Fall is here, winter is coming
Discussion in '2.5 Gen Tundras (2014-2021)' started by FrostyTundra22, Sep 26, 2022.
  1. Oct 5, 2022 at 10:50 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    As for the sandbags...is there any concern of them becoming frozen projectiles, in the event of a crash?
  2. Oct 5, 2022 at 10:56 AM
    RaginTxn
    RaginTxn New Member
    Ya done messed up..
    Cypress, TX
    2018 SR5 X Series Tundra (sold) - why, why, why
    I guess you could argue maybe, but I've never seen anything specific on it - if you're in an accident where you're launching 80lb bags of sand with any kind of velocity to be deemed a projectile, I would imagine you have other more pressing issues to worry about :D
    Bammer likes this.
  3. Oct 6, 2022 at 3:46 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I have dedicated rims and snow tires, a couple of sands bags and fluid film or NH oil or whatever your choice is on the underneath.
    Take your time in the snow.
    dondino likes this.
  4. Oct 6, 2022 at 4:06 AM
    Adam New Member
    When it gets cold (around Nov/Dec) time I will throw a can of Sea Foam in the tanks of both our vehicles. Mainly to bond to the water that is in the tank. I hit it again in Feb when it is butt ass cold. Keeping the tank topped off will help keep the water out, but throwing something in there to bond and burn it is also an ounce of prevention. Also does other things like cleans injectors, blah, blah, blah...
  5. Oct 7, 2022 at 4:37 PM
    FrostyTundra22
    FrostyTundra22 [OP] No longer new member
    2020 Toyota Tundra 1794 Crewmax
    First time hearing about seafoam
  6. Oct 7, 2022 at 5:04 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    Seafoam among other things can be used in your gas to clean the fuel system as well as in your oil before an oil change to remove sludge. Pretty cool stuff.
  7. Oct 8, 2022 at 5:26 AM
    Adam New Member
    I put a bit of it in my fuel cans every time I fill them. What made a believer out of me was I bought a generator in 08 due to some flooding going on around here and didn't know if we were going to have power. I filled it with unleaded and put some seafoam in which I had purchased on a whim. I didn't end up needed to use the generator so the fuel and sat. I would pull the generator out every 6m to 1y to run it for 10 min and make sure everything was still working. Always started on the first or second pull. Finally in 18 (yes ten years later) it started to ever so slightly miss a little bit when it was running, so I drained the fuel out and dumped it in my Tundra. I was pretty impressed at that point. I don't know if I just got lucky or what. Since putting it in all my cans, and running it in my boat, I have never had bad fuel since. I have had bad gas...my wife and daughter can attest to that.:devil:
    dondino and Ponderosa_Pine like this.
  8. Oct 8, 2022 at 11:18 AM
    Tsm503
    Tsm503 Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    Use 4wd if you have it
    Snow rated tires
    Tire chains
    Weight in the bed
    Fill your gas tank
    Keep distance from people ahead of you
    Drive cautiously
    All or any combination of these will help you avoid accidents dramatically
    Tundrastruck91 likes this.
  9. Oct 8, 2022 at 12:12 PM
    Wallygator
    The camping gear and topper stay on full time so there is the weight. Often find myself away from things, so I also carry a small recovery kit (snatch strap, chain, shackles, etc.), tools, some snacks, water, extra hat, flashlight, lighters, fat wood, extra jacket, a blanket or two, boots if I have shoes on, hell I even carry a chain saw full time in the truck. Probably overkill but don't like to be in a situation with out some preparations or at least some stuff that could help me get out of a situation if one arises. :notsure:
    tiogajoe and dondino like this.
  10. Nov 14, 2022 at 9:26 AM
    FrostyTundra22
    Well, we had our first snow fall of the season. I was excited to drive my Tundra in the first snow but not going to lie. It was a different experience to what I am used to.
    we have a highlander with AWD and it is a pleasure to drive in the snow.
    Since the roads were slick, I put 4hi and it was very similar to what my highlander feels like but when I turn it feels a bit jittery.
    Other than the jitter which I understand is from turning while on 4hi, it drives really nice in the snow.
    I’m hoping I’m bot damaging anything when I feel that jitter. The steering wheel itself feels fine and turns smooth.
    Am I missing something or should I just get used to it.
  11. Nov 14, 2022 at 9:33 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Right in 4hi you generally don’t want to turn unless the roads are very wet/snow/gravel/etc enough that the inner wheels can slip enough. Like if the road is mostly dry then you’d have to leave it in 2wd otherwise every turn will be brutal on the drivetrain.
    PermaFrostTRD likes this.
  12. Nov 14, 2022 at 1:37 PM
    WV_Warrior
    WV_Warrior New Member
    Cody
    West Virginia
    2021 CM TRD Sport
    I’ve got a couple of sections of railroad track that I’ll throw in the bed of mine. I’ll also use some bags of sand on top of them for additional weight.
