False ABS activation?
Discussion in '1st Gen Tundras (2000-2006)' started by dav1dmiller, May 3, 2019.
  1. Aug 9, 2022 at 3:17 PM
    Do diagnostics on the wheel speed sensors. This is a common cause for the condition you're suffering with. Note they must be installed correctly or weird shit happens.
  2. Aug 9, 2022 at 4:55 PM
    nickrick78
    nickrick78 New Member
    Nick
    Pittsburgh PA
    2004 DC
    Usually you need a scanner that graphs all four wheel speed signals at the same time.
    You'll let it run while driving, and monitor which wheel signal drops out quicker than the other three. That's the corner you have a problem on.
    Inspect sensor and tone ring on that corner. If tone ring is ok replace sensor.
  3. Aug 9, 2022 at 5:01 PM
    Aerindel
    Aerindel New Member
    Montana
    See the stickied post on this sub forum on rear brakes. Common problem.
    https://www.tundras.com/threads/rear-brake-adjustment-theory-and-practice.99575/
    shifty` likes this.
