8mm jack bolt holes were rusted out. I replaced them with black electro-plated crossdrilled/slotted rotors, and ceramic pads, matched by StopTech. The reinstallation was straight forward. Everything fit perfectly, and tightend down right. The coilover are preset by FatBobs, I'm going to call tomorrow and see what it is, looks like 3ish inches, 40.5" fender to ground. Out back, I installed Bilstein 5100's, and adjustable shackles, on the middle holes (1.75") the ride is amazing, I'd like to go 1/4" more up front, but I'm just weird like that.
    equin, georgiey22, Kerch71 and 6 others like this.
  2. Oct 1, 2017 at 3:07 PM
    Basskrazee
    Basskrazee Pop
    Joe
    Indianapolis, IN.
    2016 Tundra SR5 /TRD
    AFE mass air intake TRD rear anti sway bar Headwaters seat covers TRD Pro grill Bilstien 6112 coil overs Bilstien 5160 rear shocks Consol vault
    Very nice look
  3. Oct 1, 2017 at 3:13 PM
    1BadTundra
    Clinton
    Too Much to List
    Thanks man, sorry for the low quality pics... Just took them real fast with my phone.
  4. Oct 1, 2017 at 5:53 PM
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    Hey what’s up man.
    So I’ve been looking at a 3.5” fat bob setup vs the toytec 3” boss system, trying to figure which would suite my needs better, and price vs price, obviously.
    Did you go with a full kit or just the front shocks/coil overs?
  5. Oct 1, 2017 at 6:07 PM
    1BadTundra
    Clinton
    Too Much to List
    I just got the front coilovers. The 3.5 did have the UCAs, but also spacers. I already had spacers, I wanted the tuned shocks and coils. The ride is unbelievable compared to stock with a spacer, definitly money well spent. Up to 3.25" doesn't require UCAs, anything over that does. I had shackles for the rear anyway, the blocks I had before were giving me axle wrap. Shackles put some arch back in the leafs, not just spacing the axle with a block. This is all just my opinion, I've been lifting and lowering things for about 20 years now.
  6. Oct 1, 2017 at 6:20 PM
    TundraTss
    Brandon
    2019 TRD SR5
    Right on man.
    You happen to know anybody with the 3.5” from Bob’s?
    For what I do, I don’t need anything crazy. Aside from camping a few times a year during the summer, she’s a concrete queen for sure. I like the toytec because it’s got rear shocks included, but whatever I get I’m going to get UCAs with it, just for alignment, canter, etc, but to include UCAs with the toytec kit puts it close to 2 g’s, whereas the kit from Bob’s would get me everything I need, plus an extra 1/2 inch, and would also let me get tires at the same time...
  7. Oct 1, 2017 at 6:53 PM
    TheBeast The Beach
    looks great !
    I also run stop tech rotors + ceramic pads. big difference from stock when braking.
    1BadTundra[OP] likes this.
  8. Oct 2, 2017 at 3:19 PM
    1BadTundra
    Clinton
    Too Much to List
    I was contemplating the same thing. I'm happy with my decision. I can do UCA's in the future, but for now it lines up right, and rides like a new truck.
  9. Oct 2, 2017 at 3:21 PM
    1BadTundra
    Clinton
    Too Much to List
    Huge difference, the pedal is almost touchy now. Lately, Ive had to stand on the brakes, so these are a relief
    TheBeast[QUOTED] likes this.
  10. Feb 28, 2018 at 8:34 AM
    ttka1868
    ttka1868 New Member
    JJ
    2014 Silver Platinum
    I don't see a 3.5 option on Fat Bob's what am I missing? I only see a 3" option, please help!
  11. Feb 28, 2018 at 4:24 PM
    1BadTundra
    Clinton
    Too Much to List
    The 3" can be safely adjusted higher to 3.5"... It can go more, but isn't recommended
  12. Feb 6, 2019 at 10:59 AM
    TrooperDC4x4
    TrooperDC4x4 New Member
    Nor Cal
    2017 BBP Double Cab 5.7L TRD 4X4 OR
    Bilstein 5100 2.5", 1.5"
    How are these holding up?
    I am leaning toward Fat Bob's Version with the Bilstein 5100's.
    The stance of yours looks good.
  13. Feb 6, 2019 at 4:10 PM
    1BadTundra
    Clinton
    Too Much to List
    They corroded pretty bad after a year. I contacted them and they said that something about the salt spray testing and something had to have happened and they weren't treated properly. They sent me a new set to swap out, they have been awesome since.
  14. Sep 1, 2019 at 4:54 AM
    roy2015
    roy2015 Waterproof
    Houston
    Super White = Super Fast
    It's been a while since . . . . how have the second set held up? Would you still recommend FBGs?
  15. Sep 1, 2019 at 5:04 AM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Looks righteous! REALLY like the way it sits.
  16. Sep 2, 2019 at 6:36 AM
    1BadTundra
    Clinton
    Too Much to List
    They held up great, I ended up with a 6" lift and needed to remove the FBG's because they didnt work out with the spacers on the 6". They were awesome struts though. I'd recommend them to anyone. I
    Thanks, sometimes I wish I'd have left it alone at this point.
  17. Sep 2, 2019 at 8:07 AM
    roy2015
    roy2015 Waterproof
    Houston
    Any particular reason why?
  18. Sep 2, 2019 at 8:19 AM
    1BadTundra
    Clinton
    Too Much to List
    Idk, it was simple then. The 6" lift takes a little drivability away from the truck. I lost some turning radius, the 37's ride rough, and she wont hold an alignment. Most of all, I went with -24 offset wheels, and needed fender flares to keep the law off my ass. I hate flares! The truck is cool, just wish I'd done things a little different.
  19. Sep 2, 2019 at 9:26 AM
    roy2015
    roy2015 Waterproof
    Houston
    Sounds like this one needs to be your toy truck. Go buy a 2019 for your daily driver
  20. Sep 2, 2019 at 9:48 AM
    1BadTundra
    Clinton
    Too Much to List
    She is the toy. It's my shop truck. I daily an A6, my 65 mile daily round trip commute would eventually kill her.
    roy2015 likes this.
  21. Sep 2, 2019 at 9:49 AM
    TurboGoKart
    TurboGoKart New Member
    Ha! I just switched to my Tundra from my '12 A6! I love mine. Think I'm gonna sell the wife's Altima and let her drive the A6. :eek:
    Also, you could grab CoachBuilders 1/4" shims and bump the front up a tad! No extra bolts needed or anything, just drop the coilovers, slide those in and re-bolt it all together.
  22. Sep 2, 2019 at 9:52 AM
    TurboGoKart
    Do you have UCA's?
  23. Sep 2, 2019 at 9:54 AM
    1BadTundra
    Clinton
    Too Much to List
    I made my own spacers, I did 1/4 on one side, 3/8 on the low side. So it gave me 1/2 on one and 3/4 on the other. I just picked up my 2018 A6 after totalling my 2015 Passat.
    TurboGoKart likes this.
  24. Sep 2, 2019 at 9:54 AM
    1BadTundra
    Clinton
    Too Much to List
    I'm on Rough Country UCAs.
    TurboGoKart[QUOTED] likes this.
  25. Sep 2, 2019 at 11:28 AM
    TurboGoKart
    Any issues with them, mechanical or uneven tire wear? I like their price lol.
  26. Sep 2, 2019 at 2:03 PM
    1BadTundra
    Clinton
    Too Much to List
    No, they are well built. I was pleasantly surprised when they arrived. I was actually skeptical myself. When they came in, I couldn't wait to get them on. Greasable Ball Joints are nice on them too.
    Akaklutz and TurboGoKart like this.
